Hello! From jetson nano i use this code https://github.com/onnx/models/blob/master/vision/body_analysis/arcface/arcface_inference.ipynb to face identification.
i install mxnet=1.5.1 and other dependence. And this code
sym, arg_params, aux_params = import_model(model)
(import_model from "from mxnet.contrib.onnx.onnx2mx.import_model ") very long time (over 20 minutes). Why? and how can I optimize the startup time? Or maybe you know facial identification systems that also return a 512-dimensional vector for recognition and which can be run on jetson nano? thanks
Minimal code
from __future__ import absolute_import
from __future__ import division
from __future__ import print_function
import cv2
import sys
import numpy as np
import mxnet as mx
import os
import time
from scipy import misc
import random
import sklearn
from sklearn.decomposition import PCA
from time import sleep
from easydict import EasyDict as edict
from mtcnn_detector import MtcnnDetector
from skimage import transform as trans
import matplotlib.pyplot as plt
from mxnet.contrib.onnx.onnx2mx.import_model import import_model
# In[6]:
def get_model(ctx, model):
print(1)
image_size = (112,112)
# Import ONNX model
print(2)
# Define and binds parameters to the network
print(3)
model = mx.mod.Module(symbol=sym, context=ctx, label_names = None)
print(4)
model.bind(data_shapes=[('data', (1, 3, image_size[0], image_size[1]))])
print(5)
model.set_params(arg_params, aux_params)
print(6)
return model
# In[7]:
for i in range(4):
mx.test_utils.download(dirname='mtcnn-model', url='https://s3.amazonaws.com/onnx-model-zoo/arcface/mtcnn-model/det{}-0001.params'.format(i+1))
mx.test_utils.download(dirname='mtcnn-model', url='https://s3.amazonaws.com/onnx-model-zoo/arcface/mtcnn-model/det{}-symbol.json'.format(i+1))
mx.test_utils.download(dirname='mtcnn-model', url='https://s3.amazonaws.com/onnx-model-zoo/arcface/mtcnn-model/det{}.caffemodel'.format(i+1))
mx.test_utils.download(dirname='mtcnn-model', url='https://s3.amazonaws.com/onnx-model-zoo/arcface/mtcnn-model/det{}.prototxt'.format(i+1))
# In[8]:
# Determine and set context
#if len(mx.test_utils.list_gpus())==0:
# ctx = mx.cpu()
#else:
ctx = mx.gpu(0)
# Configure face detector
det_threshold = [0.6,0.7,0.8]
mtcnn_path = os.path.join(os.path.dirname('__file__'), 'mtcnn-model')
detector = MtcnnDetector(model_folder=mtcnn_path, ctx=ctx, num_worker=1, accurate_landmark = True, threshold=det_threshold)
# In[9]:
def preprocess(img, bbox=None, landmark=None, **kwargs):
M = None
image_size = []
str_image_size = kwargs.get('image_size', '')
# Assert input shape
if len(str_image_size)>0:
image_size = [int(x) for x in str_image_size.split(',')]
if len(image_size)==1:
image_size = [image_size[0], image_size[0]]
assert len(image_size)==2
assert image_size[0]==112
assert image_size[0]==112 or image_size[1]==96
# Do alignment using landmark points
if landmark is not None:
src = np.array([
[30.2946, 51.6963],
[65.5318, 51.5014],
[48.0252, 71.7366],
[33.5493, 92.3655],
[62.7299, 92.2041] ], dtype=np.float32 )
if image_size[1]==112:
src[:,0] += 8.0
dst = landmark.astype(np.float32)
tform = trans.SimilarityTransform()
tform.estimate(dst, src)
M = tform.params[0:2,:]
warped = cv2.warpAffine(img,M,(image_size[1],image_size[0]), borderValue = 0.0)
return warped
# If no landmark points available, do alignment using bounding box. If no bounding box available use center crop
if M is None:
if bbox is None:
det = np.zeros(4, dtype=np.int32)
det[0] = int(img.shape[1]*0.0625)
det[1] = int(img.shape[0]*0.0625)
det[2] = img.shape[1] - det[0]
det[3] = img.shape[0] - det[1]
else:
det = bbox
margin = kwargs.get('margin', 44)
bb = np.zeros(4, dtype=np.int32)
bb[0] = np.maximum(det[0]-margin/2, 0)
bb[1] = np.maximum(det[1]-margin/2, 0)
bb[2] = np.minimum(det[2]+margin/2, img.shape[1])
bb[3] = np.minimum(det[3]+margin/2, img.shape[0])
ret = img[bb[1]:bb[3],bb[0]:bb[2],:]
if len(image_size)>0:
ret = cv2.resize(ret, (image_size[1], image_size[0]))
return ret
def get_input(detector,face_img):
# Pass input images through face detector
ret = detector.detect_face(face_img, det_type = 0)
if ret is None:
return None
bbox, points = ret
if bbox.shape[0]==0:
return None
bbox = bbox[0,0:4]
points = points[0,:].reshape((2,5)).T
# Call preprocess() to generate aligned images
nimg = preprocess(face_img, bbox, points, image_size='112,112')
nimg = cv2.cvtColor(nimg, cv2.COLOR_BGR2RGB)
aligned = np.transpose(nimg, (2,0,1))
return aligned
# In[10]:
def get_feature(model,aligned):
input_blob = np.expand_dims(aligned, axis=0)
data = mx.nd.array(input_blob)
db = mx.io.DataBatch(data=(data,))
model.forward(db, is_train=False)
embedding = model.get_outputs()[0].asnumpy()
embedding = sklearn.preprocessing.normalize(embedding).flatten()
return embedding
# In[11]:
# Download first image
mx.test_utils.download('https://s3.amazonaws.com/onnx-model-zoo/arcface/player1.jpg')
# Download second image
mx.test_utils.download('https://s3.amazonaws.com/onnx-model-zoo/arcface/player2.jpg')
# Download onnx model
mx.test_utils.download('https://s3.amazonaws.com/onnx-model-zoo/arcface/resnet100.onnx')
# Path to ONNX model
model_name = 'resnet100.onnx'
# In[ ]:
# Load ONNX model
print("{}".format("Start load model"))
start_time = time.time()
model = get_model(ctx , model_name)
print("{} time load".format(time.time()-start_time))
# In[ ]:
# Load first image
img1 = cv2.imread('player1.jpg')
print("Start_generate_features")
start_time2 = time.time()
# Display first image
#plt.imshow(cv2.cvtColor(img1,cv2.COLOR_BGR2RGB))
#plt.show()
# In[ ]:
# Preprocess first image
pre1 = get_input(detector,img1)
# Display preprocessed image
#plt.imshow(np.transpose(pre1,(1,2,0)))
#plt.show()
# Get embedding of first image
out1 = get_feature(model,pre1)
print("{} generate featuress".format(time.time()-start_time2))
# In[ ]:
# Load second image
img2 = cv2.imread('player2.jpg')
# Display second image
#plt.imshow(cv2.cvtColor(img2,cv2.COLOR_BGR2RGB))
#plt.show()
# In[ ]:
# Preprocess second image
pre2 = get_input(detector,img2)
# plt.imshow(np.transpose(pre2,(1,2,0)))
# plt.show()
# Get embedding of second image
out2 = get_feature(model,pre2)
# In[ ]:
# Compute squared distance between embeddings
dist = np.sum(np.square(out1-out2))
# Compute cosine similarity between embedddings
sim = np.dot(out1, out2.T)
# Print predictions
print('Distance = %f' %(dist))
print('Similarity = %f' %(sim))
