We had been trying to get our TPM to work with SPI2 in uboot to provide security for FDE. However we have hit some roadblocks that have kept us from doing so. Our next best option is to extend the root of trust by using Verified Boot. This means we need to package our Kernel, Initrd, and FDT as a signed FIT Image.
I have started by not using signed images to just try and get the thing to boot. I am having an issue getting the FIT to boot as expected.
This is the fit-image.its file we are using:
/dts-v1/;
description = "FIT image for Codename";
#address-cells = <1>;
images {
kernel {
description = "Linux";
data = /incbin/("Image");
type = "kernel";
arch = "arm";
os = "linux";
compression = "none";
load = <0x84000000>;
entry = <0x84000000>;
hash-1 {
algo = "sha256";
initrd {
description = "Initrd";
data = /incbin/("initrd");
type = "ramdisk";
arch = "arm";
os = "linux";
load = <0x83200000>;
entry = <0x83200000>;
hash-1 {
algo = "sha256";
fdt {
description = "DTB";
data = /incbin/("kernel_tegra210-p3448-0002-p3449-0000-b00.dtb");
type = "flat_dt";
arch = "arm";
load = <0x83000000>;
entry = <0x83000000>; hash-1 {
algo = "sha256";
configurations {
default = "conf";
conf {
description = "Config";
kernel = "kernel";
ramdisk = "initrd";
fdt = "fdt";
I used copied our Image, Initrd, and DTB to the same directory and ran:
$LINUX_FOR_TEGRA_DIR/sources/u-boot/tools/mkimage -f fit-image.its FitImage
This generates the FitImage binary that can be checked with mkimage -l:
sudo ../sources/u-boot/tools/mkimage -l FitImage
FIT description: FIT image for Codename
Created: Thu Nov 17 22:53:26 2022
Image 0 (kernel)
Description: Linux
Type: Kernel Image
Compression: uncompressed
Data Size: 33892360 Bytes = 33098.01 KiB = 32.32 MiB
Architecture: ARM
OS: Linux
Load Address: 0x84000000
Entry Point: 0x84000000
Hash algo: sha256
Hash value: 7bc16c4173f179d71efb2d872bba5ca8cd2d30d969396f6c1911ac37b11d91d2
Image 1 (initrd)
Description: Initrd
Type: RAMDisk Image
Data Size: 13919184 Bytes = 13592.95 KiB = 13.27 MiB
Architecture: ARM
OS: Linux
Load Address: 0x83200000
Entry Point: 0x83200000
Hash algo: sha256
Hash value: de20057ea88c89284577bf409ecf71aa24f757971d57ced51cbad185ee5602e6
Image 2 (fdt)
Description: DTB
Type: Flat Device Tree
Data Size: 221698 Bytes = 216.50 KiB = 0.21 MiB
Architecture: ARM
Load Address: 0x83000000
Hash algo: sha256
Hash value: 7c6a2a9454449d7732a7c4a83dea0d0eef2007bd8d2a0d4587d31469ee2d2179
Default Configuration: 'conf'
Configuration 0 (conf)
Description: Config
Kernel: kernel
Init Ramdisk: initrd
FDT: fdt
I added the following to the uboot config:
CONFIG_RSA=y
CONFIG_FIT=y
CONFIG_FIT_EXTERNAL_OFFSET=0x0
CONFIG_FIT_ENABLE_SHA256_SUPPORT=y
CONFIG_FIT_SIGNATURE=y
CONFIG_FIT_SIGNATURE_MAX_SIZE=0x10000000
CONFIG_USE_BOOTARGS=y
CONFIG_BOOTARGS="root=UUID=5d9904fa-9ca0-4869-b53c-4244b931e0cc rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 fsck.mode=force fsck.repair=yes rng_core.default_quality=1000"
I added the public key info to (but again, not requiring signatures yet)
signature {
key-dev {
I bumped the bootm size to 64MB as well.
I have CONFIG_LEGACY_IMAGE_FORMAT=y
for now to support this test process.
When I flash the update uboot to LNX and add the FitImage binary blob to /boot I try and boot to it by doing the following:
ext4load mmc 0 0x95000000 /boot/FitImage
bootm 0x95000000
I then get the following:
Tegra210 (P3450-0000) # ext4load mmc 0 0x95000000 /boot/FitImage
48035172 bytes read in 1100 ms (41.6 MiB/s)
Tegra210 (P3450-0000) # bootm 0x95000000
## Loading kernel from FIT Image at 95000000 ...
Using 'conf' configuration
Verifying Hash Integrity ... OK
Trying 'kernel' kernel subimage
Description: Linux
Type: Kernel Image
Data Start: 0x950000bc
Data Size: 33892360 Bytes = 32.3 MiB
Architecture: ARM
OS: Linux
Hash algo: sha256
Verifying Hash Integrity ... sha256+ OK
## Loading ramdisk from FIT Image at 95000000 ...
Trying 'initrd' ramdisk subimage
Description: Initrd
Type: RAMDisk Image
Data Start: 0x970529b0
Data Size: 13919162 Bytes = 13.3 MiB
Architecture: ARM
OS: Linux
Hash algo: sha256
Hash value: 1da6bec88f93454fb27c8255d9e0ac92898721132d09222e9bc07e6ab8612bc0
Loading ramdisk from 0x970529b0 to 0x83200000
## Loading fdt from FIT Image at 95000000 ...
Trying 'fdt' fdt subimage
Description: DTB
Data Start: 0x97d98e50
Data Size: 221698 Bytes = 216.5 KiB
Architecture: ARM
Hash algo: sha256
Loading fdt from 0x97d98e50 to 0x83000000
Booting using the fdt blob at 0x83000000
Loading Kernel Image
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083000000, end 0000000083039201
copying carveout for /host1x@50000000/dc@54200000...
copying carveout for /host1x@50000000/dc@54240000...
DT property /chosen/nvidia,bluetooth-mac missing in source; can't copy
DT property /chosen/nvidia,wifi-mac missing in source; can't copy
DT property /psci/nvidia,system-lp0-disable missing in source; can't copy
Starting kernel ...
It halts after “Starting kernel …” and never continues. I used the same Image, Initrd, and FDT binaries we have successfully been booting to with the normal boot process. I took the addresses from the printenv variables of uboot for where it usually loads the kernel, initrd, and the fdt.
Does someone who has done this before have a clue that could point me in the right direction to get this working?
