When I’m trying to run isaaclab, I get this error:
(isaaclab) D:\Nvidia_Omniverse\isaaclab3\IsaacLab>isaaclab.bat -p source\standalone\tutorials\00_sim\create_empty.py
[INFO] Using python from: D:\Nvidia_Omniverse\Anaconda\envs\isaaclab\python.exe
[WARN][AppLauncher]: There are no arguments attached to the ArgumentParser object. If you have your own arguments, please load your own arguments before calling the AppLauncher.add_app_launcher_args
method. This allows the method to check the validity of the arguments and perform checks for argument names.
[INFO][AppLauncher]: Loading experience file: D:\Nvidia_Omniverse\isaaclab3\IsaacLab\source\apps\isaaclab.python.kit
[Warning] [omni.isaac.kit.simulation_app] Modules: [‘omni.kit_app’] were loaded before SimulationApp was started and might not be loaded correctly.
[Warning] [omni.isaac.kit.simulation_app] Please check to make sure no extra omniverse or pxr modules are imported before the call to SimulationApp(…)
Loading user config located at: ‘d:/nvidia_omniverse/anaconda/envs/isaaclab/lib/site-packages/omni/data/Kit/Isaac-Sim/4.2/user.config.json’
[Info] [carb] Logging to file: d:/nvidia_omniverse/anaconda/envs/isaaclab/lib/site-packages/omni/logs/Kit/Isaac-Sim/4.2/kit_20241127_111551.log
2024-11-27 09:15:51 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn’t available.
2024-11-27 09:15:53 [1,969ms] [Error] [omni.ext.plugin] Failed to resolve extension dependencies. Failure hints:
[isaaclab.python-1.3.0] dependency: ‘omni.physx.bundle’ = { version=‘^’ } can’t be satisfied. Available versions:
(none found)
Synced registries:
- kit/default : found 388 packages
- kit/sdk : found 317 packages
- kit/community : found 384 packages
2024-11-27 09:15:53 [1,970ms] [Error] [omni.kit.app.plugin] Exiting app because of dependency solver failure…
File “D:\Nvidia_Omniverse\isaaclab3\IsaacLab\source\standalone\tutorials\00_sim\create_empty.py”, line 29, in
app_launcher = AppLauncher(args_cli)
File “D:\Nvidia_Omniverse\isaaclab3\IsaacLab\source\extensions\omni.isaac.lab\omni\isaac\lab\app\app_launcher.py”, line 113, in init
self._create_app()
File “D:\Nvidia_Omniverse\isaaclab3\IsaacLab\source\extensions\omni.isaac.lab\omni\isaac\lab\app\app_launcher.py”, line 607, in _create_app
self._app = SimulationApp(self._sim_app_config, experience=self._sim_experience_file)
File “D:\Nvidia_Omniverse\Anaconda\envs\isaaclab\Lib\site-packages\isaacsim\exts\omni.isaac.kit\omni\isaac\kit\simulation_app.py”, line 214, in init
from .utils import create_new_stage, open_stage, set_livesync_stage
File “D:\Nvidia_Omniverse\Anaconda\envs\isaaclab\Lib\site-packages\isaacsim\exts\omni.isaac.kit\omni\isaac\kit\utils.py”, line 17, in
from omni.kit.usd import layers
ModuleNotFoundError: No module named ‘omni.kit.usd’
2024-11-27 09:15:53 [1,973ms] [Warning] [carb] Recursive unloadAllPlugins() detected!
Can someone help me? Thank you!
