Velodyne VLP 16 Driveworks
Software Version
[*] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
IÔÇÖm trying to visualize the real time data from Velodyne VLP16.
  1. Followed steps from Ros driver blog for network setup through terminal velodyne/Tutorials/Getting Started with the Velodyne VLP16 - ROS Wiki
  2. Trying to execute the lidar replay sample from driveworks sdk DriveWorks SDK Reference: Lidar Replay Sample
Not able to visualize any data.
Dear @mugeshkannan.ks ,
I can see the file on my target. Could you share dpkg -l | grep driveworks
/usr/local/driveworks-5.14/data/samples/sensors/lidar/hesai-P128-dual_v6_codecs.bin
nvidia@tegra-ubuntu:/usr/local/driveworks/bin$ dpkg -l | grep driveworks
ii  driveworks                                                              5.14.74~linux6.0.8.0-338205240          arm64        NVIDIA® DriveWorks software development kit (SDK) provides a foundation
ii  driveworks-cgf                                                          5.14.74~linux6.0.8.0-338205240          arm64        NVIDIA® DriveWorks software development kit (SDK) provides a foundation
ii  driveworks-cgf-data                                                     5.14.74-338205240                       all          NVIDIA® DriveWorks software development kit (SDK) provides a foundation
ii  driveworks-cgf-samples                                                  5.14.74~linux6.0.8.0-338205240          arm64        NVIDIA® DriveWorks software development kit (SDK) provides a foundation
ii  driveworks-data                                                         5.14.74-338205240                       all          NVIDIA® DriveWorks software development kit (SDK) provides a foundation
ii  driveworks-samples                                                      5.14.74~linux6.0.8.0-338205240          arm64        NVIDIA® DriveWorks software development kit (SDK) provides a foundation
ii  driveworks-stm                                                          19.1.0                                  arm64        NVIDIA® DriveWorks software development kit (SDK) provides a foundation
nvidia@tegra-ubuntu:~/dw/data/samples/sensors/lidar$ ls
DataspeedByWire.dbc  gps.bin                        hesai-P128-dual_v6_codecs.bin.seek  lidar_left_hdl32e.bin   lidar_top_hdl64e.bin  nv_lidar.bin.seek
can.bin              hesai-P128-dual_v6_codecs.bin  imu.bin                             lidar_right_hdl32e.bin  nv_lidar.bin          rig.json
nvidia@tegra-ubuntu:/usr/local/driveworks$ dpkg -l | grep driveworks
I am able to visualize the sample data using sample_lidar_relay without passing any arguments. but i want to visualize the real time lidar stream
Dear @mugeshkannan.ks,
Could you check if Launching the velodyne lidar VLP16 is getting failed, this is while it is working with ROS - #10 by user158496 helps?
I notice driveworks-data package is not installed on target. You can find the debians at /drive/extra/driveworks on DRIVE OS 6.0.8.1 docker containers.
Any guide to install /drive/extra/driveworks in target from host docker. can you please share?
You can copy the debians to target using scp and install them on target. If you want driveworks sample data, you need to install just driveworks data debian.
Thanks now able to stream the realtime data from velodyne VLP16
