Very low framerate on Tegra devices
I’ve got a serious issue with Tegra devices on my engine: the framerate is extremely low.
For exemple:
  • On Nexus 4, iPad2, HTC Desire HD, … my simulation is smooth and run at 60FPS without problems.
  • On a Wiko Highway 4G (with Tegra 4i inside), the game is running at 14 FPS.
Here is what I’ve tried:
I’m on this problem since some days and I don’t know what is the problem. I’m using PerfHud ES to see where could be the bottleneck, I haven’t found anything but something is strange, the cpu load is moving strangely:
And here is my OpenGL’s call stack: http://pastebin.com/5AfLa9mS
PerfHud ES screenshots:
http://i.stack.imgur.com/BzN7R.png
http://i.stack.imgur.com/dqLck.png
I’m using OpenGL ES2 with an Android native activity.
I haven’t any idea about the problem :/.
Thanks for the help!
FPS is not a performance metric please do some accurate profiling and capture the frame time ( clock time ) as well as draw call timing ( CPU ) and any other interesting function that may need to be times instead of using relative comparison metric. FPS just gives a vague indication that something maybe awry but cannot help you pinpoint where the issue may lie.
What’s your ppsspp settings?
