Veracrypt
I’m trying to encrypt a drive using verycrypt and I’m running into an error that seems to plague ARM machines. The error is:
Error: device-mapper: reload ioctl on veracrypt1 failed: Invalid argumentCommand failed
The areguments I’m passing to veracrypt are:
sudo veracrypt -t -c -m=nokernelcrypto --quick /dev/sdb1
I just did a simple sudo apt install veracrypt, which may not support ARM devices; not sure though.
Similar problems here: Veracrypt Error device-mapper: reload ioctl Error Fixed – The Chewett blog
Any thoughts?
hello will.e.carlson,
verycrypt is one open source disk encryption tool.
actually, we propose Trusty, a Trusted Execution Environment and using CA/TA service for communication.
thanks
