Can someone please tell me the vertical dimension, hole to hole, of the top-left most mounting hole labeled ‘A’ on the development board…this dimension is not given in your data sheet.
Dan
Dan
Hi, what do you the vertical dimension of “hole to hole”? Is it PCB thickness?
I was wondering on the vertical value in order to determine mounting hole location. On the dev board mechanical drawing there are four holes marked ‘A’ with the bottom left being the origin. The top left does not have a vertical location value and thus I cannot complete my design project.
Dan
There will be a update file in DLC soon. Take a screenshot for your reference.
External Media
