Using the following scripts to verify Hawk camera:
“cd /usr/src/jetson_multimedia_api/argus/cmake/
sudo cmake …
sudo make install
argus_syncstereo”
but nncounter the following problems:
sudo cmake …
sudo make install
argus_syncstereo”
Hi @1471131969
Have you checked if your Hawk camera is connected to your Jetson as per the vendor documentation?
To better assist you, could you please specify which Hawk camera and NVIDIA Jetson model you are using?
Best,
Raffello
I will check this later
