VGPU-KVM and CUDA Driver Version mismatch
When I install NVIDIA-Linux-x86_64-535.54.06-vgpu-kvm.run, cuda is not available anymore and it complains about driver version mismatch.
So which CUDA package I have to install with VGPU KVM driver?
In all you documentation there is no clear statement about that. Maybe you add that to documentation, after you found out.
Following: CUDA Compatibility :: NVIDIA Data Center GPU Driver Documentation you need CUDA 12.2
Guess you never tried that by yourself.
| NVIDIA-SMI 535.54.06 Driver Version: 535.54.06 CUDA Version: N/A |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 Tesla P40 Off | 00000000:0A:00.0 Off | Off |
| N/A 36C P0 46W / 250W | 0MiB / 24576MiB | 1% Default |
| | | N/A |
Tried 12.2 and 12.2.1
CUDA is always N/A with VGPU KVM driver.
What exactly are you going to achieve?
Why do you expect CUDA with the host driver? For a VM you should install the guest driver:
NVIDIA-Linux-x86_64-535.54.03-grid.run
This is only for KVM VMs with mdev device(s).
Yes this works as expected.
But I want to run CUDA on host and in containers (lxc/docker) too.
And containers for sure use the kernel module from the host, so it is also impossible to use cuda in containers with the vgpu KVM driver.
