It will fail if version 470.63.1 is greater, either on ubuntu18.04 or ubuntu20
I installed 525.116.04,525.85.05,525.89.02,525.60.13,470.141.03,515… 530… all failed
cpu:
ll
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
Address sizes: 39 bits physical, 48 bits virtual
CPU(s): 16
On-line CPU(s) list: 0-15
Thread(s) per core: 2
Core(s) per socket: 8
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 158
Model name: Intel(R) Core™ i9-9900K CPU @ 3.60GHz
Stepping: 13
CPU MHz: 800.081
CPU max MHz: 5000.0000
CPU min MHz: 800.0000
BogoMIPS: 7200.00
Virtualization: VT-x
L1d cache: 256 KiB
L1i cache: 256 KiB
L2 cache: 2 MiB
L3 cache: 16 MiB
NUMA node0 CPU(s): 0-15
nvidia-bug-report.log (379.0 KB)
install cuda_12.0.0_525.60.13_linux.run on ubuntu-18.04
nvidia-bug-report-ubuntu-18.log (357.0 KB)
