I’ve created a custom Debian build for a Xavier NX, after I create the rootfs I use the L4T tools to create an SD card image. The card does boot and I can login to the newly created system. What I am seeing is a very long boot time, specifically loading of the kernel and initrd. The following boot log is using a kernel provided by Allied Vision but I have seen the same issue using the stock Nvidia kernel as well.
I have speed tested the SD card once the system is running and I can write at 76MB/s so I don’t think the card is the issue.
Looking at the log times you can see where the issue is. What would cause this to happen.
[0001.164] I> 3) Base:0xf1200000 Size:0x00200000
[0001.169] I> 4) Base:0xf1000000 Size:0x00100000
[0001.173] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.178] I> 6) Base:0xf3800000 Size:0x00400000
[0001.182] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.187] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.191] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.196] I> 10) Base:0xf3000000 Size:0x00800000
[0001.200] I> 11) Base:0x40000000 Size:0x00040000
[0001.205] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.209] I> 13) Base:0x40046000 Size:0x00002000
[0001.213] I> 14) Base:0x40048000 Size:0x00002000
[0001.218] I> 15) Base:0xac000000 Size:0x00004000
[0001.222] I> 16) Base:0x4004a000 Size:0x00002000
[0001.227] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.231] I> 18) Base:0x4004c000 Size:0x00002000
[0001.236] I> 19) Base:0xf2200000 Size:0x00600000
[0001.240] I> 20) Base:0x4004e000 Size:0x00002000
[0001.245] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.249] I> 22) Base:0x00000000 Size:0x00000000
[0001.254] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.258] I> 24) Base:0xf6000000 Size:0x02000000
[0001.263] I> 25) Base:0x40050000 Size:0x00002000
[0001.267] I> 26) Base:0x40040000 Size:0x00006000
[0001.271] I> 27) Base:0xf1800000 Size:0x00400000
[0001.276] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.280] I> 29) Base:0xf1400000 Size:0x00400000
[0001.285] I> 30) Base:0x00000000 Size:0x00000000
[0001.289] I> 31) Base:0x00000000 Size:0x00000000
[0001.294] I> 32) Base:0xf8000000 Size:0x08000000
[0001.298] I> 33) Base:0x00000000 Size:0x00000000
[0001.303] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.307] I> 35) Base:0xab000000 Size:0x01000000
[0001.312] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.316] I> 37) Base:0xf2800000 Size:0x00800000
[0001.321] I> 38) Base:0x80000000 Size:0x20000000
[0001.325] I> 39) Base:0xb0000000 Size:0x08000000
[0001.329] I> 40) Base:0x00000000 Size:0x00000000
[0001.334] I> 41) Base:0x00000000 Size:0x00000000
[0001.338] I> 42) Base:0x00000000 Size:0x00000000
[0001.343] I> 43) Base:0x00000000 Size:0x00000000
[0001.347] I> 44) Base:0x00000000 Size:0x00000000
[0001.352] I> 45) Base:0x00000000 Size:0x00000000
[0001.356] GIC-SPI Target CPU: 0
[0001.359] Interrupts Init done
[0001.362] calling constructors
[0001.365] initializing heap
[0001.368] I> Heap: [0xa06945e8 ... 0xab000000]
[0001.372] initializing threads
[0001.375] initializing timers
[0001.378] creating bootstrap completion thread
[0001.382] top of bootstrap2()
[0001.385] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.389] initializing platform
[0001.392] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.398] W> device prod register failed
[0001.401] I> Bl_dtb @0xaaf00000
[0001.407] W> "plugin-manager" doesn't exist, creating
[0001.409] W> "ids" doesn't exist, creating
[0001.414] W> "connection" doesn't exist, creating
[0001.418] W> "configs" doesn't exist, creating
[0001.429] I> Find /i2c@3160000's alias i2c0
[0001.429] I> Reading eeprom i2c=0 address=0x50
[0001.456] I> Device at /i2c@3160000:0x50
[0001.456] I> Reading eeprom i2c=0 address=0x57
[0001.481] I> Device at /i2c@3160000:0x57
[0001.482] I> Find /i2c@c240000's alias i2c1
[0001.482] I> Reading eeprom i2c=1 address=0x50
[0001.484] E> I2C: slave not found in slaves.
[0001.484] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.485] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.486] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.495] E> eeprom: Retry to read I2C slave device.
[0001.500] E> I2C: slave not found in slaves.
[0001.504] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.511] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.517] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.526] E> eeprom: Failed to read I2C slave device
[0001.531] I> Eeprom read failed 0x3526070d
[0001.535] I> create_pm_ids: id: 3668-0000-200-H, len: 15
[0001.540] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.551] I> create_pm_ids: id: 3509-0000-100-F, len: 15
[0001.557] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.568] I> Adding plugin-manager/ids/3668-0000-200=/i2c@3160000:module@0x50
[0001.575] W> "i2c@3160000" doesn't exist, creating
[0001.579] W> "module@0x50" doesn't exist, creating
[0001.584] I> Adding plugin-manager/ids/3509-0000-100=/i2c@3160000:module@0x57
[0001.591] W> "module@0x57" doesn't exist, creating
[0001.597] I> Adding plugin-manager/cvm
[0001.599] W> "chip-id" doesn't exist, creating
[0001.603] I> Adding plugin-manager/chip-id/A02P
[0001.608] I> Plugin-manager override starting
[0001.613] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.622] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.627] I> node /plugin-manager/fragement-tegra-sdhci-emmc-dis matches
[0001.633] I> Disable plugin-manager status in FDT
[0001.635] I> Plugin-manager override finished successfully
[0001.640] I> gpio framework initialized
[0001.644] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.652] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.659] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.665] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.673] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.680] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.686] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.693] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.701] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.708] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.715] I> fixed regulator driver initialized
[0001.722] I> register 'maxim' power off handle
[0001.723] I> virtual i2c enabled
[0001.726] I> registered 'maxim,max20024' pmic
[0001.730] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.737] I> Boot-device: QSPI
[0001.740] I> Boot_device: QSPI_FLASH instance: 0
[0001.745] I> QSPI source rate = 204000 Khz
[0001.748] I> Requested rate for QSPI clock = 34000 Khz
[0001.753] I> BPMP-set rate for QSPI clk = 34000 Khz
[0001.758] I> QSPI Flash Size = 32 MB
[0001.766] I> Qspi initialized successfully
[0001.766] I> qspi flash-0 params source = boot args
[0001.770] I> create_pm_ids: id: 3668-0000-200-H, len: 15
[0001.775] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.786] I> create_pm_ids: id: 3509-0000-100-F, len: 15
[0001.791] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.803] I> Found sdcard
[0001.807] I> enabling 'vdd-sdmmc1-sw' regulator
[0001.813] I> regulator 'vdd-sdmmc1-sw' already enabled
[0001.967] I> -0 params source =
[0001.969] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.063] I> Found 11 partitions in SDCARD (instance 0)
[0002.070] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.074] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.074] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.075] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.078] E> invalid display type
[0002.079] E> cannot find any other nvdisp nodes
[0002.079] E> no valid display unit config found in dtb
[0002.082] W> display init failed
[0002.084] I> Load in CBoot Boot Options partition and parse it
[0002.090] E> Error -9 when finding node with path /boot-configuration
[0002.096] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.103] I> Using default boot order
[0002.106] I> boot-dev-order :-
[0002.109] I> 1.sd
[0002.111] I> 2.usb
[0002.113] I> 3.nvme
[0002.115] I> 4.emmc
[0002.117] I> 5.net
[0002.119] I> Hit any key to stop autoboot: 4 3 2 1
[0004.126] initializing target
[0004.126] calling apps_init()
[0004.127] starting app kernel_boot_app
[0004.133] I> found decompressor handler: lz4-legacy
[0004.133] I> decompressing BMP blob ...
[0004.137] I> Kernel type = Normal
[0004.137] I> Loading kernel-bootctrl from partition
[0004.137] I> Loading partition kernel-bootctrl at 0xa42c0000 from device(0x6)
[0005.512] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0005.513] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0005.513] I> ########## SD (0) boot ##########
[0005.514] I> Found sdcard
[0005.515] I> regulator 'vdd-sdmmc1-sw' already enabled
[0005.519] I> regulator 'vdd-sdmmc1-sw' already enabled
[0005.560] I> -0 params source =
[0005.560] I> Already published: 00060000
[0005.561] I> Look for boot partition
[0005.561] I> Fallback: assuming 0th partition is boot partition
[0005.561] I> Detect filesystem
[0005.688] I> Loading extlinux.conf ...
[0005.688] I> rootfs path: /sd/boot/extlinux/extlinux.conf
[0005.858] I> L4T boot options
[0005.858] I> [1]: "primary kernel"
[0005.859] I> Enter choice:
[0008.860] I> Continuing with default option: 1
[0008.860] I> Loading kernel sig file from rootfs ...
[0008.860] I> rootfs path: /sd/boot/Image.sig
[0008.933] I> Loading kernel binary from rootfs ...
[0008.934] I> rootfs path: /sd/boot/Image
[0188.285] I> Validate kernel ...
[0188.286] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0188.600] E> digest on binary did not match!!
[0188.600] C> OEM authentication of kernel payload failed!
[0188.601] W> Failed to validate kernel binary (err=1077936152, fail=0)
[0188.601] W> Security fuse not burned, ignore validation failure
[0188.613] I> No kernel-dtb binary path
[0188.613] I> A/B: bin_type (38) slot 0
[0188.614] I> Loading kernel-dtb from partition
[0188.614] I> Loading partition kernel-dtb at 0x91000000 from device(0x6)
[0191.018] I> Validate kernel-dtb ...
[0191.018] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0191.021] I> Encryption fuse is not ON
[0191.022] I> Loading ramdisk from rootfs ...
[0191.022] I> Loading initrd sig file from rootfs ...
[0191.022] I> rootfs path: /sd/boot/initrd.sig
[0191.095] I> Loading initrd binary from rootfs ...
[0191.096] I> rootfs path: /sd/boot/initrd
[0229.025] I> overload load_size to 7238344 (from 7238352)
[0229.028] I> Validate initrd ...
[0229.028] I> T19x: Authenticate initrd (bin_type: 49), max size 0x4000000
[0229.094] I> Encryption fuse is not ON
[0229.108] I> Kernel hdr @0xa42c0000
[0229.108] I> Kernel dtb @0x90000000
[0229.108] I> decompressor handler not found
[0229.109] I> Copying kernel image (34271240 bytes) from 0xa42c0000 to 0x80080000 ... [0229.119] I> Done
[0229.120] I> Updated bpmp info to DTB
[0229.121] I> Ramdisk: Base: 0x92000000; Size: 0x6e72c8
[0229.121] I> Updated initrd info to DTB
[0229.122] W> WARN: Fail to override "console=none" in commandline
[0229.122] I> Active rootfs suffix:
[0229.124] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0229.131] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0229.139] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0229.146] I> Active slot suffix:
[0229.149] I> add_boot_slot_suffix: slot_suffix =
[0229.154] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0229.180] I> Updated bootarg info to DTB
[0229.184] W> MAC addr invalid!
[0229.186] E> Failed to get WIFI MAC address
[0229.190] W> MAC addr invalid!
[0229.193] E> Failed to get Bluetooth MAC address
[0229.198] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:07:88:0d
[0229.204] W> "plugin-manager" doesn't exist, creating
[0229.209] I> Adding /chosen/plugin-manager/cvm
[0229.213] W> "chip-id" doesn't exist, creating
[0229.217] I> Adding /chosen/plugin-manager/chip-id
[0229.222] W> "configs" doesn't exist, creating
[0229.226] I> Adding /chosen/plugin-manager/configs
[0229.231] W> "ids" doesn't exist, creating
[0229.235] I> Adding /chosen/plugin-manager/ids
[0229.239] W> "odm-data" doesn't exist, creating
[0229.244] I> Adding /chosen/plugin-manager/odm-data
[0229.251] W> "memory" doesn't exist, creating
[0229.253] I> [0] START: 0x80000000, END: 0xac000000
[0229.257] I> [1] START: 0xac004000, END: 0xf0ad0000
[0229.262] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0229.267] I> dram_block larger than 80000000
[0229.271] I> [3] START: 0x100000000, END: 0x280000000
[0229.276] I> added [base:0x80000000, size:0x2c000000] to /memory
[0229.281] I> added [base:0xac200000, size:0x44800000] to /memory
[0229.287] I> added [base:0x100000000, size:0x180000000] to /memory
[0229.294] I> Updated memory info to DTB
[0229.297] E> add_disp_param: failed to get display params for du=0
[0229.303] W> "reset" doesn't exist, creating
[0229.308] I> Adding ecid(00000001645df4441800000015ff8200) to DT
[0229.313] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0229.318] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0229.322] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0229.327] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0229.332] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0229.337] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0229.341] I> Deleted cpu@6 node in DT
[0229.345] I> Deleted cpu@7 node in DT
[0229.349] I> Deleted cluster3 node in FDT
[0229.352] I> Update arm-pmu in FDT
[0229.355] I> - update property: interrupts
[0229.359] I> - update property: interrupt-affinity
[0229.365] W> "misc-data" doesn't exist, creating
[0229.369] I> Boot-device: QSPI
[0229.371] W> Unknown boot device
[0229.374] I> Add storage-qspi to plugin-manager/misc-data
[0229.380] W> Unknown storage device
[0229.383] I> Add serial number:1421520055788 as DT property
[0229.389] I> Plugin-manager override starting
[0229.393] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0229.400] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0229.406] I> node /plugin-manager/fragement-tegra-sdhci-emmc-dis matches
[0229.413] I> Disable plugin-manager status in FDT
[0229.415] I> Plugin-manager override finished successfully
[0229.421] I> tegrabl_load_kernel_and_dtb: Done
