Hi Aintmarks,
Currently, we are able to reduce gpu clocks from ~38 secs to ~14 secs which is a good sign and will continue to investigate for further improvements.
I also tested on notebook having Alienware 17 R5 with driver 418.74 and reg key enabled on terminal, it took 14 secs to ramp down clocks.
Below is the o/p for reference.
oemqa@dbian:~$ grep GL_ExperimentalPerfStrategy /etc/environment ; echo $__GL_ExperimentalPerfStrategy ; while true ; do nvidia-smi dmon -c 1 ; timeout 3 glxgears ; for i in $(seq 1 50) ; do nvidia-smi dmon -c 1 ; sleep 1 ; done ; done
1
gpu pwr gtemp mtemp sm mem enc dec mclk pclk
Idx W C C % % % % MHz MHz
0 9 47 - 0 9 0 0 405 139
Running synchronized to the vertical refresh. The framerate should be
approximately the same as the monitor refresh rate.
0 40 48 - 11 2 0 0 4006 1442
0 34 48 - 0 1 0 0 4006 949
0 35 48 - 0 1 0 0 4006 949
0 34 48 - 0 1 0 0 3802 949
0 34 49 - 0 1 0 0 3802 949
0 28 49 - 0 1 0 0 2999 822
0 13 49 - 0 4 0 0 810 822
0 13 48 - 0 4 0 0 810 822
0 9 48 - 0 9 0 0 405 189
0 9 48 - 1 9 0 0 405 139
0 9 48 - 0 9 0 0 405 139
^C
oemqa@dbian:~$
Can you please perform below steps precisely -
- Boot up system and make sure there are no applications running.
- Open a terminal and verify output of command echo $__GL_ExperimentalPerfStrategy. It should result 1.
- Execute below command to verify secs to ramp down gpu clocks.
If you will open/close applications continuously, it will take time to ramp down clocks.
Please make sure to reopen and close app after a pause of 45-50 secs to notice change
