Very bad result on tlt mobilenetv2 tensorrt
Description
Hello everyone.
Thanks for nvidia tlt:v3.0-py3. I get very good result on tlt mobilenet-v2 classification model.
Unfortunatly, i convert my tlt model to tensorrt engine (both fp16 and int8). I got very bad results.
With my training data, i have total 3 class. The tensorrt prediction always give me highest score on the third class.
To make it more clear. I test both tlt model and tensorrt model on the same dataset. tlt model give me very good result (99% acc). TRT engine (FP16 and INT8) give very bad results
Environment
TensorRT Version: 7.2.1
GPU Type: RTX 2080ti
Reproduce
After get .tlt model, i convert tlt model to tensorrt engine model.
 !tlt-converter $USER_EXPERIMENT_DIR/export/final_model.etlt \
                -k $KEY \
                -c $USER_EXPERIMENT_DIR/export/final_model_int8_cache.bin \
                -o predictions/Softmax \
                -d 3,224,224 \
                -i nchw \
                -m 64 -t int8 \
                -e $USER_EXPERIMENT_DIR/export/mobilenet_tensort7221_batch1.engine \
                -b 1
mobilenet_tensort721.engine (2.8 MB)
Model config (1.4 KB)
For more detail, below is my tlt process.
classification.ipynb (893.7 KB)
Here is my tensorrt code. Please help me take a look
import pycuda.driver as cuda
import pycuda.autoinit
import numpy as np
import tensorrt as trt
import cv2
import torch
TRT_LOGGER = trt.Logger()
# Simple helper data class that's a little nicer to use than a 2-tuple.
class HostDeviceMem(object):
	def __init__(self, host_mem, device_mem):
		self.host = host_mem
		self.device = device_mem
	def __str__(self):
		return "Host:\n" + str(self.host) + "\nDevice:\n" + str(self.device)
	def __repr__(self):
		return self.__str__()
# Allocates all buffers required for an engine, i.e. host/device inputs/outputs.
def allocate_buffers(engine):
	inputs = []
	outputs = []
	bindings = []
	stream = cuda.Stream()
	out_shapes = []
	input_shapes = []
	out_names = []
	max_batch_size = engine.max_batch_size
	for binding in engine:
		binding_shape = engine.get_binding_shape(binding)
		#Fix -1 dimension for proper memory allocation for batch_size > 1
		if binding_shape[0] == -1:
			binding_shape = (1,) + binding_shape[1:]
		size = trt.volume(binding_shape) * max_batch_size
		dtype = trt.nptype(engine.get_binding_dtype(binding))
		# Allocate host and device buffers
		host_mem = cuda.pagelocked_empty(size, dtype)
		device_mem = cuda.mem_alloc(host_mem.nbytes)
		# Append the device buffer to device bindings.
		bindings.append(int(device_mem))
		# Append to the appropriate list.
		if engine.binding_is_input(binding):
			inputs.append(HostDeviceMem(host_mem, device_mem))
			input_shapes.append(engine.get_binding_shape(binding))
		else:
			outputs.append(HostDeviceMem(host_mem, device_mem))
			#Collect original output shapes and names from engine
			out_shapes.append(engine.get_binding_shape(binding))
			out_names.append(binding)
	return inputs, outputs, bindings, stream, input_shapes, out_shapes, out_names, max_batch_size
# This function is generalized for multiple inputs/outputs.
# inputs and outputs are expected to be lists of HostDeviceMem objects.
def do_inference(context, bindings, inputs, outputs, stream):
	# Transfer input data to the GPU.
	[cuda.memcpy_htod_async(inp.device, inp.host, stream) for inp in inputs]
	# Run inference.
	context.execute_async(bindings=bindings, stream_handle=stream.handle)
	# Transfer predictions back from the GPU.
	[cuda.memcpy_dtoh_async(out.host, out.device, stream) for out in outputs]
	# Synchronize the stream
	stream.synchronize()
	# Return only the host outputs.
	return [out.host for out in outputs]
class TrtModel(object):
	def __init__(self, model):
		self.engine_file = model
		self.engine = None
		self.inputs = None
		self.outputs = None
		self.bindings = None
		self.stream = None
		self.context = None
		self.input_shapes = None
		self.out_shapes = None
		self.max_batch_size = 1
		self.cuda_ctx = cuda.Device(0).make_context()
		if self.cuda_ctx:
			self.cuda_ctx.push()
	def build(self):
		with open(self.engine_file, 'rb') as f, trt.Runtime(TRT_LOGGER) as runtime:
			self.engine = runtime.deserialize_cuda_engine(f.read())
		self.inputs, self.outputs, self.bindings, self.stream, self.input_shapes, self.out_shapes, self.out_names, self.max_batch_size = allocate_buffers(
			self.engine)
		self.context = self.engine.create_execution_context()
		self.context.active_optimization_profile = 0
		if self.cuda_ctx:
			self.cuda_ctx.pop()
	def run(self, input, deflatten: bool = True, as_dict=False):
		# lazy load implementation
		if self.engine is None:
			self.build()
		if self.cuda_ctx:
		input = np.asarray(input)
		batch_size = input.shape[0]
		allocate_place = np.prod(input.shape)
		self.inputs[0].host[:allocate_place] = input.flatten(order='C').astype(np.float32)
		self.context.set_binding_shape(0, input.shape[1:])
		trt_outputs = do_inference(
			self.context, bindings=self.bindings,
			inputs=self.inputs, outputs=self.outputs, stream=self.stream)
		if self.cuda_ctx:
			self.cuda_ctx.pop()
		#Reshape TRT outputs to original shape instead of flattened array
		if deflatten:
			trt_outputs = [torch.from_numpy(output.reshape(shape)) for output, shape in zip(trt_outputs, self.out_shapes)]
		if as_dict:
			return {name: trt_outputs[i] for i, name in enumerate(self.out_names)}
		return trt_outputs
engine = TrtModel("/data/mobilenet_tensort721.engine")
engine.build()
image = cv2.imread("/data/dataset/train/withmask/2_WORLD_Coronavirus_083975_withmask_4.jpg")
image_rgb = cv2.cvtColor(image, cv2.COLOR_BGR2RGB)
resized_rgb_image = cv2.resize(image_rgb, (224, 224))
normed_image = resized_rgb_image.astype('float32') / 255.0
trt_input = np.transpose(normed_image, (2, 0, 1))
trt_input = np.expand_dims(trt_input, axis=0)
trt_outputs = engine.run(trt_input)
print("trt_output: ", np.array(trt_outputs[0]).shape)
Please try to refer to Inferring resnet18 classification etlt model with python - #41 by Morganh
