I am trying to install kokoro with CUDA. It runs fine on cpu, well not fine (slow!) but it runs. And so starts version hell. You update pyTorch for the machine, now libcuddn doesn’t work. So - you upgrade libcuddn and now libcublas complains. You install libcublas latest, but it’s version 12 - and which doesn’t seem to be compatible with libcuddn9.
The downloaded script bombs out, because it only supports CUDA versions until 12.4 . Easy fix. Changed it to include 12.6 Continue with the document until:
torch-2.0.0+nv23.05-cp38-cp38-linux_aarch64.whl is not a supported wheel on this platform
Thank you very much. Reading other user’s command it turns out, that those wheels were built for Python 3.8, but my machine runs 3.10.12 … ups … compatibility again. Oh well … sorry.
So PLEASE:
I need an environment in which things that depend on each other play nice. CUDA, torch, libcudnn, libcublas and all those little thingies that are supposed to work together. Orins are developer versions, but in order to develop something, one needs an environment that kinda works.
Manually upgrading cuDNN to 9.4.0 can fix this issue.
Since the package is wrapped with a repository configure file, you will need to upgrade the cuDNN with subitems.
Default:
$ dpkg --list | grep cudnn
ii cudnn 9.3.0-1 arm64 NVIDIA CUDA Deep Neural Network library (cuDNN)
ii cudnn-local-tegra-repo-ubuntu2204-9.4.0 1.0-1 arm64 cudnn-local-tegra repository configuration files
ii cudnn9 9.3.0-1 arm64 NVIDIA CUDA Deep Neural Network library (cuDNN)
ii cudnn9-cuda-12 9.3.0.75-1 arm64 NVIDIA cuDNN for CUDA 12
ii cudnn9-cuda-12-6 9.3.0.75-1 arm64 NVIDIA cuDNN for CUDA 12.6
ii libcudnn9-cuda-12 9.3.0.75-1 arm64 cuDNN runtime libraries for CUDA 12.6
ii libcudnn9-dev-cuda-12 9.3.0.75-1 arm64 cuDNN development headers and symlinks for CUDA 12.6
ii libcudnn9-samples 9.3.0.75-1 all cuDNN samples
ii libcudnn9-static-cuda-12 9.3.0.75-1 arm64 cuDNN static libraries for CUDA 12.6
ii nvidia-cudnn 6.2+b77 arm64 NVIDIA CUDNN Meta Package
ii nvidia-cudnn-dev 6.2+b77 arm64 NVIDIA CUDNN dev Meta Package
ii cudnn 9.4.0-1 arm64 NVIDIA CUDA Deep Neural Network library (cuDNN)
ii cudnn9 9.4.0-1 arm64 NVIDIA CUDA Deep Neural Network library (cuDNN)
ii cudnn9-cuda-12 9.4.0.58-1 arm64 NVIDIA cuDNN for CUDA 12
ii cudnn9-cuda-12-6 9.4.0.58-1 arm64 NVIDIA cuDNN for CUDA 12.6
ii libcudnn9-cuda-12 9.4.0.58-1 arm64 cuDNN runtime libraries for CUDA 12.6
ii libcudnn9-dev-cuda-12 9.4.0.58-1 arm64 cuDNN development headers and symlinks for CUDA 12.6
ii libcudnn9-samples 9.4.0.58-1 all cuDNN samples
ii libcudnn9-static-cuda-12 9.4.0.58-1 arm64 cuDNN static libraries for CUDA 12.6
After upgrading cuDNN, the PyTorch cuDNN backend can work correctly:
python3
Python 3.10.12 (main, Nov 6 2024, 20:22:13) [GCC 11.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import torch
>>> torch.__version__
'2.6.0-rc1'
>>> print(torch.backends.cudnn.version())
90400
