VI Timeout when capturing from multiple synchronous sensors
I’m trying to capture from three sensors at the same time on a TX2. My current setup has sensor have the particularity that there’s one master sensor and two slave sensor were using a broadcasted i2c command; the master sensor will start the stream for the two slave sensors. So for instance when using a pipeline like the following:
GST_DEBUG=2 DISPLAY=:0 gst-launch-1.0 nvcamerasrc exposure-time=0.006 fpsRange="30 30" auto-exposure=off sensor-id=2 !  'video/x-raw(memory:NVMM),width=(int)4656,height=(int)3496,format=(string)I420,framerate=(fraction)21/1' ! nvvidconv ! "video/x-raw,width=(int)640,height=(int)480,format=(string)I420,framerate=(fraction)21/1"  ! queue !  mixer.sink_0  nvcamerasrc  auto-exposure=off exposure-time=0.006  sensor-id=1 fpsRange="30 30" !  'video/x-raw(memory:NVMM),width=(int)4656,height=(int)3496,format=(string)I420,framerate=(fraction)21/1' ! nvvidconv ! "video/x-raw,width=(int)640,height=(int)480,format=(string)I420,framerate=(fraction)21/1"  ! queue ! mixer.sink_1 nvcamerasrc auto-exposure=off exposure-time=0.006 sensor-id=0 fpsRange="30 30" ! 'video/x-raw(memory:NVMM),width=(int)4656,height=(int)3496,format=(string)I420,framerate=(fraction)21/1' ! nvvidconv !  "video/x-raw,width=(int)640,height=(int)480,format=(string)I420,framerate=(fraction)21/1" ! queue ! mixer.sink_2 videomixer background=1 name=mixer sink_0::xpos=0 sink_0::ypos=0  sink_1::xpos=640 sink_1::ypos=0 sink_2::xpos=320 sink_2::ypos=480 ! queue ! nvoverlaysink sync=false -v
The driver of the sensor with the id 0 then will sent the command to all the sensors; this involves that the cameras should start in the order 1->2 for the slaves, and finally sensor 0 to broadcast the start stream.
This seems to be working well but in some occasions I get the following timeout and the capture subsystem (nvcamera-daemon) crashes:
[  232.517597] fence timeout on [ffffffc04a34f900] after 1500ms
[  232.521233] fence timeout on [ffffffc050530800] after 1500ms
[  232.521243] name=[nvhost_sync:86], current value=12 waiting value=13
[  232.521249] ---- mlocks ----
[  232.521273] 17: locked by channel 8
[  232.521284] ---- syncpts ----
[  232.521298] id 4 (disp_d) min 111 max 111 refs 1 (previous client : )
[  232.521305] id 5 (disp_e) min 443 max 444 refs 1 (previous client : )
[  232.521312] id 7 (vblank1) min 13723 max 0 refs 1 (previous client : )
[  232.521331] id 18 (17000000.gp10b_507) min 7392 max 7392 refs 1 (previous client : )
I tried increasing the clock speeds recommended on the following post but am still experiencing the issue:
https://devtalk.nvidia.com/default/topic/1038000/jetson-tx2/vi-errors-when-running-two-mipi-cameras/
We checked the CSI lines and it seems like data is indeed getting out of each sensor when the timeout happens; so my rough guess is that there is a timeout that gets triggered once the data takes a bit longer to come out of the sensor and this crashes the capture subsystem. I have the following questions:
1- Has anybody tried to accomplish this on the past and succeed at it?
2- Any pointers to where we could increase the potential timeout that is happening?
Thanks in advance.
hello josejich,
  1. may I know which JetPack release you’re working on?
  2. are these sensor can configure to execute individually to verify the driver works well.
  3. could you also enable tracing logs from debugfs as below to gather more details.
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
Thanks for you reply, The following is a log obtained when the capture fails
root@tegra-ubuntu:/home/nvidia# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 6376/6376   #P:4
#                              _-----=> irqs-off
#                             / _----=> need-resched
#                            | / _---=> hardirq/softirq
#                            || / _--=> preempt-depth
#                            ||| /     delay
#           TASK-PID   CPU#  ||||    TIMESTAMP  FUNCTION
     kworker/0:0-4     [000] ...1   114.510440: rtos_queue_peek_from_isr_failed: tstamp:3925192479 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   114.510444: rtcpu_start: tstamp:3925193202
     kworker/0:0-4     [000] ...1   114.562443: rtos_queue_peek_from_isr_failed: tstamp:3927019012 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   114.562446: rtos_queue_peek_from_isr_failed: tstamp:3927153378 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   114.562447: rtcpu_start: tstamp:3927154130
     kworker/0:0-4     [000] ...1   114.666449: rtos_queue_peek_from_isr_failed: tstamp:3930176074 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   114.666452: rtos_queue_peek_from_isr_failed: tstamp:3930207968 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   114.666453: rtcpu_start: tstamp:3930208691
     kworker/0:0-4     [000] ...1   115.102893: rtos_queue_peek_from_isr_failed: tstamp:3935208833 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   115.102897: rtos_queue_peek_from_isr_failed: tstamp:3940209317 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   115.154457: rtos_queue_peek_from_isr_failed: tstamp:3945209815 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   115.322454: rtos_queue_peek_from_isr_failed: tstamp:3950210338 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   115.474464: rtos_queue_peek_from_isr_failed: tstamp:3955210847 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   115.630495: rtos_queue_peek_from_isr_failed: tstamp:3960211333 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   115.786522: rtos_queue_peek_from_isr_failed: tstamp:3965211851 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   115.942493: rtos_queue_peek_from_isr_failed: tstamp:3970212346 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   116.102481: rtos_queue_peek_from_isr_failed: tstamp:3975212854 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   116.258569: rtos_queue_peek_from_isr_failed: tstamp:3980213369 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   116.362472: rtcpu_vinotify_handle_msg: tstamp:3983866410 tag:ATOMP_FS channel:0x02 frame:9 vi_tstamp:3983865989 data:0x00000000
     kworker/0:0-4     [000] ...1   116.362476: rtcpu_vinotify_handle_msg: tstamp:3983874093 tag:CHANSEL_PXL_SOF channel:0x02 frame:9 vi_tstamp:3983873689 data:0x00000001
     kworker/0:0-4     [000] ...1   116.362476: rtcpu_vinotify_handle_msg: tstamp:3983874559 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:9 vi_tstamp:3983874215 data:0x28000000
     kworker/0:0-4     [000] ...1   116.414484: rtcpu_vinotify_handle_msg: tstamp:3984403075 tag:ATOMP_FS channel:0x00 frame:9 vi_tstamp:3984402666 data:0x00000000
     kworker/0:0-4     [000] ...1   116.414488: rtcpu_vinotify_handle_msg: tstamp:3984410768 tag:CHANSEL_PXL_SOF channel:0x00 frame:9 vi_tstamp:3984410366 data:0x00000001
     kworker/0:0-4     [000] ...1   116.414489: rtcpu_vinotify_handle_msg: tstamp:3984411239 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:9 vi_tstamp:3984410890 data:0x08000000
     kworker/0:0-4     [000] ...1   116.414490: rtcpu_vinotify_handle_msg: tstamp:3984882068 tag:CHANSEL_PXL_EOF channel:0x02 frame:9 vi_tstamp:3984881659 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.414491: rtcpu_vinotify_handle_msg: tstamp:3984882634 tag:ATOMP_FE channel:0x02 frame:9 vi_tstamp:3984882217 data:0x00000000
     kworker/0:0-4     [000] ...1   116.414491: rtcpu_vinotify_handle_msg: tstamp:3984906706 tag:ATOMP_FS channel:0x02 frame:10 vi_tstamp:3984906297 data:0x00000000
     kworker/0:0-4     [000] ...1   116.414492: rtcpu_vinotify_handle_msg: tstamp:3984914399 tag:CHANSEL_PXL_SOF channel:0x02 frame:10 vi_tstamp:3984913997 data:0x00000001
     kworker/0:0-4     [000] ...1   116.414493: rtcpu_vinotify_handle_msg: tstamp:3984914969 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:10 vi_tstamp:3984914541 data:0x28000000
     kworker/0:0-4     [000] ...1   116.414495: rtos_queue_peek_from_isr_failed: tstamp:3985213868 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   116.414497: rtcpu_vinotify_handle_msg: tstamp:3985418735 tag:CHANSEL_PXL_EOF channel:0x00 frame:9 vi_tstamp:3985418335 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.414497: rtcpu_vinotify_handle_msg: tstamp:3985419298 tag:ATOMP_FE channel:0x00 frame:9 vi_tstamp:3985418893 data:0x00000000
     kworker/0:0-4     [000] ...1   116.414498: rtcpu_vinotify_handle_msg: tstamp:3985443382 tag:ATOMP_FS channel:0x00 frame:10 vi_tstamp:3985442974 data:0x00000000
     kworker/0:0-4     [000] ...1   116.414499: rtcpu_vinotify_handle_msg: tstamp:3985451074 tag:CHANSEL_PXL_SOF channel:0x00 frame:10 vi_tstamp:3985450674 data:0x00000001
     kworker/0:0-4     [000] ...1   116.414500: rtcpu_vinotify_handle_msg: tstamp:3985451633 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:10 vi_tstamp:3985451209 data:0x08000000
     kworker/0:0-4     [000] ...1   116.414501: rtcpu_vinotify_handle_msg: tstamp:3985922378 tag:CHANSEL_PXL_EOF channel:0x02 frame:10 vi_tstamp:3985921966 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.414502: rtcpu_vinotify_handle_msg: tstamp:3985922944 tag:ATOMP_FE channel:0x02 frame:10 vi_tstamp:3985922525 data:0x00000000
     kworker/0:0-4     [000] ...1   116.414503: rtcpu_vinotify_handle_msg: tstamp:3985947011 tag:ATOMP_FS channel:0x02 frame:11 vi_tstamp:3985946605 data:0x00000000
     kworker/0:0-4     [000] ...1   116.414504: rtcpu_vinotify_handle_msg: tstamp:3985954705 tag:CHANSEL_PXL_SOF channel:0x02 frame:11 vi_tstamp:3985954306 data:0x00000001
     kworker/0:0-4     [000] ...1   116.414505: rtcpu_vinotify_handle_msg: tstamp:3985955285 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:11 vi_tstamp:3985954840 data:0x28000000
     kworker/0:0-4     [000] ...1   116.466486: rtcpu_vinotify_handle_msg: tstamp:3986459053 tag:CHANSEL_PXL_EOF channel:0x00 frame:10 vi_tstamp:3986458643 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.466490: rtcpu_vinotify_handle_msg: tstamp:3986459620 tag:ATOMP_FE channel:0x00 frame:10 vi_tstamp:3986459201 data:0x00000000
     kworker/0:0-4     [000] ...1   116.466490: rtcpu_vinotify_handle_msg: tstamp:3986483691 tag:ATOMP_FS channel:0x00 frame:11 vi_tstamp:3986483283 data:0x00000000
     kworker/0:0-4     [000] ...1   116.466491: rtcpu_vinotify_handle_msg: tstamp:3986491383 tag:CHANSEL_PXL_SOF channel:0x00 frame:11 vi_tstamp:3986490982 data:0x00000001
     kworker/0:0-4     [000] ...1   116.466492: rtcpu_vinotify_handle_msg: tstamp:3986491945 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:11 vi_tstamp:3986491518 data:0x08000000
     kworker/0:0-4     [000] ...1   116.466493: rtcpu_vinotify_handle_msg: tstamp:3986962684 tag:CHANSEL_PXL_EOF channel:0x02 frame:11 vi_tstamp:3986962274 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.466494: rtcpu_vinotify_handle_msg: tstamp:3986963251 tag:ATOMP_FE channel:0x02 frame:11 vi_tstamp:3986962833 data:0x00000000
     kworker/0:0-4     [000] ...1   116.466494: rtcpu_vinotify_handle_msg: tstamp:3986987335 tag:ATOMP_FS channel:0x02 frame:12 vi_tstamp:3986986914 data:0x00000000
     kworker/0:0-4     [000] ...1   116.466495: rtcpu_vinotify_handle_msg: tstamp:3986995013 tag:CHANSEL_PXL_SOF channel:0x02 frame:12 vi_tstamp:3986994613 data:0x00000001
     kworker/0:0-4     [000] ...1   116.466496: rtcpu_vinotify_handle_msg: tstamp:3986995574 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:12 vi_tstamp:3986995152 data:0x28000000
     kworker/0:0-4     [000] ...1   116.466497: rtcpu_vinotify_handle_msg: tstamp:3987499362 tag:CHANSEL_PXL_EOF channel:0x00 frame:11 vi_tstamp:3987498951 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.466498: rtcpu_vinotify_handle_msg: tstamp:3987499930 tag:ATOMP_FE channel:0x00 frame:11 vi_tstamp:3987499510 data:0x00000000
     kworker/0:0-4     [000] ...1   116.466498: rtcpu_vinotify_handle_msg: tstamp:3987524002 tag:ATOMP_FS channel:0x00 frame:12 vi_tstamp:3987523590 data:0x00000000
     kworker/0:0-4     [000] ...1   116.466499: rtcpu_vinotify_handle_msg: tstamp:3987531696 tag:CHANSEL_PXL_SOF channel:0x00 frame:12 vi_tstamp:3987531291 data:0x00000001
     kworker/0:0-4     [000] ...1   116.466500: rtcpu_vinotify_handle_msg: tstamp:3987532261 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:12 vi_tstamp:3987531834 data:0x08000000
     kworker/0:0-4     [000] ...1   116.518486: rtcpu_vinotify_handle_msg: tstamp:3988002990 tag:CHANSEL_PXL_EOF channel:0x02 frame:12 vi_tstamp:3988002582 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.518489: rtcpu_vinotify_handle_msg: tstamp:3988003557 tag:ATOMP_FE channel:0x02 frame:12 vi_tstamp:3988003141 data:0x00000000
     kworker/0:0-4     [000] ...1   116.518489: rtcpu_vinotify_handle_msg: tstamp:3988027630 tag:ATOMP_FS channel:0x02 frame:13 vi_tstamp:3988027222 data:0x00000000
     kworker/0:0-4     [000] ...1   116.518490: rtcpu_vinotify_handle_msg: tstamp:3988035327 tag:CHANSEL_PXL_SOF channel:0x02 frame:13 vi_tstamp:3988034922 data:0x00000001
     kworker/0:0-4     [000] ...1   116.518491: rtcpu_vinotify_handle_msg: tstamp:3988035903 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:13 vi_tstamp:3988035475 data:0x28000000
     kworker/0:0-4     [000] ...1   116.518492: rtcpu_vinotify_handle_msg: tstamp:3988539670 tag:CHANSEL_PXL_EOF channel:0x00 frame:12 vi_tstamp:3988539260 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.518492: rtcpu_vinotify_handle_msg: tstamp:3988540235 tag:ATOMP_FE channel:0x00 frame:12 vi_tstamp:3988539818 data:0x00000000
     kworker/0:0-4     [000] ...1   116.518493: rtcpu_vinotify_handle_msg: tstamp:3988564308 tag:ATOMP_FS channel:0x00 frame:13 vi_tstamp:3988563898 data:0x00000000
     kworker/0:0-4     [000] ...1   116.518494: rtcpu_vinotify_handle_msg: tstamp:3988572000 tag:CHANSEL_PXL_SOF channel:0x00 frame:13 vi_tstamp:3988571599 data:0x00000001
     kworker/0:0-4     [000] ...1   116.518495: rtcpu_vinotify_handle_msg: tstamp:3988572564 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:13 vi_tstamp:3988572136 data:0x08000000
     kworker/0:0-4     [000] ...1   116.518496: rtcpu_vinotify_handle_msg: tstamp:3989015774 tag:ATOMP_FS channel:0x01 frame:9 vi_tstamp:3989015360 data:0x00000000
     kworker/0:0-4     [000] ...1   116.518496: rtcpu_vinotify_handle_msg: tstamp:3989023463 tag:CHANSEL_PXL_SOF channel:0x01 frame:9 vi_tstamp:3989023061 data:0x00000001
     kworker/0:0-4     [000] ...1   116.518497: rtcpu_vinotify_handle_msg: tstamp:3989024040 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:9 vi_tstamp:3989023612 data:0x18000000
     kworker/0:0-4     [000] ...1   116.518498: rtcpu_vinotify_handle_msg: tstamp:3989043293 tag:CHANSEL_PXL_EOF channel:0x02 frame:13 vi_tstamp:3989042891 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.518499: rtcpu_vinotify_handle_msg: tstamp:3989043853 tag:ATOMP_FE channel:0x02 frame:13 vi_tstamp:3989043449 data:0x00000000
     kworker/0:0-4     [000] ...1   116.518499: rtcpu_vinotify_handle_msg: tstamp:3989067935 tag:ATOMP_FS channel:0x02 frame:14 vi_tstamp:3989067530 data:0x00000000
     kworker/0:0-4     [000] ...1   116.518500: rtcpu_vinotify_handle_msg: tstamp:3989075633 tag:CHANSEL_PXL_SOF channel:0x02 frame:14 vi_tstamp:3989075230 data:0x00000001
     kworker/0:0-4     [000] ...1   116.518501: rtcpu_vinotify_handle_msg: tstamp:3989076196 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:14 vi_tstamp:3989075770 data:0x28000000
     kworker/0:0-4     [000] ...1   116.570479: rtcpu_vinotify_handle_msg: tstamp:3989579978 tag:CHANSEL_PXL_EOF channel:0x00 frame:13 vi_tstamp:3989579568 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.570483: rtcpu_vinotify_handle_msg: tstamp:3989580543 tag:ATOMP_FE channel:0x00 frame:13 vi_tstamp:3989580126 data:0x00000000
     kworker/0:0-4     [000] ...1   116.570485: rtcpu_vinotify_handle_msg: tstamp:3989604613 tag:ATOMP_FS channel:0x00 frame:14 vi_tstamp:3989604206 data:0x00000000
     kworker/0:0-4     [000] ...1   116.570486: rtcpu_vinotify_handle_msg: tstamp:3989612310 tag:CHANSEL_PXL_SOF channel:0x00 frame:14 vi_tstamp:3989611906 data:0x00000001
     kworker/0:0-4     [000] ...1   116.570487: rtcpu_vinotify_handle_msg: tstamp:3989612873 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:14 vi_tstamp:3989612447 data:0x08000000
     kworker/0:0-4     [000] ...1   116.570488: rtcpu_vinotify_handle_msg: tstamp:3990031451 tag:CHANSEL_PXL_EOF channel:0x01 frame:9 vi_tstamp:3990031028 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.570489: rtcpu_vinotify_handle_msg: tstamp:3990032016 tag:ATOMP_FE channel:0x01 frame:9 vi_tstamp:3990031587 data:0x00000000
     kworker/0:0-4     [000] ...1   116.570490: rtcpu_vinotify_handle_msg: tstamp:3990056077 tag:ATOMP_FS channel:0x01 frame:10 vi_tstamp:3990055668 data:0x00000000
     kworker/0:0-4     [000] ...1   116.570491: rtcpu_vinotify_handle_msg: tstamp:3990063769 tag:CHANSEL_PXL_SOF channel:0x01 frame:10 vi_tstamp:3990063368 data:0x00000001
     kworker/0:0-4     [000] ...1   116.570493: rtcpu_vinotify_handle_msg: tstamp:3990064335 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:10 vi_tstamp:3990063908 data:0x18000000
     kworker/0:0-4     [000] ...1   116.570494: rtcpu_vinotify_handle_msg: tstamp:3990083599 tag:CHANSEL_PXL_EOF channel:0x02 frame:14 vi_tstamp:3990083199 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.570495: rtcpu_vinotify_handle_msg: tstamp:3990084193 tag:ATOMP_FE channel:0x02 frame:14 vi_tstamp:3990083757 data:0x00000000
     kworker/0:0-4     [000] ...1   116.570496: rtcpu_vinotify_handle_msg: tstamp:3990108244 tag:ATOMP_FS channel:0x02 frame:15 vi_tstamp:3990107838 data:0x00000000
     kworker/0:0-4     [000] ...1   116.570497: rtcpu_vinotify_handle_msg: tstamp:3990115945 tag:CHANSEL_PXL_SOF channel:0x02 frame:15 vi_tstamp:3990115539 data:0x00000001
     kworker/0:0-4     [000] ...1   116.570498: rtcpu_vinotify_handle_msg: tstamp:3990116508 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:15 vi_tstamp:3990116081 data:0x28000000
     kworker/0:0-4     [000] ...1   116.570501: rtos_queue_peek_from_isr_failed: tstamp:3990214382 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   116.570502: rtcpu_vinotify_handle_msg: tstamp:3990620284 tag:CHANSEL_PXL_EOF channel:0x00 frame:14 vi_tstamp:3990619875 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.570503: rtcpu_vinotify_handle_msg: tstamp:3990620852 tag:ATOMP_FE channel:0x00 frame:14 vi_tstamp:3990620434 data:0x00000000
     kworker/0:0-4     [000] ...1   116.570504: rtcpu_vinotify_handle_msg: tstamp:3990644925 tag:ATOMP_FS channel:0x00 frame:15 vi_tstamp:3990644515 data:0x00000000
     kworker/0:0-4     [000] ...1   116.570505: rtcpu_vinotify_handle_msg: tstamp:3990652618 tag:CHANSEL_PXL_SOF channel:0x00 frame:15 vi_tstamp:3990652214 data:0x00000001
     kworker/0:0-4     [000] ...1   116.570506: rtcpu_vinotify_handle_msg: tstamp:3990653182 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:15 vi_tstamp:3990652755 data:0x08000000
     kworker/0:0-4     [000] ...1   116.622506: rtcpu_vinotify_handle_msg: tstamp:3991071762 tag:CHANSEL_PXL_EOF channel:0x01 frame:10 vi_tstamp:3991071337 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.622510: rtcpu_vinotify_handle_msg: tstamp:3991072329 tag:ATOMP_FE channel:0x01 frame:10 vi_tstamp:3991071895 data:0x00000000
     kworker/0:0-4     [000] ...1   116.622511: rtcpu_vinotify_handle_msg: tstamp:3991096382 tag:ATOMP_FS channel:0x01 frame:11 vi_tstamp:3991095976 data:0x00000000
     kworker/0:0-4     [000] ...1   116.622513: rtcpu_vinotify_handle_msg: tstamp:3991104079 tag:CHANSEL_PXL_SOF channel:0x01 frame:11 vi_tstamp:3991103675 data:0x00000001
     kworker/0:0-4     [000] ...1   116.622514: rtcpu_vinotify_handle_msg: tstamp:3991104645 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:11 vi_tstamp:3991104216 data:0x18000000
     kworker/0:0-4     [000] ...1   116.622515: rtcpu_vinotify_handle_msg: tstamp:3991123908 tag:CHANSEL_PXL_EOF channel:0x02 frame:15 vi_tstamp:3991123507 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.622516: rtcpu_vinotify_handle_msg: tstamp:3991124467 tag:ATOMP_FE channel:0x02 frame:15 vi_tstamp:3991124065 data:0x00000000
     kworker/0:0-4     [000] ...1   116.622517: rtcpu_vinotify_handle_msg: tstamp:3991148558 tag:ATOMP_FS channel:0x02 frame:16 vi_tstamp:3991148147 data:0x00000000
     kworker/0:0-4     [000] ...1   116.622519: rtcpu_vinotify_handle_msg: tstamp:3991156250 tag:CHANSEL_PXL_SOF channel:0x02 frame:16 vi_tstamp:3991155847 data:0x00000001
     kworker/0:0-4     [000] ...1   116.622520: rtcpu_vinotify_handle_msg: tstamp:3991156815 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:16 vi_tstamp:3991156388 data:0x28000000
     kworker/0:0-4     [000] ...1   116.622521: rtcpu_vinotify_handle_msg: tstamp:3991660593 tag:CHANSEL_PXL_EOF channel:0x00 frame:15 vi_tstamp:3991660183 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.622522: rtcpu_vinotify_handle_msg: tstamp:3991661157 tag:ATOMP_FE channel:0x00 frame:15 vi_tstamp:3991660742 data:0x00000000
     kworker/0:0-4     [000] ...1   116.622523: rtcpu_vinotify_handle_msg: tstamp:3991685228 tag:ATOMP_FS channel:0x00 frame:16 vi_tstamp:3991684823 data:0x00000000
     kworker/0:0-4     [000] ...1   116.622524: rtcpu_vinotify_handle_msg: tstamp:3991692926 tag:CHANSEL_PXL_SOF channel:0x00 frame:16 vi_tstamp:3991692524 data:0x00000001
     kworker/0:0-4     [000] ...1   116.622525: rtcpu_vinotify_handle_msg: tstamp:3991693491 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:16 vi_tstamp:3991693063 data:0x08000000
     kworker/0:0-4     [000] ...1   116.622526: rtcpu_vinotify_handle_msg: tstamp:3992112048 tag:CHANSEL_PXL_EOF channel:0x01 frame:11 vi_tstamp:3992111645 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.622527: rtcpu_vinotify_handle_msg: tstamp:3992112612 tag:ATOMP_FE channel:0x01 frame:11 vi_tstamp:3992112203 data:0x00000000
     kworker/0:0-4     [000] ...1   116.622528: rtcpu_vinotify_handle_msg: tstamp:3992136686 tag:ATOMP_FS channel:0x01 frame:12 vi_tstamp:3992136284 data:0x00000000
     kworker/0:0-4     [000] ...1   116.622529: rtcpu_vinotify_handle_msg: tstamp:3992144383 tag:CHANSEL_PXL_SOF channel:0x01 frame:12 vi_tstamp:3992143984 data:0x00000001
     kworker/0:0-4     [000] ...1   116.622530: rtcpu_vinotify_handle_msg: tstamp:3992144945 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:12 vi_tstamp:3992144521 data:0x18000000
     kworker/0:0-4     [000] ...1   116.622531: rtcpu_vinotify_handle_msg: tstamp:3992164215 tag:CHANSEL_PXL_EOF channel:0x02 frame:16 vi_tstamp:3992163815 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.622532: rtcpu_vinotify_handle_msg: tstamp:3992164770 tag:ATOMP_FE channel:0x02 frame:16 vi_tstamp:3992164374 data:0x00000000
     kworker/0:0-4     [000] ...1   116.622535: rtcpu_vinotify_handle_msg: tstamp:3992188864 tag:ATOMP_FS channel:0x02 frame:17 vi_tstamp:3992188455 data:0x00000000
     kworker/0:0-4     [000] ...1   116.622537: rtcpu_vinotify_handle_msg: tstamp:3992196558 tag:CHANSEL_PXL_SOF channel:0x02 frame:17 vi_tstamp:3992196155 data:0x00000001
     kworker/0:0-4     [000] ...1   116.622538: rtcpu_vinotify_handle_msg: tstamp:3992197118 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:17 vi_tstamp:3992196694 data:0x28000000
     kworker/0:0-4     [000] ...1   116.674532: rtcpu_vinotify_handle_msg: tstamp:3992700899 tag:CHANSEL_PXL_EOF channel:0x00 frame:16 vi_tstamp:3992700492 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.674538: rtcpu_vinotify_handle_msg: tstamp:3992701462 tag:ATOMP_FE channel:0x00 frame:16 vi_tstamp:3992701051 data:0x00000000
     kworker/0:0-4     [000] ...1   116.674539: rtcpu_vinotify_handle_msg: tstamp:3992725539 tag:ATOMP_FS channel:0x00 frame:17 vi_tstamp:3992725131 data:0x00000000
     kworker/0:0-4     [000] ...1   116.674541: rtcpu_vinotify_handle_msg: tstamp:3992733230 tag:CHANSEL_PXL_SOF channel:0x00 frame:17 vi_tstamp:3992732831 data:0x00000001
     kworker/0:0-4     [000] ...1   116.674543: rtcpu_vinotify_handle_msg: tstamp:3992733792 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:17 vi_tstamp:3992733368 data:0x08000000
     kworker/0:0-4     [000] ...1   116.674545: rtcpu_vinotify_handle_msg: tstamp:3993152359 tag:CHANSEL_PXL_EOF channel:0x01 frame:12 vi_tstamp:3993151953 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.674547: rtcpu_vinotify_handle_msg: tstamp:3993152924 tag:ATOMP_FE channel:0x01 frame:12 vi_tstamp:3993152511 data:0x00000000
     kworker/0:0-4     [000] ...1   116.674548: rtcpu_vinotify_handle_msg: tstamp:3993177005 tag:ATOMP_FS channel:0x01 frame:13 vi_tstamp:3993176593 data:0x00000000
     kworker/0:0-4     [000] ...1   116.674550: rtcpu_vinotify_handle_msg: tstamp:3993184697 tag:CHANSEL_PXL_SOF channel:0x01 frame:13 vi_tstamp:3993184291 data:0x00000001
     kworker/0:0-4     [000] ...1   116.674552: rtcpu_vinotify_handle_msg: tstamp:3993185264 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:13 vi_tstamp:3993184835 data:0x18000000
     kworker/0:0-4     [000] ...1   116.674554: rtcpu_vinotify_handle_msg: tstamp:3993204525 tag:CHANSEL_PXL_EOF channel:0x02 frame:17 vi_tstamp:3993204123 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.674556: rtcpu_vinotify_handle_msg: tstamp:3993205081 tag:ATOMP_FE channel:0x02 frame:17 vi_tstamp:3993204682 data:0x00000000
     kworker/0:0-4     [000] ...1   116.674558: rtcpu_vinotify_handle_msg: tstamp:3993229177 tag:ATOMP_FS channel:0x02 frame:18 vi_tstamp:3993228762 data:0x00000000
     kworker/0:0-4     [000] ...1   116.674559: rtcpu_vinotify_handle_msg: tstamp:3993236868 tag:CHANSEL_PXL_SOF channel:0x02 frame:18 vi_tstamp:3993236462 data:0x00000001
     kworker/0:0-4     [000] ...1   116.674561: rtcpu_vinotify_handle_msg: tstamp:3993237441 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:18 vi_tstamp:3993237006 data:0x28000000
     kworker/0:0-4     [000] ...1   116.674563: rtcpu_vinotify_handle_msg: tstamp:3993741224 tag:CHANSEL_PXL_EOF channel:0x00 frame:17 vi_tstamp:3993740800 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.674565: rtcpu_vinotify_handle_msg: tstamp:3993741786 tag:ATOMP_FE channel:0x00 frame:17 vi_tstamp:3993741359 data:0x00000000
     kworker/0:0-4     [000] ...1   116.674567: rtcpu_vinotify_handle_msg: tstamp:3993765845 tag:ATOMP_FS channel:0x00 frame:18 vi_tstamp:3993765439 data:0x00000000
     kworker/0:0-4     [000] ...1   116.674568: rtcpu_vinotify_handle_msg: tstamp:3993773547 tag:CHANSEL_PXL_SOF channel:0x00 frame:18 vi_tstamp:3993773140 data:0x00000001
     kworker/0:0-4     [000] ...1   116.674570: rtcpu_vinotify_handle_msg: tstamp:3993774123 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:18 vi_tstamp:3993773696 data:0x08000000
     kworker/0:0-4     [000] ...1   116.726485: rtcpu_vinotify_handle_msg: tstamp:3994192670 tag:CHANSEL_PXL_EOF channel:0x01 frame:13 vi_tstamp:3994192261 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.726488: rtcpu_vinotify_handle_msg: tstamp:3994193234 tag:ATOMP_FE channel:0x01 frame:13 vi_tstamp:3994192820 data:0x00000000
     kworker/0:0-4     [000] ...1   116.726489: rtcpu_vinotify_handle_msg: tstamp:3994217308 tag:ATOMP_FS channel:0x01 frame:14 vi_tstamp:3994216900 data:0x00000000
     kworker/0:0-4     [000] ...1   116.726490: rtcpu_vinotify_handle_msg: tstamp:3994225004 tag:CHANSEL_PXL_SOF channel:0x01 frame:14 vi_tstamp:3994224601 data:0x00000001
     kworker/0:0-4     [000] ...1   116.726491: rtcpu_vinotify_handle_msg: tstamp:3994225570 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:14 vi_tstamp:3994225142 data:0x18000000
     kworker/0:0-4     [000] ...1   116.726492: rtcpu_vinotify_handle_msg: tstamp:3994244833 tag:CHANSEL_PXL_EOF channel:0x02 frame:18 vi_tstamp:3994244432 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.726493: rtcpu_vinotify_handle_msg: tstamp:3994245393 tag:ATOMP_FE channel:0x02 frame:18 vi_tstamp:3994244990 data:0x00000000
     kworker/0:0-4     [000] ...1   116.726494: rtcpu_vinotify_handle_msg: tstamp:3994269484 tag:ATOMP_FS channel:0x02 frame:19 vi_tstamp:3994269070 data:0x00000000
     kworker/0:0-4     [000] ...1   116.726495: rtcpu_vinotify_handle_msg: tstamp:3994277174 tag:CHANSEL_PXL_SOF channel:0x02 frame:19 vi_tstamp:3994276770 data:0x00000001
     kworker/0:0-4     [000] ...1   116.726496: rtcpu_vinotify_handle_msg: tstamp:3994277740 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:19 vi_tstamp:3994277311 data:0x28000000
     kworker/0:0-4     [000] ...1   116.726496: rtcpu_vinotify_handle_msg: tstamp:3994781520 tag:CHANSEL_PXL_EOF channel:0x00 frame:18 vi_tstamp:3994781108 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.726497: rtcpu_vinotify_handle_msg: tstamp:3994782086 tag:ATOMP_FE channel:0x00 frame:18 vi_tstamp:3994781666 data:0x00000000
     kworker/0:0-4     [000] ...1   116.726498: rtcpu_vinotify_handle_msg: tstamp:3994806155 tag:ATOMP_FS channel:0x00 frame:19 vi_tstamp:3994805748 data:0x00000000
     kworker/0:0-4     [000] ...1   116.726499: rtcpu_vinotify_handle_msg: tstamp:3994813852 tag:CHANSEL_PXL_SOF channel:0x00 frame:19 vi_tstamp:3994813447 data:0x00000001
     kworker/0:0-4     [000] ...1   116.726500: rtcpu_vinotify_handle_msg: tstamp:3994873165 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:19 vi_tstamp:3994872759 data:0x08000000
     kworker/0:0-4     [000] ...1   116.726502: rtos_queue_peek_from_isr_failed: tstamp:3995214886 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   116.726503: rtcpu_vinotify_handle_msg: tstamp:3995232972 tag:CHANSEL_PXL_EOF channel:0x01 frame:14 vi_tstamp:3995232569 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.726504: rtcpu_vinotify_handle_msg: tstamp:3995233536 tag:ATOMP_FE channel:0x01 frame:14 vi_tstamp:3995233128 data:0x00000000
     kworker/0:0-4     [000] ...1   116.726505: rtcpu_vinotify_handle_msg: tstamp:3995257616 tag:ATOMP_FS channel:0x01 frame:15 vi_tstamp:3995257208 data:0x00000000
     kworker/0:0-4     [000] ...1   116.726506: rtcpu_vinotify_handle_msg: tstamp:3995265313 tag:CHANSEL_PXL_SOF channel:0x01 frame:15 vi_tstamp:3995264909 data:0x00000001
     kworker/0:0-4     [000] ...1   116.726506: rtcpu_vinotify_handle_msg: tstamp:3995265883 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:15 vi_tstamp:3995265457 data:0x18000000
     kworker/0:0-4     [000] ...1   116.726507: rtcpu_vinotify_handle_msg: tstamp:3995285141 tag:CHANSEL_PXL_EOF channel:0x02 frame:19 vi_tstamp:3995284740 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.726508: rtcpu_vinotify_handle_msg: tstamp:3995285700 tag:ATOMP_FE channel:0x02 frame:19 vi_tstamp:3995285298 data:0x00000000
     kworker/0:0-4     [000] ...1   116.726509: rtcpu_vinotify_handle_msg: tstamp:3995309786 tag:ATOMP_FS channel:0x02 frame:20 vi_tstamp:3995309379 data:0x00000000
     kworker/0:0-4     [000] ...1   116.726510: rtcpu_vinotify_handle_msg: tstamp:3995317482 tag:CHANSEL_PXL_SOF channel:0x02 frame:20 vi_tstamp:3995317078 data:0x00000001
     kworker/0:0-4     [000] ...1   116.726511: rtcpu_vinotify_handle_msg: tstamp:3995318048 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:20 vi_tstamp:3995317620 data:0x28000000
     kworker/0:0-4     [000] ...1   116.778479: rtcpu_vinotify_handle_msg: tstamp:3995821823 tag:CHANSEL_PXL_EOF channel:0x00 frame:19 vi_tstamp:3995821416 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.778483: rtcpu_vinotify_handle_msg: tstamp:3995822390 tag:ATOMP_FE channel:0x00 frame:19 vi_tstamp:3995821975 data:0x00000000
     kworker/0:0-4     [000] ...1   116.778484: rtcpu_vinotify_handle_msg: tstamp:3995846467 tag:ATOMP_FS channel:0x00 frame:20 vi_tstamp:3995846056 data:0x00000000
     kworker/0:0-4     [000] ...1   116.778485: rtcpu_vinotify_handle_msg: tstamp:3995854160 tag:CHANSEL_PXL_SOF channel:0x00 frame:20 vi_tstamp:3995853756 data:0x00000001
     kworker/0:0-4     [000] ...1   116.778486: rtcpu_vinotify_handle_msg: tstamp:3995854724 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:20 vi_tstamp:3995854296 data:0x08000000
     kworker/0:0-4     [000] ...1   116.778487: rtcpu_vinotify_handle_msg: tstamp:3996273286 tag:CHANSEL_PXL_EOF channel:0x01 frame:15 vi_tstamp:3996272877 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.778488: rtcpu_vinotify_handle_msg: tstamp:3996273852 tag:ATOMP_FE channel:0x01 frame:15 vi_tstamp:3996273436 data:0x00000000
     kworker/0:0-4     [000] ...1   116.778489: rtcpu_vinotify_handle_msg: tstamp:3996297930 tag:ATOMP_FS channel:0x01 frame:16 vi_tstamp:3996297516 data:0x00000000
     kworker/0:0-4     [000] ...1   116.778490: rtcpu_vinotify_handle_msg: tstamp:3996305620 tag:CHANSEL_PXL_SOF channel:0x01 frame:16 vi_tstamp:3996305217 data:0x00000001
     kworker/0:0-4     [000] ...1   116.778491: rtcpu_vinotify_handle_msg: tstamp:3996325450 tag:CHANSEL_PXL_EOF channel:0x02 frame:20 vi_tstamp:3996325048 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.778492: rtcpu_vinotify_handle_msg: tstamp:3996326017 tag:ATOMP_FE channel:0x02 frame:20 vi_tstamp:3996325606 data:0x00000000
     kworker/0:0-4     [000] ...1   116.778493: rtcpu_vinotify_handle_msg: tstamp:3996350098 tag:ATOMP_FS channel:0x02 frame:21 vi_tstamp:3996349687 data:0x00000000
     kworker/0:0-4     [000] ...1   116.778494: rtcpu_vinotify_handle_msg: tstamp:3996357800 tag:CHANSEL_PXL_SOF channel:0x02 frame:21 vi_tstamp:3996357387 data:0x00000001
     kworker/0:0-4     [000] ...1   116.778495: rtcpu_vinotify_handle_msg: tstamp:3996654944 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:21 vi_tstamp:3996654515 data:0x28000000
     kworker/0:0-4     [000] ...1   116.778495: rtcpu_vinotify_handle_msg: tstamp:3996660040 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:16 vi_tstamp:3996659634 data:0x18000000
     kworker/0:0-4     [000] ...1   116.778496: rtcpu_vinotify_handle_msg: tstamp:3996862141 tag:CHANSEL_PXL_EOF channel:0x00 frame:20 vi_tstamp:3996861725 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.778497: rtcpu_vinotify_handle_msg: tstamp:3996862712 tag:ATOMP_FE channel:0x00 frame:20 vi_tstamp:3996862283 data:0x00000000
     kworker/0:0-4     [000] ...1   116.778499: rtcpu_vinotify_handle_msg: tstamp:3996886780 tag:ATOMP_FS channel:0x00 frame:21 vi_tstamp:3996886364 data:0x00000000
     kworker/0:0-4     [000] ...1   116.778499: rtcpu_vinotify_handle_msg: tstamp:3996894469 tag:CHANSEL_PXL_SOF channel:0x00 frame:21 vi_tstamp:3996894063 data:0x00000001
     kworker/0:0-4     [000] ...1   116.778500: rtcpu_vinotify_handle_msg: tstamp:3997313608 tag:CHANSEL_PXL_EOF channel:0x01 frame:16 vi_tstamp:3997313185 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.778501: rtcpu_vinotify_handle_msg: tstamp:3997314172 tag:ATOMP_FE channel:0x01 frame:16 vi_tstamp:3997313744 data:0x00000000
     kworker/0:0-4     [000] ...1   116.778502: rtcpu_vinotify_handle_msg: tstamp:3997338237 tag:ATOMP_FS channel:0x01 frame:17 vi_tstamp:3997337825 data:0x00000000
     kworker/0:0-4     [000] ...1   116.778503: rtcpu_vinotify_handle_msg: tstamp:3997345929 tag:CHANSEL_PXL_SOF channel:0x01 frame:17 vi_tstamp:3997345525 data:0x00000001
     kworker/0:0-4     [000] ...1   116.778504: rtcpu_vinotify_handle_msg: tstamp:3997365759 tag:CHANSEL_PXL_EOF channel:0x02 frame:21 vi_tstamp:3997365356 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.778505: rtcpu_vinotify_handle_msg: tstamp:3997366319 tag:ATOMP_FE channel:0x02 frame:21 vi_tstamp:3997365915 data:0x00000000
     kworker/0:0-4     [000] ...1   116.830536: rtcpu_vinotify_handle_msg: tstamp:3997390405 tag:ATOMP_FS channel:0x02 frame:22 vi_tstamp:3997389995 data:0x00000000
     kworker/0:0-4     [000] ...1   116.830540: rtcpu_vinotify_handle_msg: tstamp:3997398098 tag:CHANSEL_PXL_SOF channel:0x02 frame:22 vi_tstamp:3997397694 data:0x00000001
     kworker/0:0-4     [000] ...1   116.830541: rtcpu_vinotify_handle_msg: tstamp:3997553989 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:21 vi_tstamp:3997553578 data:0x08000000
     kworker/0:0-4     [000] ...1   116.830542: rtcpu_vinotify_handle_msg: tstamp:3997561377 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:17 vi_tstamp:3997560972 data:0x18000000
     kworker/0:0-4     [000] ...1   116.830544: rtcpu_vinotify_handle_msg: tstamp:3997568409 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:22 vi_tstamp:3997568001 data:0x28000000
     kworker/0:0-4     [000] ...1   116.830545: rtcpu_vinotify_handle_msg: tstamp:3997902442 tag:CHANSEL_PXL_EOF channel:0x00 frame:21 vi_tstamp:3997902033 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.830546: rtcpu_vinotify_handle_msg: tstamp:3997903010 tag:ATOMP_FE channel:0x00 frame:21 vi_tstamp:3997902591 data:0x00000000
     kworker/0:0-4     [000] ...1   116.830547: rtcpu_vinotify_handle_msg: tstamp:3997927079 tag:ATOMP_FS channel:0x00 frame:22 vi_tstamp:3997926672 data:0x00000000
     kworker/0:0-4     [000] ...1   116.830549: rtcpu_vinotify_handle_msg: tstamp:3997934775 tag:CHANSEL_PXL_SOF channel:0x00 frame:22 vi_tstamp:3997934371 data:0x00000001
     kworker/0:0-4     [000] ...1   116.830550: rtcpu_vinotify_handle_msg: tstamp:3998353903 tag:CHANSEL_PXL_EOF channel:0x01 frame:17 vi_tstamp:3998353493 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.830551: rtcpu_vinotify_handle_msg: tstamp:3998354469 tag:ATOMP_FE channel:0x01 frame:17 vi_tstamp:3998354052 data:0x00000000
     kworker/0:0-4     [000] ...1   116.830552: rtcpu_vinotify_handle_msg: tstamp:3998378538 tag:ATOMP_FS channel:0x01 frame:18 vi_tstamp:3998378133 data:0x00000000
     kworker/0:0-4     [000] ...1   116.830554: rtcpu_vinotify_handle_msg: tstamp:3998386237 tag:CHANSEL_PXL_SOF channel:0x01 frame:18 vi_tstamp:3998385832 data:0x00000001
     kworker/0:0-4     [000] ...1   116.830555: rtcpu_vinotify_handle_msg: tstamp:3998406068 tag:CHANSEL_PXL_EOF channel:0x02 frame:22 vi_tstamp:3998405665 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.830556: rtcpu_vinotify_handle_msg: tstamp:3998406626 tag:ATOMP_FE channel:0x02 frame:22 vi_tstamp:3998406223 data:0x00000000
     kworker/0:0-4     [000] ...1   116.830557: rtcpu_vinotify_handle_msg: tstamp:3998430710 tag:ATOMP_FS channel:0x02 frame:23 vi_tstamp:3998430303 data:0x00000000
     kworker/0:0-4     [000] ...1   116.830558: rtcpu_vinotify_handle_msg: tstamp:3998433604 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:18 vi_tstamp:3998433196 data:0x18000000
     kworker/0:0-4     [000] ...1   116.830559: rtcpu_vinotify_handle_msg: tstamp:3998438410 tag:CHANSEL_PXL_SOF channel:0x02 frame:23 vi_tstamp:3998438004 data:0x00000001
     kworker/0:0-4     [000] ...1   116.830560: rtcpu_vinotify_handle_msg: tstamp:3998439638 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:22 vi_tstamp:3998439234 data:0x08000000
     kworker/0:0-4     [000] ...1   116.830562: rtcpu_vinotify_handle_msg: tstamp:3998451851 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:23 vi_tstamp:3998451449 data:0x28000000
     kworker/0:0-4     [000] ...1   116.830563: rtcpu_vinotify_handle_msg: tstamp:3998942749 tag:CHANSEL_PXL_EOF channel:0x00 frame:22 vi_tstamp:3998942341 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.830564: rtcpu_vinotify_handle_msg: tstamp:3998943317 tag:ATOMP_FE channel:0x00 frame:22 vi_tstamp:3998942899 data:0x00000000
     kworker/0:0-4     [000] ...1   116.830565: rtcpu_vinotify_handle_msg: tstamp:3998967391 tag:ATOMP_FS channel:0x00 frame:23 vi_tstamp:3998966980 data:0x00000000
     kworker/0:0-4     [000] ...1   116.830567: rtcpu_vinotify_handle_msg: tstamp:3998975084 tag:CHANSEL_PXL_SOF channel:0x00 frame:23 vi_tstamp:3998974681 data:0x00000001
     kworker/0:0-4     [000] ...1   116.882502: rtcpu_vinotify_handle_msg: tstamp:3999345164 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:23 vi_tstamp:3999344745 data:0x08000000
     kworker/0:0-4     [000] ...1   116.882507: rtcpu_vinotify_handle_msg: tstamp:3999394203 tag:CHANSEL_PXL_EOF channel:0x01 frame:18 vi_tstamp:3999393802 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.882509: rtcpu_vinotify_handle_msg: tstamp:3999394762 tag:ATOMP_FE channel:0x01 frame:18 vi_tstamp:3999394361 data:0x00000000
     kworker/0:0-4     [000] ...1   116.882511: rtcpu_vinotify_handle_msg: tstamp:3999418850 tag:ATOMP_FS channel:0x01 frame:19 vi_tstamp:3999418441 data:0x00000000
     kworker/0:0-4     [000] ...1   116.882512: rtcpu_vinotify_handle_msg: tstamp:3999426551 tag:CHANSEL_PXL_SOF channel:0x01 frame:19 vi_tstamp:3999426142 data:0x00000001
     kworker/0:0-4     [000] ...1   116.882514: rtcpu_vinotify_handle_msg: tstamp:3999427119 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:19 vi_tstamp:3999426690 data:0x18000000
     kworker/0:0-4     [000] ...1   116.882515: rtcpu_vinotify_handle_msg: tstamp:3999446376 tag:CHANSEL_PXL_EOF channel:0x02 frame:23 vi_tstamp:3999445972 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.882517: rtcpu_vinotify_handle_msg: tstamp:3999446939 tag:ATOMP_FE channel:0x02 frame:23 vi_tstamp:3999446531 data:0x00000000
     kworker/0:0-4     [000] ...1   116.882518: rtcpu_vinotify_handle_msg: tstamp:3999471019 tag:ATOMP_FS channel:0x02 frame:24 vi_tstamp:3999470612 data:0x00000000
     kworker/0:0-4     [000] ...1   116.882520: rtcpu_vinotify_handle_msg: tstamp:3999478716 tag:CHANSEL_PXL_SOF channel:0x02 frame:24 vi_tstamp:3999478313 data:0x00000001
     kworker/0:0-4     [000] ...1   116.882521: rtcpu_vinotify_handle_msg: tstamp:3999479288 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:24 vi_tstamp:3999478860 data:0x28000000
     kworker/0:0-4     [000] ...1   116.882523: rtcpu_vinotify_handle_msg: tstamp:3999983056 tag:CHANSEL_PXL_EOF channel:0x00 frame:23 vi_tstamp:3999982649 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.882524: rtcpu_vinotify_handle_msg: tstamp:3999983623 tag:ATOMP_FE channel:0x00 frame:23 vi_tstamp:3999983207 data:0x00000000
     kworker/0:0-4     [000] ...1   116.882526: rtcpu_vinotify_handle_msg: tstamp:4000007696 tag:ATOMP_FS channel:0x00 frame:24 vi_tstamp:4000007289 data:0x00000000
     kworker/0:0-4     [000] ...1   116.882527: rtcpu_vinotify_handle_msg: tstamp:4000015393 tag:CHANSEL_PXL_SOF channel:0x00 frame:24 vi_tstamp:4000014987 data:0x00000001
     kworker/0:0-4     [000] ...1   116.882533: rtos_queue_peek_from_isr_failed: tstamp:4000215390 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   116.882534: rtcpu_vinotify_handle_msg: tstamp:4000249237 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:24 vi_tstamp:4000248834 data:0x08000000
     kworker/0:0-4     [000] ...1   116.882536: rtcpu_vinotify_handle_msg: tstamp:4000434518 tag:CHANSEL_PXL_EOF channel:0x01 frame:19 vi_tstamp:4000434110 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.882538: rtcpu_vinotify_handle_msg: tstamp:4000435081 tag:ATOMP_FE channel:0x01 frame:19 vi_tstamp:4000434668 data:0x00000000
     kworker/0:0-4     [000] ...1   116.882539: rtcpu_vinotify_handle_msg: tstamp:4000459159 tag:ATOMP_FS channel:0x01 frame:20 vi_tstamp:4000458749 data:0x00000000
     kworker/0:0-4     [000] ...1   116.882541: rtcpu_vinotify_handle_msg: tstamp:4000466852 tag:CHANSEL_PXL_SOF channel:0x01 frame:20 vi_tstamp:4000466449 data:0x00000001
     kworker/0:0-4     [000] ...1   116.882542: rtcpu_vinotify_handle_msg: tstamp:4000486685 tag:CHANSEL_PXL_EOF channel:0x02 frame:24 vi_tstamp:4000486280 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.882544: rtcpu_vinotify_handle_msg: tstamp:4000487244 tag:ATOMP_FE channel:0x02 frame:24 vi_tstamp:4000486839 data:0x00000000
     kworker/0:0-4     [000] ...1   116.882545: rtcpu_vinotify_handle_msg: tstamp:4000511327 tag:ATOMP_FS channel:0x02 frame:25 vi_tstamp:4000510920 data:0x00000000
     kworker/0:0-4     [000] ...1   116.882547: rtcpu_vinotify_handle_msg: tstamp:4000519023 tag:CHANSEL_PXL_SOF channel:0x02 frame:25 vi_tstamp:4000518619 data:0x00000001
     kworker/0:0-4     [000] ...1   116.934539: rtcpu_vinotify_handle_msg: tstamp:4001023378 tag:CHANSEL_PXL_EOF channel:0x00 frame:24 vi_tstamp:4001022957 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.934547: rtcpu_vinotify_handle_msg: tstamp:4001023949 tag:ATOMP_FE channel:0x00 frame:24 vi_tstamp:4001023516 data:0x00000000
     kworker/0:0-4     [000] ...1   116.934549: rtcpu_vinotify_handle_msg: tstamp:4001048002 tag:ATOMP_FS channel:0x00 frame:25 vi_tstamp:4001047596 data:0x00000000
     kworker/0:0-4     [000] ...1   116.934551: rtcpu_vinotify_handle_msg: tstamp:4001055699 tag:CHANSEL_PXL_SOF channel:0x00 frame:25 vi_tstamp:4001055296 data:0x00000001
     kworker/0:0-4     [000] ...1   116.934553: rtcpu_vinotify_handle_msg: tstamp:4001119795 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:20 vi_tstamp:4001119391 data:0x18000000
     kworker/0:0-4     [000] ...1   116.934555: rtcpu_vinotify_handle_msg: tstamp:4001131104 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:25 vi_tstamp:4001130694 data:0x28000000
     kworker/0:0-4     [000] ...1   116.934557: rtcpu_vinotify_handle_msg: tstamp:4001144078 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:25 vi_tstamp:4001143673 data:0x08000000
     kworker/0:0-4     [000] ...1   116.934558: rtcpu_vinotify_handle_msg: tstamp:4001474828 tag:CHANSEL_PXL_EOF channel:0x01 frame:20 vi_tstamp:4001474418 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.934560: rtcpu_vinotify_handle_msg: tstamp:4001475396 tag:ATOMP_FE channel:0x01 frame:20 vi_tstamp:4001474976 data:0x00000000
     kworker/0:0-4     [000] ...1   116.934562: rtcpu_vinotify_handle_msg: tstamp:4001499465 tag:ATOMP_FS channel:0x01 frame:21 vi_tstamp:4001499058 data:0x00000000
     kworker/0:0-4     [000] ...1   116.934564: rtcpu_vinotify_handle_msg: tstamp:4001507162 tag:CHANSEL_PXL_SOF channel:0x01 frame:21 vi_tstamp:4001506758 data:0x00000001
     kworker/0:0-4     [000] ...1   116.934566: rtcpu_vinotify_handle_msg: tstamp:4001526991 tag:CHANSEL_PXL_EOF channel:0x02 frame:25 vi_tstamp:4001526588 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.934568: rtcpu_vinotify_handle_msg: tstamp:4001527551 tag:ATOMP_FE channel:0x02 frame:25 vi_tstamp:4001527147 data:0x00000000
     kworker/0:0-4     [000] ...1   116.934570: rtcpu_vinotify_handle_msg: tstamp:4001551634 tag:ATOMP_FS channel:0x02 frame:26 vi_tstamp:4001551228 data:0x00000000
     kworker/0:0-4     [000] ...1   116.934572: rtcpu_vinotify_handle_msg: tstamp:4001559330 tag:CHANSEL_PXL_SOF channel:0x02 frame:26 vi_tstamp:4001558927 data:0x00000001
     kworker/0:0-4     [000] ...1   116.934574: rtcpu_vinotify_handle_msg: tstamp:4001998192 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:21 vi_tstamp:4001997781 data:0x18000000
     kworker/0:0-4     [000] ...1   116.934576: rtcpu_vinotify_handle_msg: tstamp:4002013891 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:26 vi_tstamp:4002013488 data:0x28000000
     kworker/0:0-4     [000] ...1   116.934578: rtcpu_vinotify_handle_msg: tstamp:4002063668 tag:CHANSEL_PXL_EOF channel:0x00 frame:25 vi_tstamp:4002063265 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.934579: rtcpu_vinotify_handle_msg: tstamp:4002064229 tag:ATOMP_FE channel:0x00 frame:25 vi_tstamp:4002063824 data:0x00000000
     kworker/0:0-4     [000] ...1   116.934581: rtcpu_vinotify_handle_msg: tstamp:4002088310 tag:ATOMP_FS channel:0x00 frame:26 vi_tstamp:4002087904 data:0x00000000
     kworker/0:0-4     [000] ...1   116.934583: rtcpu_vinotify_handle_msg: tstamp:4002096026 tag:CHANSEL_PXL_SOF channel:0x00 frame:26 vi_tstamp:4002095605 data:0x00000001
     kworker/0:0-4     [000] ...1   116.934586: rtcpu_vinotify_handle_msg: tstamp:4002096593 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:26 vi_tstamp:4002096166 data:0x08000000
     kworker/0:0-4     [000] ...1   116.986525: rtcpu_vinotify_handle_msg: tstamp:4002515133 tag:CHANSEL_PXL_EOF channel:0x01 frame:21 vi_tstamp:4002514726 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.986531: rtcpu_vinotify_handle_msg: tstamp:4002515696 tag:ATOMP_FE channel:0x01 frame:21 vi_tstamp:4002515284 data:0x00000000
     kworker/0:0-4     [000] ...1   116.986532: rtcpu_vinotify_handle_msg: tstamp:4002539782 tag:ATOMP_FS channel:0x01 frame:22 vi_tstamp:4002539366 data:0x00000000
     kworker/0:0-4     [000] ...1   116.986534: rtcpu_vinotify_handle_msg: tstamp:4002547470 tag:CHANSEL_PXL_SOF channel:0x01 frame:22 vi_tstamp:4002547065 data:0x00000001
     kworker/0:0-4     [000] ...1   116.986536: rtcpu_vinotify_handle_msg: tstamp:4002567301 tag:CHANSEL_PXL_EOF channel:0x02 frame:26 vi_tstamp:4002566897 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.986537: rtcpu_vinotify_handle_msg: tstamp:4002567868 tag:ATOMP_FE channel:0x02 frame:26 vi_tstamp:4002567456 data:0x00000000
     kworker/0:0-4     [000] ...1   116.986539: rtcpu_vinotify_handle_msg: tstamp:4002591941 tag:ATOMP_FS channel:0x02 frame:27 vi_tstamp:4002591536 data:0x00000000
     kworker/0:0-4     [000] ...1   116.986540: rtcpu_vinotify_handle_msg: tstamp:4002599642 tag:CHANSEL_PXL_SOF channel:0x02 frame:27 vi_tstamp:4002599236 data:0x00000001
     kworker/0:0-4     [000] ...1   116.986542: rtcpu_vinotify_handle_msg: tstamp:4002906917 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:27 vi_tstamp:4002906506 data:0x28000000
     kworker/0:0-4     [000] ...1   116.986543: rtcpu_vinotify_handle_msg: tstamp:4002919290 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:22 vi_tstamp:4002918881 data:0x18000000
     kworker/0:0-4     [000] ...1   116.986545: rtcpu_vinotify_handle_msg: tstamp:4003103982 tag:CHANSEL_PXL_EOF channel:0x00 frame:26 vi_tstamp:4003103573 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.986546: rtcpu_vinotify_handle_msg: tstamp:4003104545 tag:ATOMP_FE channel:0x00 frame:26 vi_tstamp:4003104132 data:0x00000000
     kworker/0:0-4     [000] ...1   116.986548: rtcpu_vinotify_handle_msg: tstamp:4003128634 tag:ATOMP_FS channel:0x00 frame:27 vi_tstamp:4003128213 data:0x00000000
     kworker/0:0-4     [000] ...1   116.986550: rtcpu_vinotify_handle_msg: tstamp:4003136316 tag:CHANSEL_PXL_SOF channel:0x00 frame:27 vi_tstamp:4003135913 data:0x00000001
     kworker/0:0-4     [000] ...1   116.986551: rtcpu_vinotify_handle_msg: tstamp:4003555458 tag:CHANSEL_PXL_EOF channel:0x01 frame:22 vi_tstamp:4003555034 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.986552: rtcpu_vinotify_handle_msg: tstamp:4003556023 tag:ATOMP_FE channel:0x01 frame:22 vi_tstamp:4003555593 data:0x00000000
     kworker/0:0-4     [000] ...1   116.986554: rtcpu_vinotify_handle_msg: tstamp:4003580079 tag:ATOMP_FS channel:0x01 frame:23 vi_tstamp:4003579674 data:0x00000000
     kworker/0:0-4     [000] ...1   116.986555: rtcpu_vinotify_handle_msg: tstamp:4003587776 tag:CHANSEL_PXL_SOF channel:0x01 frame:23 vi_tstamp:4003587373 data:0x00000001
     kworker/0:0-4     [000] ...1   116.986557: rtcpu_vinotify_handle_msg: tstamp:4003607608 tag:CHANSEL_PXL_EOF channel:0x02 frame:27 vi_tstamp:4003607205 data:0x0da70002
     kworker/0:0-4     [000] ...1   116.986559: rtcpu_vinotify_handle_msg: tstamp:4003608172 tag:ATOMP_FE channel:0x02 frame:27 vi_tstamp:4003607763 data:0x00000000
     kworker/0:0-4     [000] ...1   116.986560: rtcpu_vinotify_handle_msg: tstamp:4003632256 tag:ATOMP_FS channel:0x02 frame:28 vi_tstamp:4003631844 data:0x00000000
     kworker/0:0-4     [000] ...1   116.986562: rtcpu_vinotify_handle_msg: tstamp:4003639948 tag:CHANSEL_PXL_SOF channel:0x02 frame:28 vi_tstamp:4003639545 data:0x00000001
     kworker/0:0-4     [000] ...1   116.986564: rtcpu_vinotify_handle_msg: tstamp:4003846165 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:27 vi_tstamp:4003845752 data:0x08000000
     kworker/0:0-4     [000] ...1   116.986565: rtcpu_vinotify_handle_msg: tstamp:4003863425 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:28 vi_tstamp:4003863021 data:0x28000000
     kworker/0:0-4     [000] ...1   116.986567: rtcpu_vinotify_handle_msg: tstamp:4003873380 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:23 vi_tstamp:4003872974 data:0x18000000
     kworker/0:0-4     [000] ...1   117.038497: rtcpu_vinotify_handle_msg: tstamp:4004144288 tag:CHANSEL_PXL_EOF channel:0x00 frame:27 vi_tstamp:4004143881 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.038500: rtcpu_vinotify_handle_msg: tstamp:4004144856 tag:ATOMP_FE channel:0x00 frame:27 vi_tstamp:4004144440 data:0x00000000
     kworker/0:0-4     [000] ...1   117.038501: rtcpu_vinotify_handle_msg: tstamp:4004168929 tag:ATOMP_FS channel:0x00 frame:28 vi_tstamp:4004168521 data:0x00000000
     kworker/0:0-4     [000] ...1   117.038501: rtcpu_vinotify_handle_msg: tstamp:4004176622 tag:CHANSEL_PXL_SOF channel:0x00 frame:28 vi_tstamp:4004176220 data:0x00000001
     kworker/0:0-4     [000] ...1   117.038502: rtcpu_vinotify_handle_msg: tstamp:4004595754 tag:CHANSEL_PXL_EOF channel:0x01 frame:23 vi_tstamp:4004595343 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.038503: rtcpu_vinotify_handle_msg: tstamp:4004596319 tag:ATOMP_FE channel:0x01 frame:23 vi_tstamp:4004595901 data:0x00000000
     kworker/0:0-4     [000] ...1   117.038504: rtcpu_vinotify_handle_msg: tstamp:4004620387 tag:ATOMP_FS channel:0x01 frame:24 vi_tstamp:4004619982 data:0x00000000
     kworker/0:0-4     [000] ...1   117.038505: rtcpu_vinotify_handle_msg: tstamp:4004628087 tag:CHANSEL_PXL_SOF channel:0x01 frame:24 vi_tstamp:4004627683 data:0x00000001
     kworker/0:0-4     [000] ...1   117.038506: rtcpu_vinotify_handle_msg: tstamp:4004647917 tag:CHANSEL_PXL_EOF channel:0x02 frame:28 vi_tstamp:4004647513 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.038507: rtcpu_vinotify_handle_msg: tstamp:4004648476 tag:ATOMP_FE channel:0x02 frame:28 vi_tstamp:4004648071 data:0x00000000
     kworker/0:0-4     [000] ...1   117.038508: rtcpu_vinotify_handle_msg: tstamp:4004672561 tag:ATOMP_FS channel:0x02 frame:29 vi_tstamp:4004672153 data:0x00000000
     kworker/0:0-4     [000] ...1   117.038509: rtcpu_vinotify_handle_msg: tstamp:4004680261 tag:CHANSEL_PXL_SOF channel:0x02 frame:29 vi_tstamp:4004679853 data:0x00000001
     kworker/0:0-4     [000] ...1   117.038509: rtcpu_vinotify_handle_msg: tstamp:4004692850 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:28 vi_tstamp:4004692447 data:0x08000000
     kworker/0:0-4     [000] ...1   117.038510: rtcpu_vinotify_handle_msg: tstamp:4004704681 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:29 vi_tstamp:4004704275 data:0x28000000
     kworker/0:0-4     [000] ...1   117.038511: rtcpu_vinotify_handle_msg: tstamp:4004714897 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:24 vi_tstamp:4004714491 data:0x18000000
     kworker/0:0-4     [000] ...1   117.038512: rtcpu_vinotify_handle_msg: tstamp:4005184601 tag:CHANSEL_PXL_EOF channel:0x00 frame:28 vi_tstamp:4005184189 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.038513: rtcpu_vinotify_handle_msg: tstamp:4005185169 tag:ATOMP_FE channel:0x00 frame:28 vi_tstamp:4005184749 data:0x00000000
     kworker/0:0-4     [000] ...1   117.038514: rtcpu_vinotify_handle_msg: tstamp:4005209237 tag:ATOMP_FS channel:0x00 frame:29 vi_tstamp:4005208829 data:0x00000000
     kworker/0:0-4     [000] ...1   117.038516: rtos_queue_peek_from_isr_failed: tstamp:4005215898 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   117.038517: rtcpu_vinotify_handle_msg: tstamp:4005216929 tag:CHANSEL_PXL_SOF channel:0x00 frame:29 vi_tstamp:4005216528 data:0x00000001
     kworker/0:0-4     [000] ...1   117.090506: rtcpu_vinotify_handle_msg: tstamp:4005571880 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:29 vi_tstamp:4005571452 data:0x08000000
     kworker/0:0-4     [000] ...1   117.090510: rtcpu_vinotify_handle_msg: tstamp:4005636060 tag:CHANSEL_PXL_EOF channel:0x01 frame:24 vi_tstamp:4005635651 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.090511: rtcpu_vinotify_handle_msg: tstamp:4005636627 tag:ATOMP_FE channel:0x01 frame:24 vi_tstamp:4005636209 data:0x00000000
     kworker/0:0-4     [000] ...1   117.090513: rtcpu_vinotify_handle_msg: tstamp:4005660704 tag:ATOMP_FS channel:0x01 frame:25 vi_tstamp:4005660290 data:0x00000000
     kworker/0:0-4     [000] ...1   117.090514: rtcpu_vinotify_handle_msg: tstamp:4005668396 tag:CHANSEL_PXL_SOF channel:0x01 frame:25 vi_tstamp:4005667991 data:0x00000001
     kworker/0:0-4     [000] ...1   117.090515: rtcpu_vinotify_handle_msg: tstamp:4005668969 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:25 vi_tstamp:4005668533 data:0x18000000
     kworker/0:0-4     [000] ...1   117.090516: rtcpu_vinotify_handle_msg: tstamp:4005688233 tag:CHANSEL_PXL_EOF channel:0x02 frame:29 vi_tstamp:4005687821 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.090518: rtcpu_vinotify_handle_msg: tstamp:4005688792 tag:ATOMP_FE channel:0x02 frame:29 vi_tstamp:4005688380 data:0x00000000
     kworker/0:0-4     [000] ...1   117.090519: rtcpu_vinotify_handle_msg: tstamp:4005712870 tag:ATOMP_FS channel:0x02 frame:30 vi_tstamp:4005712461 data:0x00000000
     kworker/0:0-4     [000] ...1   117.090520: rtcpu_vinotify_handle_msg: tstamp:4005720565 tag:CHANSEL_PXL_SOF channel:0x02 frame:30 vi_tstamp:4005720161 data:0x00000001
     kworker/0:0-4     [000] ...1   117.090521: rtcpu_vinotify_handle_msg: tstamp:4005721129 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:30 vi_tstamp:4005720703 data:0x28000000
     kworker/0:0-4     [000] ...1   117.090522: rtcpu_vinotify_handle_msg: tstamp:4006224908 tag:CHANSEL_PXL_EOF channel:0x00 frame:29 vi_tstamp:4006224498 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.090523: rtcpu_vinotify_handle_msg: tstamp:4006225503 tag:ATOMP_FE channel:0x00 frame:29 vi_tstamp:4006225057 data:0x00000000
     kworker/0:0-4     [000] ...1   117.090524: rtcpu_vinotify_handle_msg: tstamp:4006249544 tag:ATOMP_FS channel:0x00 frame:30 vi_tstamp:4006249137 data:0x00000000
     kworker/0:0-4     [000] ...1   117.090526: rtcpu_vinotify_handle_msg: tstamp:4006257241 tag:CHANSEL_PXL_SOF channel:0x00 frame:30 vi_tstamp:4006256837 data:0x00000001
     kworker/0:0-4     [000] ...1   117.090527: rtcpu_vinotify_handle_msg: tstamp:4006461436 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:30 vi_tstamp:4006461023 data:0x08000000
     kworker/0:0-4     [000] ...1   117.090528: rtcpu_vinotify_handle_msg: tstamp:4006676373 tag:CHANSEL_PXL_EOF channel:0x01 frame:25 vi_tstamp:4006675959 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.090530: rtcpu_vinotify_handle_msg: tstamp:4006676946 tag:ATOMP_FE channel:0x01 frame:25 vi_tstamp:4006676517 data:0x00000000
     kworker/0:0-4     [000] ...1   117.090531: rtcpu_vinotify_handle_msg: tstamp:4006701006 tag:ATOMP_FS channel:0x01 frame:26 vi_tstamp:4006700599 data:0x00000000
     kworker/0:0-4     [000] ...1   117.090532: rtcpu_vinotify_handle_msg: tstamp:4006708702 tag:CHANSEL_PXL_SOF channel:0x01 frame:26 vi_tstamp:4006708298 data:0x00000001
     kworker/0:0-4     [000] ...1   117.090533: rtcpu_vinotify_handle_msg: tstamp:4006728533 tag:CHANSEL_PXL_EOF channel:0x02 frame:30 vi_tstamp:4006728130 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.090534: rtcpu_vinotify_handle_msg: tstamp:4006729100 tag:ATOMP_FE channel:0x02 frame:30 vi_tstamp:4006728688 data:0x00000000
     kworker/0:0-4     [000] ...1   117.090536: rtcpu_vinotify_handle_msg: tstamp:4006753175 tag:ATOMP_FS channel:0x02 frame:31 vi_tstamp:4006752768 data:0x00000000
     kworker/0:0-4     [000] ...1   117.090537: rtcpu_vinotify_handle_msg: tstamp:4006760874 tag:CHANSEL_PXL_SOF channel:0x02 frame:31 vi_tstamp:4006760469 data:0x00000001
     kworker/0:0-4     [000] ...1   117.142558: rtcpu_vinotify_handle_msg: tstamp:4007265215 tag:CHANSEL_PXL_EOF channel:0x00 frame:30 vi_tstamp:4007264806 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.142564: rtcpu_vinotify_handle_msg: tstamp:4007265781 tag:ATOMP_FE channel:0x00 frame:30 vi_tstamp:4007265364 data:0x00000000
     kworker/0:0-4     [000] ...1   117.142565: rtcpu_vinotify_handle_msg: tstamp:4007289852 tag:ATOMP_FS channel:0x00 frame:31 vi_tstamp:4007289445 data:0x00000000
     kworker/0:0-4     [000] ...1   117.142567: rtcpu_vinotify_handle_msg: tstamp:4007297553 tag:CHANSEL_PXL_SOF channel:0x00 frame:31 vi_tstamp:4007297145 data:0x00000001
     kworker/0:0-4     [000] ...1   117.142568: rtcpu_vinotify_handle_msg: tstamp:4007351326 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:26 vi_tstamp:4007350907 data:0x18000000
     kworker/0:0-4     [000] ...1   117.142570: rtcpu_vinotify_handle_msg: tstamp:4007360285 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:31 vi_tstamp:4007359880 data:0x28000000
     kworker/0:0-4     [000] ...1   117.142572: rtcpu_vinotify_handle_msg: tstamp:4007367514 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:31 vi_tstamp:4007367101 data:0x08000000
     kworker/0:0-4     [000] ...1   117.142573: rtcpu_vinotify_handle_msg: tstamp:4007716683 tag:CHANSEL_PXL_EOF channel:0x01 frame:26 vi_tstamp:4007716267 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.142575: rtcpu_vinotify_handle_msg: tstamp:4007717251 tag:ATOMP_FE channel:0x01 frame:26 vi_tstamp:4007716826 data:0x00000000
     kworker/0:0-4     [000] ...1   117.142576: rtcpu_vinotify_handle_msg: tstamp:4007741312 tag:ATOMP_FS channel:0x01 frame:27 vi_tstamp:4007740906 data:0x00000000
     kworker/0:0-4     [000] ...1   117.142578: rtcpu_vinotify_handle_msg: tstamp:4007749010 tag:CHANSEL_PXL_SOF channel:0x01 frame:27 vi_tstamp:4007748606 data:0x00000001
     kworker/0:0-4     [000] ...1   117.142579: rtcpu_vinotify_handle_msg: tstamp:4007768841 tag:CHANSEL_PXL_EOF channel:0x02 frame:31 vi_tstamp:4007768438 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.142583: rtcpu_vinotify_handle_msg: tstamp:4007769402 tag:ATOMP_FE channel:0x02 frame:31 vi_tstamp:4007768996 data:0x00000000
     kworker/0:0-4     [000] ...1   117.142585: rtcpu_vinotify_handle_msg: tstamp:4007793480 tag:ATOMP_FS channel:0x02 frame:32 vi_tstamp:4007793077 data:0x00000000
     kworker/0:0-4     [000] ...1   117.142586: rtcpu_vinotify_handle_msg: tstamp:4007801180 tag:CHANSEL_PXL_SOF channel:0x02 frame:32 vi_tstamp:4007800777 data:0x00000001
     kworker/0:0-4     [000] ...1   117.142588: rtcpu_vinotify_handle_msg: tstamp:4008244435 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:27 vi_tstamp:4008244012 data:0x18000000
     kworker/0:0-4     [000] ...1   117.142589: rtcpu_vinotify_handle_msg: tstamp:4008259947 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:32 vi_tstamp:4008259544 data:0x28000000
     kworker/0:0-4     [000] ...1   117.142591: rtcpu_vinotify_handle_msg: tstamp:4008305514 tag:CHANSEL_PXL_EOF channel:0x00 frame:31 vi_tstamp:4008305114 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.142592: rtcpu_vinotify_handle_msg: tstamp:4008306074 tag:ATOMP_FE channel:0x00 frame:31 vi_tstamp:4008305672 data:0x00000000
     kworker/0:0-4     [000] ...1   117.142594: rtcpu_vinotify_handle_msg: tstamp:4008330160 tag:ATOMP_FS channel:0x00 frame:32 vi_tstamp:4008329754 data:0x00000000
     kworker/0:0-4     [000] ...1   117.142595: rtcpu_vinotify_handle_msg: tstamp:4008337858 tag:CHANSEL_PXL_SOF channel:0x00 frame:32 vi_tstamp:4008337454 data:0x00000001
     kworker/0:0-4     [000] ...1   117.142597: rtcpu_vinotify_handle_msg: tstamp:4008338427 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:32 vi_tstamp:4008337998 data:0x08000000
     kworker/0:0-4     [000] ...1   117.142598: rtcpu_vinotify_handle_msg: tstamp:4008756992 tag:CHANSEL_PXL_EOF channel:0x01 frame:27 vi_tstamp:4008756575 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.142600: rtcpu_vinotify_handle_msg: tstamp:4008757554 tag:ATOMP_FE channel:0x01 frame:27 vi_tstamp:4008757134 data:0x00000000
     kworker/0:0-4     [000] ...1   117.194588: rtcpu_vinotify_handle_msg: tstamp:4008781619 tag:ATOMP_FS channel:0x01 frame:28 vi_tstamp:4008781214 data:0x00000000
     kworker/0:0-4     [000] ...1   117.194595: rtcpu_vinotify_handle_msg: tstamp:4008789315 tag:CHANSEL_PXL_SOF channel:0x01 frame:28 vi_tstamp:4008788914 data:0x00000001
     kworker/0:0-4     [000] ...1   117.194597: rtcpu_vinotify_handle_msg: tstamp:4008809149 tag:CHANSEL_PXL_EOF channel:0x02 frame:32 vi_tstamp:4008808746 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.194599: rtcpu_vinotify_handle_msg: tstamp:4008809706 tag:ATOMP_FE channel:0x02 frame:32 vi_tstamp:4008809304 data:0x00000000
     kworker/0:0-4     [000] ...1   117.194601: rtcpu_vinotify_handle_msg: tstamp:4008833792 tag:ATOMP_FS channel:0x02 frame:33 vi_tstamp:4008833385 data:0x00000000
     kworker/0:0-4     [000] ...1   117.194603: rtcpu_vinotify_handle_msg: tstamp:4008841486 tag:CHANSEL_PXL_SOF channel:0x02 frame:33 vi_tstamp:4008841085 data:0x00000001
     kworker/0:0-4     [000] ...1   117.194605: rtcpu_vinotify_handle_msg: tstamp:4009149376 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:28 vi_tstamp:4009148965 data:0x18000000
     kworker/0:0-4     [000] ...1   117.194607: rtcpu_vinotify_handle_msg: tstamp:4009157755 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:33 vi_tstamp:4009157351 data:0x28000000
     kworker/0:0-4     [000] ...1   117.194609: rtcpu_vinotify_handle_msg: tstamp:4009345832 tag:CHANSEL_PXL_EOF channel:0x00 frame:32 vi_tstamp:4009345422 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.194610: rtcpu_vinotify_handle_msg: tstamp:4009346395 tag:ATOMP_FE channel:0x00 frame:32 vi_tstamp:4009345981 data:0x00000000
     kworker/0:0-4     [000] ...1   117.194612: rtcpu_vinotify_handle_msg: tstamp:4009370467 tag:ATOMP_FS channel:0x00 frame:33 vi_tstamp:4009370062 data:0x00000000
     kworker/0:0-4     [000] ...1   117.194614: rtcpu_vinotify_handle_msg: tstamp:4009378175 tag:CHANSEL_PXL_SOF channel:0x00 frame:33 vi_tstamp:4009377763 data:0x00000001
     kworker/0:0-4     [000] ...1   117.194616: rtcpu_vinotify_handle_msg: tstamp:4009797291 tag:CHANSEL_PXL_EOF channel:0x01 frame:28 vi_tstamp:4009796883 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.194618: rtcpu_vinotify_handle_msg: tstamp:4009797855 tag:ATOMP_FE channel:0x01 frame:28 vi_tstamp:4009797442 data:0x00000000
     kworker/0:0-4     [000] ...1   117.194619: rtcpu_vinotify_handle_msg: tstamp:4009821929 tag:ATOMP_FS channel:0x01 frame:29 vi_tstamp:4009821522 data:0x00000000
     kworker/0:0-4     [000] ...1   117.194621: rtcpu_vinotify_handle_msg: tstamp:4009829626 tag:CHANSEL_PXL_SOF channel:0x01 frame:29 vi_tstamp:4009829224 data:0x00000001
     kworker/0:0-4     [000] ...1   117.194623: rtcpu_vinotify_handle_msg: tstamp:4009849457 tag:CHANSEL_PXL_EOF channel:0x02 frame:33 vi_tstamp:4009849053 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.194625: rtcpu_vinotify_handle_msg: tstamp:4009850015 tag:ATOMP_FE channel:0x02 frame:33 vi_tstamp:4009849613 data:0x00000000
     kworker/0:0-4     [000] ...1   117.194627: rtcpu_vinotify_handle_msg: tstamp:4009874101 tag:ATOMP_FS channel:0x02 frame:34 vi_tstamp:4009873693 data:0x00000000
     kworker/0:0-4     [000] ...1   117.194629: rtcpu_vinotify_handle_msg: tstamp:4009881795 tag:CHANSEL_PXL_SOF channel:0x02 frame:34 vi_tstamp:4009881393 data:0x00000001
     kworker/0:0-4     [000] ...1   117.194631: rtcpu_vinotify_handle_msg: tstamp:4010055256 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:33 vi_tstamp:4010054846 data:0x08000000
     kworker/0:0-4     [000] ...1   117.194632: rtcpu_vinotify_handle_msg: tstamp:4010078252 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:29 vi_tstamp:4010077849 data:0x18000000
     kworker/0:0-4     [000] ...1   117.194634: rtcpu_vinotify_handle_msg: tstamp:4010095064 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:34 vi_tstamp:4010094659 data:0x28000000
     kworker/0:0-4     [000] ...1   117.194638: rtos_queue_peek_from_isr_failed: tstamp:4010216408 queue:0x0b4a3c58
     kworker/0:0-4     [000] ...1   117.194640: rtcpu_vinotify_handle_msg: tstamp:4010386139 tag:CHANSEL_PXL_EOF channel:0x00 frame:33 vi_tstamp:4010385731 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.194641: rtcpu_vinotify_handle_msg: tstamp:4010386705 tag:ATOMP_FE channel:0x00 frame:33 vi_tstamp:4010386289 data:0x00000000
     kworker/0:0-4     [000] ...1   117.246523: rtcpu_vinotify_handle_msg: tstamp:4010410776 tag:ATOMP_FS channel:0x00 frame:34 vi_tstamp:4010410370 data:0x00000000
     kworker/0:0-4     [000] ...1   117.246528: rtcpu_vinotify_handle_msg: tstamp:4010418473 tag:CHANSEL_PXL_SOF channel:0x00 frame:34 vi_tstamp:4010418069 data:0x00000001
     kworker/0:0-4     [000] ...1   117.246530: rtcpu_vinotify_handle_msg: tstamp:4010837601 tag:CHANSEL_PXL_EOF channel:0x01 frame:29 vi_tstamp:4010837191 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.246532: rtcpu_vinotify_handle_msg: tstamp:4010838165 tag:ATOMP_FE channel:0x01 frame:29 vi_tstamp:4010837750 data:0x00000000
     kworker/0:0-4     [000] ...1   117.246534: rtcpu_vinotify_handle_msg: tstamp:4010862238 tag:ATOMP_FS channel:0x01 frame:30 vi_tstamp:4010861831 data:0x00000000
     kworker/0:0-4     [000] ...1   117.246536: rtcpu_vinotify_handle_msg: tstamp:4010869934 tag:CHANSEL_PXL_SOF channel:0x01 frame:30 vi_tstamp:4010869531 data:0x00000001
     kworker/0:0-4     [000] ...1   117.246537: rtcpu_vinotify_handle_msg: tstamp:4010889766 tag:CHANSEL_PXL_EOF channel:0x02 frame:34 vi_tstamp:4010889362 data:0x0da70002
     kworker/0:0-4     [000] ...1   117.246539: rtcpu_vinotify_handle_msg: tstamp:4010890327 tag:ATOMP_FE channel:0x02 frame:34 vi_tstamp:4010889921 data
hello josejich,
here’s known issue with R28.2/TX2 that we did not handle FE_SYNCPT_IDX correctly,
could you please refer to Topic 1038067 and apply the kernel patches for testing,
thanks
I tested the patches on R28.2, but even after that; capture stability seems to be worst than on R28.1. Just by starting three cameras at the same time (without any sync configuration) causes the last camera to fail start the capture. The following is the log that I get after the error:
root@tegra-ubuntu:/home/nvidia# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 2322/2322   #P:4
#                              _-----=> irqs-off
#                             / _----=> need-resched
#                            | / _---=> hardirq/softirq
#                            || / _--=> preempt-depth
#                            ||| /     delay
#           TASK-PID   CPU#  ||||    TIMESTAMP  FUNCTION
     kworker/4:2-218   [004] ...1   102.072073: rtos_queue_peek_from_isr_failed: tstamp:3276628236 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   102.072077: rtcpu_start: tstamp:3276628983
     kworker/4:2-218   [004] ...1   102.228026: rtos_queue_peek_from_isr_failed: tstamp:3281629125 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   102.384445: rtos_queue_peek_from_isr_failed: tstamp:3286629628 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   102.591885: rtos_queue_peek_from_isr_failed: tstamp:3291630136 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   102.752077: rtos_queue_peek_from_isr_failed: tstamp:3296630632 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   102.915496: rtos_queue_peek_from_isr_failed: tstamp:3301631141 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   103.067729: rtos_queue_peek_from_isr_failed: tstamp:3306631636 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   103.223700: rtos_queue_peek_from_isr_failed: tstamp:3311632145 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   103.379611: rtos_queue_peek_from_isr_failed: tstamp:3316632646 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   103.543552: rtos_queue_peek_from_isr_failed: tstamp:3321633159 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   103.599528: rtcpu_vinotify_handle_msg: tstamp:3323809726 tag:ATOMP_FS channel:0x00 frame:9 vi_tstamp:3323809304 data:0x00000000
     kworker/4:2-218   [004] ...1   103.599531: rtcpu_vinotify_handle_msg: tstamp:3323817424 tag:CHANSEL_PXL_SOF channel:0x00 frame:9 vi_tstamp:3323817017 data:0x00000001
     kworker/4:2-218   [004] ...1   103.599532: rtcpu_vinotify_handle_msg: tstamp:3323817898 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:9 vi_tstamp:3323817548 data:0x08000000
     kworker/4:2-218   [004] ...1   103.651516: rtcpu_vinotify_handle_msg: tstamp:3324825632 tag:CHANSEL_PXL_EOF channel:0x00 frame:9 vi_tstamp:3324824986 data:0x0da70002
     kworker/4:2-218   [004] ...1   103.651519: rtcpu_vinotify_handle_msg: tstamp:3324825747 tag:ATOMP_FE channel:0x00 frame:9 vi_tstamp:3324825288 data:0x00000000
     kworker/4:2-218   [004] ...1   103.651520: rtcpu_vinotify_handle_msg: tstamp:3324850018 tag:ATOMP_FS channel:0x00 frame:10 vi_tstamp:3324849612 data:0x00000000
     kworker/4:2-218   [004] ...1   103.651521: rtcpu_vinotify_handle_msg: tstamp:3324857731 tag:CHANSEL_PXL_SOF channel:0x00 frame:10 vi_tstamp:3324857326 data:0x00000001
     kworker/4:2-218   [004] ...1   103.651522: rtcpu_vinotify_handle_msg: tstamp:3324858299 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:10 vi_tstamp:3324857854 data:0x08000000
     kworker/4:2-218   [004] ...1   103.651522: rtcpu_vinotify_handle_msg: tstamp:3325865935 tag:CHANSEL_PXL_EOF channel:0x00 frame:10 vi_tstamp:3325865294 data:0x0da70002
     kworker/4:2-218   [004] ...1   103.651523: rtcpu_vinotify_handle_msg: tstamp:3325866043 tag:ATOMP_FE channel:0x00 frame:10 vi_tstamp:3325865598 data:0x00000000
     kworker/4:2-218   [004] ...1   103.651524: rtcpu_vinotify_handle_msg: tstamp:3325890327 tag:ATOMP_FS channel:0x00 frame:11 vi_tstamp:3325889920 data:0x00000000
     kworker/4:2-218   [004] ...1   103.651525: rtcpu_vinotify_handle_msg: tstamp:3325898036 tag:CHANSEL_PXL_SOF channel:0x00 frame:11 vi_tstamp:3325897634 data:0x00000001
     kworker/4:2-218   [004] ...1   103.651526: rtcpu_vinotify_handle_msg: tstamp:3325898599 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:11 vi_tstamp:3325898156 data:0x08000000
     kworker/4:2-218   [004] ...1   103.703507: rtos_queue_peek_from_isr_failed: tstamp:3326633662 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   103.703512: rtcpu_vinotify_handle_msg: tstamp:3326906251 tag:CHANSEL_PXL_EOF channel:0x00 frame:11 vi_tstamp:3326905602 data:0x0da70002
     kworker/4:2-218   [004] ...1   103.703514: rtcpu_vinotify_handle_msg: tstamp:3326906358 tag:ATOMP_FE channel:0x00 frame:11 vi_tstamp:3326905905 data:0x00000000
     kworker/4:2-218   [004] ...1   103.703515: rtcpu_vinotify_handle_msg: tstamp:3326930631 tag:ATOMP_FS channel:0x00 frame:12 vi_tstamp:3326930228 data:0x00000000
     kworker/4:2-218   [004] ...1   103.703516: rtcpu_vinotify_handle_msg: tstamp:3326938345 tag:CHANSEL_PXL_SOF channel:0x00 frame:12 vi_tstamp:3326937941 data:0x00000001
     kworker/4:2-218   [004] ...1   103.703517: rtcpu_vinotify_handle_msg: tstamp:3326938923 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:12 vi_tstamp:3326938472 data:0x08000000
     kworker/4:2-218   [004] ...1   103.755473: rtcpu_vinotify_handle_msg: tstamp:3327946561 tag:CHANSEL_PXL_EOF channel:0x00 frame:12 vi_tstamp:3327945910 data:0x0da70002
     kworker/4:2-218   [004] ...1   103.755476: rtcpu_vinotify_handle_msg: tstamp:3327946672 tag:ATOMP_FE channel:0x00 frame:12 vi_tstamp:3327946213 data:0x00000000
     kworker/4:2-218   [004] ...1   103.755477: rtcpu_vinotify_handle_msg: tstamp:3327970944 tag:ATOMP_FS channel:0x00 frame:13 vi_tstamp:3327970537 data:0x00000000
     kworker/4:2-218   [004] ...1   103.755478: rtcpu_vinotify_handle_msg: tstamp:3327978667 tag:CHANSEL_PXL_SOF channel:0x00 frame:13 vi_tstamp:3327978250 data:0x00000001
     kworker/4:2-218   [004] ...1   103.755479: rtcpu_vinotify_handle_msg: tstamp:3327979139 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:13 vi_tstamp:3327978788 data:0x08000000
     kworker/4:2-218   [004] ...1   103.755480: rtcpu_vinotify_handle_msg: tstamp:3328986867 tag:CHANSEL_PXL_EOF channel:0x00 frame:13 vi_tstamp:3328986219 data:0x0da70002
     kworker/4:2-218   [004] ...1   103.755481: rtcpu_vinotify_handle_msg: tstamp:3328986979 tag:ATOMP_FE channel:0x00 frame:13 vi_tstamp:3328986521 data:0x00000000
     kworker/4:2-218   [004] ...1   103.755482: rtcpu_vinotify_handle_msg: tstamp:3329011250 tag:ATOMP_FS channel:0x00 frame:14 vi_tstamp:3329010844 data:0x00000000
     kworker/4:2-218   [004] ...1   103.755483: rtcpu_vinotify_handle_msg: tstamp:3329018956 tag:CHANSEL_PXL_SOF channel:0x00 frame:14 vi_tstamp:3329018558 data:0x00000001
     kworker/4:2-218   [004] ...1   103.755484: rtcpu_vinotify_handle_msg: tstamp:3329019519 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:14 vi_tstamp:3329019077 data:0x08000000
     kworker/4:2-218   [004] ...1   103.807465: rtcpu_vinotify_handle_msg: tstamp:3330027176 tag:CHANSEL_PXL_EOF channel:0x00 frame:14 vi_tstamp:3330026527 data:0x0da70002
     kworker/4:2-218   [004] ...1   103.807469: rtcpu_vinotify_handle_msg: tstamp:3330027288 tag:ATOMP_FE channel:0x00 frame:14 vi_tstamp:3330026830 data:0x00000000
     kworker/4:2-218   [004] ...1   103.807471: rtcpu_vinotify_handle_msg: tstamp:3330051559 tag:ATOMP_FS channel:0x00 frame:15 vi_tstamp:3330051153 data:0x00000000
     kworker/4:2-218   [004] ...1   103.807472: rtcpu_vinotify_handle_msg: tstamp:3330059266 tag:CHANSEL_PXL_SOF channel:0x00 frame:15 vi_tstamp:3330058866 data:0x00000001
     kworker/4:2-218   [004] ...1   103.807473: rtcpu_vinotify_handle_msg: tstamp:3330059827 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:15 vi_tstamp:3330059388 data:0x08000000
     kworker/4:2-218   [004] ...1   103.807474: rtcpu_vinotify_handle_msg: tstamp:3331067484 tag:CHANSEL_PXL_EOF channel:0x00 frame:15 vi_tstamp:3331066835 data:0x0da70002
     kworker/4:2-218   [004] ...1   103.807476: rtcpu_vinotify_handle_msg: tstamp:3331067594 tag:ATOMP_FE channel:0x00 frame:15 vi_tstamp:3331067138 data:0x00000000
     kworker/4:2-218   [004] ...1   103.807477: rtcpu_vinotify_handle_msg: tstamp:3331091868 tag:ATOMP_FS channel:0x00 frame:16 vi_tstamp:3331091461 data:0x00000000
     kworker/4:2-218   [004] ...1   103.807478: rtcpu_vinotify_handle_msg: tstamp:3331099587 tag:CHANSEL_PXL_SOF channel:0x00 frame:16 vi_tstamp:3331099175 data:0x00000001
     kworker/4:2-218   [004] ...1   103.807479: rtcpu_vinotify_handle_msg: tstamp:3331100152 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:16 vi_tstamp:3331099709 data:0x08000000
     kworker/4:2-218   [004] ...1   103.859657: rtos_queue_peek_from_isr_failed: tstamp:3331634176 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   103.859664: rtcpu_vinotify_handle_msg: tstamp:3332107790 tag:CHANSEL_PXL_EOF channel:0x00 frame:16 vi_tstamp:3332107143 data:0x0da70002
     kworker/4:2-218   [004] ...1   103.859665: rtcpu_vinotify_handle_msg: tstamp:3332107896 tag:ATOMP_FE channel:0x00 frame:16 vi_tstamp:3332107446 data:0x00000000
     kworker/4:2-218   [004] ...1   103.859667: rtcpu_vinotify_handle_msg: tstamp:3332132174 tag:ATOMP_FS channel:0x00 frame:17 vi_tstamp:3332131769 data:0x00000000
     kworker/4:2-218   [004] ...1   103.859669: rtcpu_vinotify_handle_msg: tstamp:3332139887 tag:CHANSEL_PXL_SOF channel:0x00 frame:17 vi_tstamp:3332139483 data:0x00000001
     kworker/4:2-218   [004] ...1   103.859670: rtcpu_vinotify_handle_msg: tstamp:3332140456 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:17 vi_tstamp:3332140010 data:0x08000000
     kworker/4:2-218   [004] ...1   103.926043: rtcpu_vinotify_handle_msg: tstamp:3333148112 tag:CHANSEL_PXL_EOF channel:0x00 frame:17 vi_tstamp:3333147452 data:0x0da70002
     kworker/4:2-218   [004] ...1   103.926048: rtcpu_vinotify_handle_msg: tstamp:3333148224 tag:ATOMP_FE channel:0x00 frame:17 vi_tstamp:3333147754 data:0x00000000
     kworker/4:2-218   [004] ...1   103.926050: rtcpu_vinotify_handle_msg: tstamp:3333172483 tag:ATOMP_FS channel:0x00 frame:18 vi_tstamp:3333172077 data:0x00000000
     kworker/4:2-218   [004] ...1   103.926051: rtcpu_vinotify_handle_msg: tstamp:3333180193 tag:CHANSEL_PXL_SOF channel:0x00 frame:18 vi_tstamp:3333179790 data:0x00000001
     kworker/4:2-218   [004] ...1   103.926053: rtcpu_vinotify_handle_msg: tstamp:3333180765 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:18 vi_tstamp:3333180319 data:0x08000000
     kworker/4:2-218   [004] ...1   103.926054: rtcpu_vinotify_handle_msg: tstamp:3334188404 tag:CHANSEL_PXL_EOF channel:0x00 frame:18 vi_tstamp:3334187760 data:0x0da70002
     kworker/4:2-218   [004] ...1   103.926056: rtcpu_vinotify_handle_msg: tstamp:3334188516 tag:ATOMP_FE channel:0x00 frame:18 vi_tstamp:3334188062 data:0x00000000
     kworker/4:2-218   [004] ...1   103.926058: rtcpu_vinotify_handle_msg: tstamp:3334212791 tag:ATOMP_FS channel:0x00 frame:19 vi_tstamp:3334212385 data:0x00000000
     kworker/4:2-218   [004] ...1   103.926059: rtcpu_vinotify_handle_msg: tstamp:3334220500 tag:CHANSEL_PXL_SOF channel:0x00 frame:19 vi_tstamp:3334220099 data:0x00000001
     kworker/4:2-218   [004] ...1   103.926061: rtcpu_vinotify_handle_msg: tstamp:3334221065 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:19 vi_tstamp:3334220621 data:0x08000000
     kworker/4:2-218   [004] ...1   103.975407: rtcpu_vinotify_handle_msg: tstamp:3335228726 tag:CHANSEL_PXL_EOF channel:0x00 frame:19 vi_tstamp:3335228068 data:0x0da70002
     kworker/4:2-218   [004] ...1   103.975410: rtcpu_vinotify_handle_msg: tstamp:3335228838 tag:ATOMP_FE channel:0x00 frame:19 vi_tstamp:3335228371 data:0x00000000
     kworker/4:2-218   [004] ...1   103.975411: rtcpu_vinotify_handle_msg: tstamp:3335253097 tag:ATOMP_FS channel:0x00 frame:20 vi_tstamp:3335252694 data:0x00000000
     kworker/4:2-218   [004] ...1   103.975412: rtcpu_vinotify_handle_msg: tstamp:3335260808 tag:CHANSEL_PXL_SOF channel:0x00 frame:20 vi_tstamp:3335260406 data:0x00000001
     kworker/4:2-218   [004] ...1   103.975413: rtcpu_vinotify_handle_msg: tstamp:3335261279 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:20 vi_tstamp:3335260932 data:0x08000000
     kworker/4:2-218   [004] ...1   103.975414: rtcpu_vinotify_handle_msg: tstamp:3336269023 tag:CHANSEL_PXL_EOF channel:0x00 frame:20 vi_tstamp:3336268376 data:0x0da70002
     kworker/4:2-218   [004] ...1   103.975414: rtcpu_vinotify_handle_msg: tstamp:3336269135 tag:ATOMP_FE channel:0x00 frame:20 vi_tstamp:3336268679 data:0x00000000
     kworker/4:2-218   [004] ...1   103.975415: rtcpu_vinotify_handle_msg: tstamp:3336293410 tag:ATOMP_FS channel:0x00 frame:21 vi_tstamp:3336293002 data:0x00000000
     kworker/4:2-218   [004] ...1   103.975416: rtcpu_vinotify_handle_msg: tstamp:3336301116 tag:CHANSEL_PXL_SOF channel:0x00 frame:21 vi_tstamp:3336300715 data:0x00000001
     kworker/4:2-218   [004] ...1   103.975417: rtcpu_vinotify_handle_msg: tstamp:3336301683 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:21 vi_tstamp:3336301238 data:0x08000000
     kworker/4:2-218   [004] ...1   104.027403: rtos_queue_peek_from_isr_failed: tstamp:3336634684 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   104.027406: rtcpu_vinotify_handle_msg: tstamp:3337309331 tag:CHANSEL_PXL_EOF channel:0x00 frame:21 vi_tstamp:3337308684 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.027407: rtcpu_vinotify_handle_msg: tstamp:3337309444 tag:ATOMP_FE channel:0x00 frame:21 vi_tstamp:3337308986 data:0x00000000
     kworker/4:2-218   [004] ...1   104.027408: rtcpu_vinotify_handle_msg: tstamp:3337333716 tag:ATOMP_FS channel:0x00 frame:22 vi_tstamp:3337333310 data:0x00000000
     kworker/4:2-218   [004] ...1   104.027409: rtcpu_vinotify_handle_msg: tstamp:3337341422 tag:CHANSEL_PXL_SOF channel:0x00 frame:22 vi_tstamp:3337341023 data:0x00000001
     kworker/4:2-218   [004] ...1   104.027410: rtcpu_vinotify_handle_msg: tstamp:3337341987 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:22 vi_tstamp:3337341545 data:0x08000000
     kworker/4:2-218   [004] ...1   104.079382: rtcpu_vinotify_handle_msg: tstamp:3338349639 tag:CHANSEL_PXL_EOF channel:0x00 frame:22 vi_tstamp:3338348992 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.079385: rtcpu_vinotify_handle_msg: tstamp:3338349750 tag:ATOMP_FE channel:0x00 frame:22 vi_tstamp:3338349295 data:0x00000000
     kworker/4:2-218   [004] ...1   104.079385: rtcpu_vinotify_handle_msg: tstamp:3338374027 tag:ATOMP_FS channel:0x00 frame:23 vi_tstamp:3338373618 data:0x00000000
     kworker/4:2-218   [004] ...1   104.079386: rtcpu_vinotify_handle_msg: tstamp:3338381735 tag:CHANSEL_PXL_SOF channel:0x00 frame:23 vi_tstamp:3338381331 data:0x00000001
     kworker/4:2-218   [004] ...1   104.079387: rtcpu_vinotify_handle_msg: tstamp:3338706676 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:23 vi_tstamp:3338706265 data:0x08000000
     kworker/4:2-218   [004] ...1   104.079388: rtcpu_vinotify_handle_msg: tstamp:3339389946 tag:CHANSEL_PXL_EOF channel:0x00 frame:23 vi_tstamp:3339389300 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.079389: rtcpu_vinotify_handle_msg: tstamp:3339390060 tag:ATOMP_FE channel:0x00 frame:23 vi_tstamp:3339389603 data:0x00000000
     kworker/4:2-218   [004] ...1   104.079390: rtcpu_vinotify_handle_msg: tstamp:3339414332 tag:ATOMP_FS channel:0x00 frame:24 vi_tstamp:3339413926 data:0x00000000
     kworker/4:2-218   [004] ...1   104.079390: rtcpu_vinotify_handle_msg: tstamp:3339422043 tag:CHANSEL_PXL_SOF channel:0x00 frame:24 vi_tstamp:3339421639 data:0x00000001
     kworker/4:2-218   [004] ...1   104.079391: rtcpu_vinotify_handle_msg: tstamp:3339422525 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:24 vi_tstamp:3339422170 data:0x08000000
     kworker/4:2-218   [004] ...1   104.131840: rtcpu_vinotify_handle_msg: tstamp:3340430255 tag:CHANSEL_PXL_EOF channel:0x00 frame:24 vi_tstamp:3340429608 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.131843: rtcpu_vinotify_handle_msg: tstamp:3340430372 tag:ATOMP_FE channel:0x00 frame:24 vi_tstamp:3340429911 data:0x00000000
     kworker/4:2-218   [004] ...1   104.131844: rtcpu_vinotify_handle_msg: tstamp:3340454642 tag:ATOMP_FS channel:0x00 frame:25 vi_tstamp:3340454234 data:0x00000000
     kworker/4:2-218   [004] ...1   104.131845: rtcpu_vinotify_handle_msg: tstamp:3340462351 tag:CHANSEL_PXL_SOF channel:0x00 frame:25 vi_tstamp:3340461947 data:0x00000001
     kworker/4:2-218   [004] ...1   104.183329: rtcpu_vinotify_handle_msg: tstamp:3341470565 tag:CHANSEL_PXL_EOF channel:0x00 frame:25 vi_tstamp:3341469917 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.183333: rtcpu_vinotify_handle_msg: tstamp:3341470682 tag:ATOMP_FE channel:0x00 frame:25 vi_tstamp:3341470219 data:0x00000000
     kworker/4:2-218   [004] ...1   104.183335: rtos_queue_peek_from_isr_failed: tstamp:3341635181 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   104.347292: rtos_queue_peek_from_isr_failed: tstamp:3346635698 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   104.347297: rtcpu_vinotify_handle_msg: tstamp:3346696490 tag:ATOMP_FS channel:0x00 frame:31 vi_tstamp:3346696083 data:0x00000000
     kworker/4:2-218   [004] ...1   104.347298: rtcpu_vinotify_handle_msg: tstamp:3346704198 tag:CHANSEL_PXL_SOF channel:0x00 frame:31 vi_tstamp:3346703797 data:0x00000001
     kworker/4:2-218   [004] ...1   104.347299: rtcpu_vinotify_handle_msg: tstamp:3346704768 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:31 vi_tstamp:3346704334 data:0x08000000
     kworker/4:2-218   [004] ...1   104.347301: rtcpu_vinotify_handle_msg: tstamp:3346934244 tag:ATOMP_FS channel:0x02 frame:12 vi_tstamp:3346933840 data:0x00000000
     kworker/4:2-218   [004] ...1   104.347302: rtcpu_vinotify_handle_msg: tstamp:3346941955 tag:CHANSEL_PXL_SOF channel:0x02 frame:12 vi_tstamp:3346941554 data:0x00000001
     kworker/4:2-218   [004] ...1   104.347303: rtcpu_vinotify_handle_msg: tstamp:3346942528 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:12 vi_tstamp:3346942098 data:0x28000000
     kworker/4:2-218   [004] ...1   104.347304: rtcpu_vinotify_handle_msg: tstamp:3347712418 tag:CHANSEL_PXL_EOF channel:0x00 frame:31 vi_tstamp:3347711766 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.347305: rtcpu_vinotify_handle_msg: tstamp:3347712529 tag:ATOMP_FE channel:0x00 frame:31 vi_tstamp:3347712068 data:0x00000000
     kworker/4:2-218   [004] ...1   104.347306: rtcpu_vinotify_handle_msg: tstamp:3347736797 tag:ATOMP_FS channel:0x00 frame:32 vi_tstamp:3347736392 data:0x00000000
     kworker/4:2-218   [004] ...1   104.347307: rtcpu_vinotify_handle_msg: tstamp:3347744508 tag:CHANSEL_PXL_SOF channel:0x00 frame:32 vi_tstamp:3347744106 data:0x00000001
     kworker/4:2-218   [004] ...1   104.347308: rtcpu_vinotify_handle_msg: tstamp:3347745076 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:32 vi_tstamp:3347744645 data:0x08000000
     kworker/4:2-218   [004] ...1   104.347309: rtcpu_vinotify_handle_msg: tstamp:3347950171 tag:CHANSEL_PXL_EOF channel:0x02 frame:12 vi_tstamp:3347949523 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.347310: rtcpu_vinotify_handle_msg: tstamp:3347950283 tag:ATOMP_FE channel:0x02 frame:12 vi_tstamp:3347949824 data:0x00000000
     kworker/4:2-218   [004] ...1   104.347311: rtcpu_vinotify_handle_msg: tstamp:3347974557 tag:ATOMP_FS channel:0x02 frame:13 vi_tstamp:3347974148 data:0x00000000
     kworker/4:2-218   [004] ...1   104.347313: rtcpu_vinotify_handle_msg: tstamp:3347982263 tag:CHANSEL_PXL_SOF channel:0x02 frame:13 vi_tstamp:3347981861 data:0x00000001
     kworker/4:2-218   [004] ...1   104.347314: rtcpu_vinotify_handle_msg: tstamp:3347982827 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:13 vi_tstamp:3347982400 data:0x28000000
     kworker/4:2-218   [004] ...1   104.399277: rtcpu_vinotify_handle_msg: tstamp:3348752737 tag:CHANSEL_PXL_EOF channel:0x00 frame:32 vi_tstamp:3348752073 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.399281: rtcpu_vinotify_handle_msg: tstamp:3348752849 tag:ATOMP_FE channel:0x00 frame:32 vi_tstamp:3348752376 data:0x00000000
     kworker/4:2-218   [004] ...1   104.399282: rtcpu_vinotify_handle_msg: tstamp:3348777116 tag:ATOMP_FS channel:0x00 frame:33 vi_tstamp:3348776700 data:0x00000000
     kworker/4:2-218   [004] ...1   104.399283: rtcpu_vinotify_handle_msg: tstamp:3348784817 tag:CHANSEL_PXL_SOF channel:0x00 frame:33 vi_tstamp:3348784413 data:0x00000001
     kworker/4:2-218   [004] ...1   104.399284: rtcpu_vinotify_handle_msg: tstamp:3348785381 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:33 vi_tstamp:3348784953 data:0x08000000
     kworker/4:2-218   [004] ...1   104.399284: rtcpu_vinotify_handle_msg: tstamp:3348990483 tag:CHANSEL_PXL_EOF channel:0x02 frame:13 vi_tstamp:3348989831 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.399285: rtcpu_vinotify_handle_msg: tstamp:3348990593 tag:ATOMP_FE channel:0x02 frame:13 vi_tstamp:3348990133 data:0x00000000
     kworker/4:2-218   [004] ...1   104.399286: rtcpu_vinotify_handle_msg: tstamp:3349014864 tag:ATOMP_FS channel:0x02 frame:14 vi_tstamp:3349014456 data:0x00000000
     kworker/4:2-218   [004] ...1   104.399287: rtcpu_vinotify_handle_msg: tstamp:3349022576 tag:CHANSEL_PXL_SOF channel:0x02 frame:14 vi_tstamp:3349022169 data:0x00000001
     kworker/4:2-218   [004] ...1   104.399287: rtcpu_vinotify_handle_msg: tstamp:3349023138 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:14 vi_tstamp:3349022711 data:0x28000000
     kworker/4:2-218   [004] ...1   104.451261: rtcpu_vinotify_handle_msg: tstamp:3349793030 tag:CHANSEL_PXL_EOF channel:0x00 frame:33 vi_tstamp:3349792381 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.451264: rtcpu_vinotify_handle_msg: tstamp:3349793142 tag:ATOMP_FE channel:0x00 frame:33 vi_tstamp:3349792684 data:0x00000000
     kworker/4:2-218   [004] ...1   104.451264: rtcpu_vinotify_handle_msg: tstamp:3349817416 tag:ATOMP_FS channel:0x00 frame:34 vi_tstamp:3349817008 data:0x00000000
     kworker/4:2-218   [004] ...1   104.451265: rtcpu_vinotify_handle_msg: tstamp:3349825126 tag:CHANSEL_PXL_SOF channel:0x00 frame:34 vi_tstamp:3349824720 data:0x00000001
     kworker/4:2-218   [004] ...1   104.451266: rtcpu_vinotify_handle_msg: tstamp:3349825692 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:34 vi_tstamp:3349825262 data:0x08000000
     kworker/4:2-218   [004] ...1   104.451267: rtcpu_vinotify_handle_msg: tstamp:3350030801 tag:CHANSEL_PXL_EOF channel:0x02 frame:14 vi_tstamp:3350030139 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.451267: rtcpu_vinotify_handle_msg: tstamp:3350030932 tag:ATOMP_FE channel:0x02 frame:14 vi_tstamp:3350030441 data:0x00000000
     kworker/4:2-218   [004] ...1   104.451268: rtcpu_vinotify_handle_msg: tstamp:3350055189 tag:ATOMP_FS channel:0x02 frame:15 vi_tstamp:3350054765 data:0x00000000
     kworker/4:2-218   [004] ...1   104.451269: rtcpu_vinotify_handle_msg: tstamp:3350062895 tag:CHANSEL_PXL_SOF channel:0x02 frame:15 vi_tstamp:3350062477 data:0x00000001
     kworker/4:2-218   [004] ...1   104.451270: rtcpu_vinotify_handle_msg: tstamp:3350063499 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:15 vi_tstamp:3350063053 data:0x28000000
     kworker/4:2-218   [004] ...1   104.451271: rtcpu_vinotify_handle_msg: tstamp:3350328920 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3350328512 data:0x00000002
     kworker/4:2-218   [004] ...1   104.451271: rtcpu_vinotify_handle_msg: tstamp:3350833339 tag:CHANSEL_PXL_EOF channel:0x00 frame:34 vi_tstamp:3350832690 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.451272: rtcpu_vinotify_handle_msg: tstamp:3350833451 tag:ATOMP_FE channel:0x00 frame:34 vi_tstamp:3350832992 data:0x00000000
     kworker/4:2-218   [004] ...1   104.451273: rtcpu_vinotify_handle_msg: tstamp:3350857727 tag:ATOMP_FS channel:0x00 frame:35 vi_tstamp:3350857315 data:0x00000000
     kworker/4:2-218   [004] ...1   104.451274: rtcpu_vinotify_handle_msg: tstamp:3350865433 tag:CHANSEL_PXL_SOF channel:0x00 frame:35 vi_tstamp:3350865030 data:0x00000001
     kworker/4:2-218   [004] ...1   104.451274: rtcpu_vinotify_handle_msg: tstamp:3350866003 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:35 vi_tstamp:3350865570 data:0x08000000
     kworker/4:2-218   [004] ...1   104.451275: rtcpu_vinotify_handle_msg: tstamp:3351071097 tag:CHANSEL_PXL_EOF channel:0x02 frame:15 vi_tstamp:3351070447 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.451276: rtcpu_vinotify_handle_msg: tstamp:3351071207 tag:ATOMP_FE channel:0x02 frame:15 vi_tstamp:3351070749 data:0x00000000
     kworker/4:2-218   [004] ...1   104.451277: rtcpu_vinotify_handle_msg: tstamp:3351095481 tag:ATOMP_FS channel:0x02 frame:16 vi_tstamp:3351095073 data:0x00000000
     kworker/4:2-218   [004] ...1   104.451277: rtcpu_vinotify_handle_msg: tstamp:3351103199 tag:CHANSEL_PXL_SOF channel:0x02 frame:16 vi_tstamp:3351102787 data:0x00000001
     kworker/4:2-218   [004] ...1   104.451278: rtcpu_vinotify_handle_msg: tstamp:3351103764 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:16 vi_tstamp:3351103335 data:0x28000000
     kworker/4:2-218   [004] ...1   104.503237: rtcpu_vinotify_handle_msg: tstamp:3351369324 tag:CSIMUX_FRAME channel:0x00 frame:1 vi_tstamp:3351368713 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.503240: rtcpu_vinotify_handle_msg: tstamp:3351369447 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3351368821 data:0x00000002
     kworker/4:2-218   [004] ...1   104.503242: rtos_queue_peek_from_isr_failed: tstamp:3351636194 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   104.503242: rtcpu_vinotify_handle_msg: tstamp:3351873643 tag:CHANSEL_PXL_EOF channel:0x00 frame:35 vi_tstamp:3351872998 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.503243: rtcpu_vinotify_handle_msg: tstamp:3351873748 tag:ATOMP_FE channel:0x00 frame:35 vi_tstamp:3351873301 data:0x00000000
     kworker/4:2-218   [004] ...1   104.503244: rtcpu_vinotify_handle_msg: tstamp:3351898030 tag:ATOMP_FS channel:0x00 frame:36 vi_tstamp:3351897624 data:0x00000000
     kworker/4:2-218   [004] ...1   104.503245: rtcpu_vinotify_handle_msg: tstamp:3351905741 tag:CHANSEL_PXL_SOF channel:0x00 frame:36 vi_tstamp:3351905338 data:0x00000001
     kworker/4:2-218   [004] ...1   104.503245: rtcpu_vinotify_handle_msg: tstamp:3351906306 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:36 vi_tstamp:3351905878 data:0x08000000
     kworker/4:2-218   [004] ...1   104.503246: rtcpu_vinotify_handle_msg: tstamp:3352111403 tag:CHANSEL_PXL_EOF channel:0x02 frame:16 vi_tstamp:3352110755 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.503247: rtcpu_vinotify_handle_msg: tstamp:3352111516 tag:ATOMP_FE channel:0x02 frame:16 vi_tstamp:3352111057 data:0x00000000
     kworker/4:2-218   [004] ...1   104.503248: rtcpu_vinotify_handle_msg: tstamp:3352135790 tag:ATOMP_FS channel:0x02 frame:17 vi_tstamp:3352135381 data:0x00000000
     kworker/4:2-218   [004] ...1   104.503248: rtcpu_vinotify_handle_msg: tstamp:3352143499 tag:CHANSEL_PXL_SOF channel:0x02 frame:17 vi_tstamp:3352143094 data:0x00000001
     kworker/4:2-218   [004] ...1   104.503249: rtcpu_vinotify_handle_msg: tstamp:3352144065 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:17 vi_tstamp:3352143636 data:0x28000000
     kworker/4:2-218   [004] ...1   104.503250: rtcpu_vinotify_handle_msg: tstamp:3352409634 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:3352409021 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.503251: rtcpu_vinotify_handle_msg: tstamp:3352409758 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3352409127 data:0x00000002
     kworker/4:2-218   [004] ...1   104.503252: rtcpu_vinotify_handle_msg: tstamp:3352913951 tag:CHANSEL_PXL_EOF channel:0x00 frame:36 vi_tstamp:3352913306 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.503252: rtcpu_vinotify_handle_msg: tstamp:3352914062 tag:ATOMP_FE channel:0x00 frame:36 vi_tstamp:3352913609 data:0x00000000
     kworker/4:2-218   [004] ...1   104.555229: rtcpu_vinotify_handle_msg: tstamp:3352938343 tag:ATOMP_FS channel:0x00 frame:37 vi_tstamp:3352937932 data:0x00000000
     kworker/4:2-218   [004] ...1   104.555232: rtcpu_vinotify_handle_msg: tstamp:3352946051 tag:CHANSEL_PXL_SOF channel:0x00 frame:37 vi_tstamp:3352945646 data:0x00000001
     kworker/4:2-218   [004] ...1   104.555233: rtcpu_vinotify_handle_msg: tstamp:3352946619 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:37 vi_tstamp:3352946189 data:0x08000000
     kworker/4:2-218   [004] ...1   104.555234: rtcpu_vinotify_handle_msg: tstamp:3353151712 tag:CHANSEL_PXL_EOF channel:0x02 frame:17 vi_tstamp:3353151064 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.555235: rtcpu_vinotify_handle_msg: tstamp:3353151824 tag:ATOMP_FE channel:0x02 frame:17 vi_tstamp:3353151366 data:0x00000000
     kworker/4:2-218   [004] ...1   104.555236: rtcpu_vinotify_handle_msg: tstamp:3353176096 tag:ATOMP_FS channel:0x02 frame:18 vi_tstamp:3353175689 data:0x00000000
     kworker/4:2-218   [004] ...1   104.555236: rtcpu_vinotify_handle_msg: tstamp:3353183805 tag:CHANSEL_PXL_SOF channel:0x02 frame:18 vi_tstamp:3353183403 data:0x00000001
     kworker/4:2-218   [004] ...1   104.555237: rtcpu_vinotify_handle_msg: tstamp:3353184394 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:18 vi_tstamp:3353183967 data:0x28000000
     kworker/4:2-218   [004] ...1   104.555238: rtcpu_vinotify_handle_msg: tstamp:3353449939 tag:CSIMUX_FRAME channel:0x00 frame:3 vi_tstamp:3353449329 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.555239: rtcpu_vinotify_handle_msg: tstamp:3353450062 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3353449436 data:0x00000002
     kworker/4:2-218   [004] ...1   104.555240: rtcpu_vinotify_handle_msg: tstamp:3353954262 tag:CHANSEL_PXL_EOF channel:0x00 frame:37 vi_tstamp:3353953614 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.555240: rtcpu_vinotify_handle_msg: tstamp:3353954374 tag:ATOMP_FE channel:0x00 frame:37 vi_tstamp:3353953917 data:0x00000000
     kworker/4:2-218   [004] ...1   104.555241: rtcpu_vinotify_handle_msg: tstamp:3353978650 tag:ATOMP_FS channel:0x00 frame:38 vi_tstamp:3353978240 data:0x00000000
     kworker/4:2-218   [004] ...1   104.555242: rtcpu_vinotify_handle_msg: tstamp:3353986358 tag:CHANSEL_PXL_SOF channel:0x00 frame:38 vi_tstamp:3353985954 data:0x00000001
     kworker/4:2-218   [004] ...1   104.555243: rtcpu_vinotify_handle_msg: tstamp:3353986922 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:38 vi_tstamp:3353986494 data:0x08000000
     kworker/4:2-218   [004] ...1   104.555244: rtcpu_vinotify_handle_msg: tstamp:3354192029 tag:CHANSEL_PXL_EOF channel:0x02 frame:18 vi_tstamp:3354191372 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.555244: rtcpu_vinotify_handle_msg: tstamp:3354192134 tag:ATOMP_FE channel:0x02 frame:18 vi_tstamp:3354191674 data:0x00000000
     kworker/4:2-218   [004] ...1   104.555245: rtcpu_vinotify_handle_msg: tstamp:3354216419 tag:ATOMP_FS channel:0x02 frame:19 vi_tstamp:3354215998 data:0x00000000
     kworker/4:2-218   [004] ...1   104.555246: rtcpu_vinotify_handle_msg: tstamp:3354224112 tag:CHANSEL_PXL_SOF channel:0x02 frame:19 vi_tstamp:3354223710 data:0x00000001
     kworker/4:2-218   [004] ...1   104.555247: rtcpu_vinotify_handle_msg: tstamp:3354224679 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:19 vi_tstamp:3354224250 data:0x28000000
     kworker/4:2-218   [004] ...1   104.555247: rtcpu_vinotify_handle_msg: tstamp:3354490249 tag:CSIMUX_FRAME channel:0x00 frame:4 vi_tstamp:3354489637 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.555248: rtcpu_vinotify_handle_msg: tstamp:3354490376 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3354489745 data:0x00000002
     kworker/4:2-218   [004] ...1   104.613383: rtcpu_vinotify_handle_msg: tstamp:3354994571 tag:CHANSEL_PXL_EOF channel:0x00 frame:38 vi_tstamp:3354993923 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.613385: rtcpu_vinotify_handle_msg: tstamp:3354994683 tag:ATOMP_FE channel:0x00 frame:38 vi_tstamp:3354994225 data:0x00000000
     kworker/4:2-218   [004] ...1   104.613386: rtcpu_vinotify_handle_msg: tstamp:3355018959 tag:ATOMP_FS channel:0x00 frame:39 vi_tstamp:3355018548 data:0x00000000
     kworker/4:2-218   [004] ...1   104.613387: rtcpu_vinotify_handle_msg: tstamp:3355026665 tag:CHANSEL_PXL_SOF channel:0x00 frame:39 vi_tstamp:3355026262 data:0x00000001
     kworker/4:2-218   [004] ...1   104.613388: rtcpu_vinotify_handle_msg: tstamp:3355027228 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:39 vi_tstamp:3355026802 data:0x08000000
     kworker/4:2-218   [004] ...1   104.613389: rtcpu_vinotify_handle_msg: tstamp:3355232325 tag:CHANSEL_PXL_EOF channel:0x02 frame:19 vi_tstamp:3355231679 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.613390: rtcpu_vinotify_handle_msg: tstamp:3355232430 tag:ATOMP_FE channel:0x02 frame:19 vi_tstamp:3355231982 data:0x00000000
     kworker/4:2-218   [004] ...1   104.613390: rtcpu_vinotify_handle_msg: tstamp:3355256715 tag:ATOMP_FS channel:0x02 frame:20 vi_tstamp:3355256305 data:0x00000000
     kworker/4:2-218   [004] ...1   104.613391: rtcpu_vinotify_handle_msg: tstamp:3355264445 tag:CHANSEL_PXL_SOF channel:0x02 frame:20 vi_tstamp:3355264020 data:0x00000001
     kworker/4:2-218   [004] ...1   104.613392: rtcpu_vinotify_handle_msg: tstamp:3355265013 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:20 vi_tstamp:3355264584 data:0x28000000
     kworker/4:2-218   [004] ...1   104.613393: rtcpu_vinotify_handle_msg: tstamp:3355530554 tag:CSIMUX_FRAME channel:0x00 frame:5 vi_tstamp:3355529945 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.613394: rtcpu_vinotify_handle_msg: tstamp:3355530683 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3355530052 data:0x00000002
     kworker/4:2-218   [004] ...1   104.613395: rtcpu_vinotify_handle_msg: tstamp:3356034883 tag:CHANSEL_PXL_EOF channel:0x00 frame:39 vi_tstamp:3356034231 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.613395: rtcpu_vinotify_handle_msg: tstamp:3356034994 tag:ATOMP_FE channel:0x00 frame:39 vi_tstamp:3356034534 data:0x00000000
     kworker/4:2-218   [004] ...1   104.613396: rtcpu_vinotify_handle_msg: tstamp:3356059262 tag:ATOMP_FS channel:0x00 frame:40 vi_tstamp:3356058857 data:0x00000000
     kworker/4:2-218   [004] ...1   104.613397: rtcpu_vinotify_handle_msg: tstamp:3356066974 tag:CHANSEL_PXL_SOF channel:0x00 frame:40 vi_tstamp:3356066571 data:0x00000001
     kworker/4:2-218   [004] ...1   104.613398: rtcpu_vinotify_handle_msg: tstamp:3356105897 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:40 vi_tstamp:3356105492 data:0x08000000
     kworker/4:2-218   [004] ...1   104.613398: rtcpu_vinotify_handle_msg: tstamp:3356272639 tag:CHANSEL_PXL_EOF channel:0x02 frame:20 vi_tstamp:3356271988 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.613399: rtcpu_vinotify_handle_msg: tstamp:3356272744 tag:ATOMP_FE channel:0x02 frame:20 vi_tstamp:3356272290 data:0x00000000
     kworker/4:2-218   [004] ...1   104.613400: rtcpu_vinotify_handle_msg: tstamp:3356297022 tag:ATOMP_FS channel:0x02 frame:21 vi_tstamp:3356296613 data:0x00000000
     kworker/4:2-218   [004] ...1   104.613401: rtcpu_vinotify_handle_msg: tstamp:3356304732 tag:CHANSEL_PXL_SOF channel:0x02 frame:21 vi_tstamp:3356304326 data:0x00000001
     kworker/4:2-218   [004] ...1   104.663180: rtcpu_vinotify_handle_msg: tstamp:3356374008 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:21 vi_tstamp:3356373601 data:0x28000000
     kworker/4:2-218   [004] ...1   104.663183: rtcpu_vinotify_handle_msg: tstamp:3356570866 tag:CSIMUX_FRAME channel:0x00 frame:6 vi_tstamp:3356570254 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.663184: rtcpu_vinotify_handle_msg: tstamp:3356570985 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3356570360 data:0x00000002
     kworker/4:2-218   [004] ...1   104.663186: rtos_queue_peek_from_isr_failed: tstamp:3356636705 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   104.663187: rtcpu_vinotify_handle_msg: tstamp:3357075192 tag:CHANSEL_PXL_EOF channel:0x00 frame:40 vi_tstamp:3357074539 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.663188: rtcpu_vinotify_handle_msg: tstamp:3357075302 tag:ATOMP_FE channel:0x00 frame:40 vi_tstamp:3357074841 data:0x00000000
     kworker/4:2-218   [004] ...1   104.663188: rtcpu_vinotify_handle_msg: tstamp:3357099573 tag:ATOMP_FS channel:0x00 frame:41 vi_tstamp:3357099165 data:0x00000000
     kworker/4:2-218   [004] ...1   104.663189: rtcpu_vinotify_handle_msg: tstamp:3357107283 tag:CHANSEL_PXL_SOF channel:0x00 frame:41 vi_tstamp:3357106879 data:0x00000001
     kworker/4:2-218   [004] ...1   104.663190: rtcpu_vinotify_handle_msg: tstamp:3357312940 tag:CHANSEL_PXL_EOF channel:0x02 frame:21 vi_tstamp:3357312296 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.663191: rtcpu_vinotify_handle_msg: tstamp:3357313066 tag:ATOMP_FE channel:0x02 frame:21 vi_tstamp:3357312598 data:0x00000000
     kworker/4:2-218   [004] ...1   104.663192: rtcpu_vinotify_handle_msg: tstamp:3357337332 tag:ATOMP_FS channel:0x02 frame:22 vi_tstamp:3357336921 data:0x00000000
     kworker/4:2-218   [004] ...1   104.663192: rtcpu_vinotify_handle_msg: tstamp:3357345038 tag:CHANSEL_PXL_SOF channel:0x02 frame:22 vi_tstamp:3357344636 data:0x00000001
     kworker/4:2-218   [004] ...1   104.663193: rtcpu_vinotify_handle_msg: tstamp:3357534247 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:41 vi_tstamp:3357533833 data:0x08000000
     kworker/4:2-218   [004] ...1   104.663194: rtcpu_vinotify_handle_msg: tstamp:3357611162 tag:CSIMUX_FRAME channel:0x00 frame:7 vi_tstamp:3357610562 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.663195: rtcpu_vinotify_handle_msg: tstamp:3357611280 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3357610669 data:0x00000002
     kworker/4:2-218   [004] ...1   104.715172: rtcpu_vinotify_handle_msg: tstamp:3357943722 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:22 vi_tstamp:3357943310 data:0x28000000
     kworker/4:2-218   [004] ...1   104.715176: rtcpu_vinotify_handle_msg: tstamp:3358115493 tag:CHANSEL_PXL_EOF channel:0x00 frame:41 vi_tstamp:3358114847 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.715176: rtcpu_vinotify_handle_msg: tstamp:3358115606 tag:ATOMP_FE channel:0x00 frame:41 vi_tstamp:3358115149 data:0x00000000
     kworker/4:2-218   [004] ...1   104.715177: rtcpu_vinotify_handle_msg: tstamp:3358139881 tag:ATOMP_FS channel:0x00 frame:42 vi_tstamp:3358139473 data:0x00000000
     kworker/4:2-218   [004] ...1   104.715178: rtcpu_vinotify_handle_msg: tstamp:3358147591 tag:CHANSEL_PXL_SOF channel:0x00 frame:42 vi_tstamp:3358147186 data:0x00000001
     kworker/4:2-218   [004] ...1   104.715181: rtcpu_vinotify_handle_msg: tstamp:3358148156 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:42 vi_tstamp:3358147728 data:0x08000000
     kworker/4:2-218   [004] ...1   104.715181: rtcpu_vinotify_handle_msg: tstamp:3358353253 tag:CHANSEL_PXL_EOF channel:0x02 frame:22 vi_tstamp:3358352604 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.715182: rtcpu_vinotify_handle_msg: tstamp:3358353363 tag:ATOMP_FE channel:0x02 frame:22 vi_tstamp:3358352907 data:0x00000000
     kworker/4:2-218   [004] ...1   104.715183: rtcpu_vinotify_handle_msg: tstamp:3358377642 tag:ATOMP_FS channel:0x02 frame:23 vi_tstamp:3358377230 data:0x00000000
     kworker/4:2-218   [004] ...1   104.715184: rtcpu_vinotify_handle_msg: tstamp:3358385347 tag:CHANSEL_PXL_SOF channel:0x02 frame:23 vi_tstamp:3358384943 data:0x00000001
     kworker/4:2-218   [004] ...1   104.715185: rtcpu_vinotify_handle_msg: tstamp:3358651479 tag:CSIMUX_FRAME channel:0x00 frame:8 vi_tstamp:3358650869 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.715186: rtcpu_vinotify_handle_msg: tstamp:3358651604 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3358650979 data:0x00000002
     kworker/4:2-218   [004] ...1   104.715187: rtcpu_vinotify_handle_msg: tstamp:3359155809 tag:CHANSEL_PXL_EOF channel:0x00 frame:42 vi_tstamp:3359155155 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.715188: rtcpu_vinotify_handle_msg: tstamp:3359155926 tag:ATOMP_FE channel:0x00 frame:42 vi_tstamp:3359155457 data:0x00000000
     kworker/4:2-218   [004] ...1   104.715189: rtcpu_vinotify_handle_msg: tstamp:3359180195 tag:ATOMP_FS channel:0x00 frame:43 vi_tstamp:3359179781 data:0x00000000
     kworker/4:2-218   [004] ...1   104.715189: rtcpu_vinotify_handle_msg: tstamp:3359187901 tag:CHANSEL_PXL_SOF channel:0x00 frame:43 vi_tstamp:3359187494 data:0x00000001
     kworker/4:2-218   [004] ...1   104.715190: rtcpu_vinotify_handle_msg: tstamp:3359393563 tag:CHANSEL_PXL_EOF channel:0x02 frame:23 vi_tstamp:3359392912 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.715191: rtcpu_vinotify_handle_msg: tstamp:3359393674 tag:ATOMP_FE channel:0x02 frame:23 vi_tstamp:3359393215 data:0x00000000
     kworker/4:2-218   [004] ...1   104.767158: rtcpu_vinotify_handle_msg: tstamp:3359691920 tag:CSIMUX_FRAME channel:0x00 frame:9 vi_tstamp:3359691178 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.767162: rtcpu_vinotify_handle_msg: tstamp:3359692064 tag:ATOMP_FS channel:0x01 frame:10 vi_tstamp:3359691195 data:0x00000000
     kworker/4:2-218   [004] ...1   104.767163: rtcpu_vinotify_handle_msg: tstamp:3359692169 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3359691285 data:0x00000002
     kworker/4:2-218   [004] ...1   104.767164: rtcpu_vinotify_handle_msg: tstamp:3359979063 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:43 vi_tstamp:3359978649 data:0x08000000
     kworker/4:2-218   [004] ...1   104.767166: rtcpu_vinotify_handle_msg: tstamp:3360196113 tag:CHANSEL_PXL_EOF channel:0x00 frame:43 vi_tstamp:3360195463 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.767167: rtcpu_vinotify_handle_msg: tstamp:3360196226 tag:ATOMP_FE channel:0x00 frame:43 vi_tstamp:3360195766 data:0x00000000
     kworker/4:2-218   [004] ...1   104.767168: rtcpu_vinotify_handle_msg: tstamp:3360220496 tag:ATOMP_FS channel:0x00 frame:44 vi_tstamp:3360220089 data:0x00000000
     kworker/4:2-218   [004] ...1   104.767169: rtcpu_vinotify_handle_msg: tstamp:3360228207 tag:CHANSEL_PXL_SOF channel:0x00 frame:44 vi_tstamp:3360227803 data:0x00000001
     kworker/4:2-218   [004] ...1   104.767170: rtcpu_vinotify_handle_msg: tstamp:3360228681 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:44 vi_tstamp:3360228332 data:0x08000000
     kworker/4:2-218   [004] ...1   104.767172: rtcpu_vinotify_handle_msg: tstamp:3360458259 tag:ATOMP_FS channel:0x02 frame:25 vi_tstamp:3360457846 data:0x00000000
     kworker/4:2-218   [004] ...1   104.767173: rtcpu_vinotify_handle_msg: tstamp:3360465961 tag:CHANSEL_PXL_SOF channel:0x02 frame:25 vi_tstamp:3360465561 data:0x00000001
     kworker/4:2-218   [004] ...1   104.767174: rtcpu_vinotify_handle_msg: tstamp:3360466536 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:25 vi_tstamp:3360466092 data:0x28000000
     kworker/4:2-218   [004] ...1   104.767175: rtcpu_vinotify_handle_msg: tstamp:3360732391 tag:CSIMUX_FRAME channel:0x00 frame:10 vi_tstamp:3360731486 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.767177: rtcpu_vinotify_handle_msg: tstamp:3360732528 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:10 vi_tstamp:3360731487 data:0x00000002
     kworker/4:2-218   [004] ...1   104.767178: rtcpu_vinotify_handle_msg: tstamp:3360732659 tag:ATOMP_FE channel:0x01 frame:10 vi_tstamp:3360731487 data:0x00000000
     kworker/4:2-218   [004] ...1   104.767179: rtcpu_vinotify_handle_msg: tstamp:3360732772 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3360731597 data:0x00000002
     kworker/4:2-218   [004] ...1   104.819146: rtcpu_vinotify_handle_msg: tstamp:3361236418 tag:CHANSEL_PXL_EOF channel:0x00 frame:44 vi_tstamp:3361235771 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.819151: rtcpu_vinotify_handle_msg: tstamp:3361236535 tag:ATOMP_FE channel:0x00 frame:44 vi_tstamp:3361236074 data:0x00000000
     kworker/4:2-218   [004] ...1   104.819153: rtcpu_vinotify_handle_msg: tstamp:3361260805 tag:ATOMP_FS channel:0x00 frame:45 vi_tstamp:3361260398 data:0x00000000
     kworker/4:2-218   [004] ...1   104.819154: rtcpu_vinotify_handle_msg: tstamp:3361268519 tag:CHANSEL_PXL_SOF channel:0x00 frame:45 vi_tstamp:3361268111 data:0x00000001
     kworker/4:2-218   [004] ...1   104.819156: rtcpu_vinotify_handle_msg: tstamp:3361269088 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:45 vi_tstamp:3361268661 data:0x08000000
     kworker/4:2-218   [004] ...1   104.819157: rtcpu_vinotify_handle_msg: tstamp:3361474192 tag:CHANSEL_PXL_EOF channel:0x02 frame:25 vi_tstamp:3361473529 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.819159: rtcpu_vinotify_handle_msg: tstamp:3361474307 tag:ATOMP_FE channel:0x02 frame:25 vi_tstamp:3361473831 data:0x00000000
     kworker/4:2-218   [004] ...1   104.819160: rtcpu_vinotify_handle_msg: tstamp:3361498561 tag:ATOMP_FS channel:0x02 frame:26 vi_tstamp:3361498154 data:0x00000000
     kworker/4:2-218   [004] ...1   104.819162: rtcpu_vinotify_handle_msg: tstamp:3361506274 tag:CHANSEL_PXL_SOF channel:0x02 frame:26 vi_tstamp:3361505869 data:0x00000001
     kworker/4:2-218   [004] ...1   104.819166: rtos_queue_peek_from_isr_failed: tstamp:3361637218 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   104.819167: rtcpu_vinotify_handle_msg: tstamp:3361772404 tag:CSIMUX_FRAME channel:0x00 frame:11 vi_tstamp:3361771794 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.819169: rtcpu_vinotify_handle_msg: tstamp:3361772544 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3361771905 data:0x00000002
     kworker/4:2-218   [004] ...1   104.819170: rtcpu_vinotify_handle_msg: tstamp:3361850415 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:26 vi_tstamp:3361850005 data:0x28000000
     kworker/4:2-218   [004] ...1   104.819172: rtcpu_vinotify_handle_msg: tstamp:3362276731 tag:CHANSEL_PXL_EOF channel:0x00 frame:45 vi_tstamp:3362276079 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.819173: rtcpu_vinotify_handle_msg: tstamp:3362276849 tag:ATOMP_FE channel:0x00 frame:45 vi_tstamp:3362276382 data:0x00000000
     kworker/4:2-218   [004] ...1   104.819175: rtcpu_vinotify_handle_msg: tstamp:3362301117 tag:ATOMP_FS channel:0x00 frame:46 vi_tstamp:3362300705 data:0x00000000
     kworker/4:2-218   [004] ...1   104.819176: rtcpu_vinotify_handle_msg: tstamp:3362308827 tag:CHANSEL_PXL_SOF channel:0x00 frame:46 vi_tstamp:3362308419 data:0x00000001
     kworker/4:2-218   [004] ...1   104.819178: rtcpu_vinotify_handle_msg: tstamp:3362514490 tag:CHANSEL_PXL_EOF channel:0x02 frame:26 vi_tstamp:3362513837 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.819179: rtcpu_vinotify_handle_msg: tstamp:3362514613 tag:ATOMP_FE channel:0x02 frame:26 vi_tstamp:3362514139 data:0x00000000
     kworker/4:2-218   [004] ...1   104.819181: rtcpu_vinotify_handle_msg: tstamp:3362538874 tag:ATOMP_FS channel:0x02 frame:27 vi_tstamp:3362538463 data:0x00000000
     kworker/4:2-218   [004] ...1   104.819182: rtcpu_vinotify_handle_msg: tstamp:3362546582 tag:CHANSEL_PXL_SOF channel:0x02 frame:27 vi_tstamp:3362546176 data:0x00000001
     kworker/4:2-218   [004] ...1   104.871143: rtcpu_vinotify_handle_msg: tstamp:3362812717 tag:CSIMUX_FRAME channel:0x00 frame:12 vi_tstamp:3362812102 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.871148: rtcpu_vinotify_handle_msg: tstamp:3362812854 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3362812210 data:0x00000002
     kworker/4:2-218   [004] ...1   104.871150: rtcpu_vinotify_handle_msg: tstamp:3363271273 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:27 vi_tstamp:3363270840 data:0x28000000
     kworker/4:2-218   [004] ...1   104.871151: rtcpu_vinotify_handle_msg: tstamp:3363280038 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:46 vi_tstamp:3363279621 data:0x08000000
     kworker/4:2-218   [004] ...1   104.871153: rtcpu_vinotify_handle_msg: tstamp:3363317034 tag:CHANSEL_PXL_EOF channel:0x00 frame:46 vi_tstamp:3363316388 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.871154: rtcpu_vinotify_handle_msg: tstamp:3363317148 tag:ATOMP_FE channel:0x00 frame:46 vi_tstamp:3363316690 data:0x00000000
     kworker/4:2-218   [004] ...1   104.871156: rtcpu_vinotify_handle_msg: tstamp:3363341427 tag:ATOMP_FS channel:0x00 frame:47 vi_tstamp:3363341013 data:0x00000000
     kworker/4:2-218   [004] ...1   104.871158: rtcpu_vinotify_handle_msg: tstamp:3363349138 tag:CHANSEL_PXL_SOF channel:0x00 frame:47 vi_tstamp:3363348727 data:0x00000001
     kworker/4:2-218   [004] ...1   104.871159: rtcpu_vinotify_handle_msg: tstamp:3363551303 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:47 vi_tstamp:3363550887 data:0x08000000
     kworker/4:2-218   [004] ...1   104.871161: rtcpu_vinotify_handle_msg: tstamp:3363554790 tag:CHANSEL_PXL_EOF channel:0x02 frame:27 vi_tstamp:3363554145 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.871162: rtcpu_vinotify_handle_msg: tstamp:3363554899 tag:ATOMP_FE channel:0x02 frame:27 vi_tstamp:3363554447 data:0x00000000
     kworker/4:2-218   [004] ...1   104.871163: rtcpu_vinotify_handle_msg: tstamp:3363579186 tag:ATOMP_FS channel:0x02 frame:28 vi_tstamp:3363578771 data:0x00000000
     kworker/4:2-218   [004] ...1   104.871165: rtcpu_vinotify_handle_msg: tstamp:3363586892 tag:CHANSEL_PXL_SOF channel:0x02 frame:28 vi_tstamp:3363586485 data:0x00000001
     kworker/4:2-218   [004] ...1   104.871166: rtcpu_vinotify_handle_msg: tstamp:3363824467 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:28 vi_tstamp:3363824058 data:0x28000000
     kworker/4:2-218   [004] ...1   104.871168: rtcpu_vinotify_handle_msg: tstamp:3363853013 tag:CSIMUX_FRAME channel:0x00 frame:13 vi_tstamp:3363852410 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.871169: rtcpu_vinotify_handle_msg: tstamp:3363853138 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3363852522 data:0x00000002
     kworker/4:2-218   [004] ...1   104.871171: rtcpu_vinotify_handle_msg: tstamp:3364357344 tag:CHANSEL_PXL_EOF channel:0x00 frame:47 vi_tstamp:3364356696 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.871172: rtcpu_vinotify_handle_msg: tstamp:3364357459 tag:ATOMP_FE channel:0x00 frame:47 vi_tstamp:3364356999 data:0x00000000
     kworker/4:2-218   [004] ...1   104.871174: rtcpu_vinotify_handle_msg: tstamp:3364381728 tag:ATOMP_FS channel:0x00 frame:48 vi_tstamp:3364381321 data:0x00000000
     kworker/4:2-218   [004] ...1   104.871175: rtcpu_vinotify_handle_msg: tstamp:3364389439 tag:CHANSEL_PXL_SOF channel:0x00 frame:48 vi_tstamp:3364389036 data:0x00000001
     kworker/4:2-218   [004] ...1   104.930352: rtcpu_vinotify_handle_msg: tstamp:3364595096 tag:CHANSEL_PXL_EOF channel:0x02 frame:28 vi_tstamp:3364594453 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.930357: rtcpu_vinotify_handle_msg: tstamp:3364595208 tag:ATOMP_FE channel:0x02 frame:28 vi_tstamp:3364594755 data:0x00000000
     kworker/4:2-218   [004] ...1   104.930359: rtcpu_vinotify_handle_msg: tstamp:3364619486 tag:ATOMP_FS channel:0x02 frame:29 vi_tstamp:3364619079 data:0x00000000
     kworker/4:2-218   [004] ...1   104.930361: rtcpu_vinotify_handle_msg: tstamp:3364627194 tag:CHANSEL_PXL_SOF channel:0x02 frame:29 vi_tstamp:3364626791 data:0x00000001
     kworker/4:2-218   [004] ...1   104.930363: rtcpu_vinotify_handle_msg: tstamp:3364700101 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:48 vi_tstamp:3364699697 data:0x08000000
     kworker/4:2-218   [004] ...1   104.930365: rtcpu_vinotify_handle_msg: tstamp:3364893330 tag:CSIMUX_FRAME channel:0x00 frame:14 vi_tstamp:3364892719 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.930366: rtcpu_vinotify_handle_msg: tstamp:3364893454 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3364892829 data:0x00000002
     kworker/4:2-218   [004] ...1   104.930368: rtcpu_vinotify_handle_msg: tstamp:3364973528 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:29 vi_tstamp:3364973119 data:0x28000000
     kworker/4:2-218   [004] ...1   104.930370: rtcpu_vinotify_handle_msg: tstamp:3365397653 tag:CHANSEL_PXL_EOF channel:0x00 frame:48 vi_tstamp:3365397004 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.930372: rtcpu_vinotify_handle_msg: tstamp:3365397770 tag:ATOMP_FE channel:0x00 frame:48 vi_tstamp:3365397307 data:0x00000000
     kworker/4:2-218   [004] ...1   104.930374: rtcpu_vinotify_handle_msg: tstamp:3365422038 tag:ATOMP_FS channel:0x00 frame:49 vi_tstamp:3365421630 data:0x00000000
     kworker/4:2-218   [004] ...1   104.930376: rtcpu_vinotify_handle_msg: tstamp:3365429747 tag:CHANSEL_PXL_SOF channel:0x00 frame:49 vi_tstamp:3365429343 data:0x00000001
     kworker/4:2-218   [004] ...1   104.930377: rtcpu_vinotify_handle_msg: tstamp:3365430314 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:49 vi_tstamp:3365429884 data:0x08000000
     kworker/4:2-218   [004] ...1   104.930379: rtcpu_vinotify_handle_msg: tstamp:3365635408 tag:CHANSEL_PXL_EOF channel:0x02 frame:29 vi_tstamp:3365634762 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.930381: rtcpu_vinotify_handle_msg: tstamp:3365635514 tag:ATOMP_FE channel:0x02 frame:29 vi_tstamp:3365635063 data:0x00000000
     kworker/4:2-218   [004] ...1   104.930383: rtcpu_vinotify_handle_msg: tstamp:3365659796 tag:ATOMP_FS channel:0x02 frame:30 vi_tstamp:3365659387 data:0x00000000
     kworker/4:2-218   [004] ...1   104.930384: rtcpu_vinotify_handle_msg: tstamp:3365667505 tag:CHANSEL_PXL_SOF channel:0x02 frame:30 vi_tstamp:3365667101 data:0x00000001
     kworker/4:2-218   [004] ...1   104.930386: rtcpu_vinotify_handle_msg: tstamp:3365933637 tag:CSIMUX_FRAME channel:0x00 frame:15 vi_tstamp:3365933027 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.930388: rtcpu_vinotify_handle_msg: tstamp:3365933768 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3365933134 data:0x00000002
     kworker/4:2-218   [004] ...1   104.979109: rtcpu_vinotify_handle_msg: tstamp:3366437964 tag:CHANSEL_PXL_EOF channel:0x00 frame:49 vi_tstamp:3366437312 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.979115: rtcpu_vinotify_handle_msg: tstamp:3366438077 tag:ATOMP_FE channel:0x00 frame:49 vi_tstamp:3366437615 data:0x00000000
     kworker/4:2-218   [004] ...1   104.979117: rtcpu_vinotify_handle_msg: tstamp:3366462345 tag:ATOMP_FS channel:0x00 frame:50 vi_tstamp:3366461938 data:0x00000000
     kworker/4:2-218   [004] ...1   104.979118: rtcpu_vinotify_handle_msg: tstamp:3366470056 tag:CHANSEL_PXL_SOF channel:0x00 frame:50 vi_tstamp:3366469651 data:0x00000001
     kworker/4:2-218   [004] ...1   104.979120: rtcpu_vinotify_handle_msg: tstamp:3366470621 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:50 vi_tstamp:3366470179 data:0x08000000
     kworker/4:2-218   [004] ...1   104.979122: rtcpu_vinotify_handle_msg: tstamp:3366555630 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:30 vi_tstamp:3366555225 data:0x28000000
     kworker/4:2-218   [004] ...1   104.979126: rtos_queue_peek_from_isr_failed: tstamp:3366637716 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   104.979128: rtcpu_vinotify_handle_msg: tstamp:3366675713 tag:CHANSEL_PXL_EOF channel:0x02 frame:30 vi_tstamp:3366675069 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.979130: rtcpu_vinotify_handle_msg: tstamp:3366675819 tag:ATOMP_FE channel:0x02 frame:30 vi_tstamp:3366675372 data:0x00000000
     kworker/4:2-218   [004] ...1   104.979132: rtcpu_vinotify_handle_msg: tstamp:3366700109 tag:ATOMP_FS channel:0x02 frame:31 vi_tstamp:3366699695 data:0x00000000
     kworker/4:2-218   [004] ...1   104.979134: rtcpu_vinotify_handle_msg: tstamp:3366707812 tag:CHANSEL_PXL_SOF channel:0x02 frame:31 vi_tstamp:3366707408 data:0x00000001
     kworker/4:2-218   [004] ...1   104.979135: rtcpu_vinotify_handle_msg: tstamp:3366708289 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:31 vi_tstamp:3366707937 data:0x28000000
     kworker/4:2-218   [004] ...1   104.979137: rtcpu_vinotify_handle_msg: tstamp:3366973949 tag:CSIMUX_FRAME channel:0x00 frame:16 vi_tstamp:3366973335 data:0x000000a0
     kworker/4:2-218   [004] ...1   104.979139: rtcpu_vinotify_handle_msg: tstamp:3366974081 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3366973444 data:0x00000002
     kworker/4:2-218   [004] ...1   104.979141: rtcpu_vinotify_handle_msg: tstamp:3367478271 tag:CHANSEL_PXL_EOF channel:0x00 frame:50 vi_tstamp:3367477620 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.979142: rtcpu_vinotify_handle_msg: tstamp:3367478391 tag:ATOMP_FE channel:0x00 frame:50 vi_tstamp:3367477923 data:0x00000000
     kworker/4:2-218   [004] ...1   104.979144: rtcpu_vinotify_handle_msg: tstamp:3367502652 tag:ATOMP_FS channel:0x00 frame:51 vi_tstamp:3367502246 data:0x00000000
     kworker/4:2-218   [004] ...1   104.979146: rtcpu_vinotify_handle_msg: tstamp:3367510364 tag:CHANSEL_PXL_SOF channel:0x00 frame:51 vi_tstamp:3367509960 data:0x00000001
     kworker/4:2-218   [004] ...1   104.979148: rtcpu_vinotify_handle_msg: tstamp:3367568570 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:51 vi_tstamp:3367568165 data:0x08000000
     kworker/4:2-218   [004] ...1   104.979150: rtcpu_vinotify_handle_msg: tstamp:3367716036 tag:CHANSEL_PXL_EOF channel:0x02 frame:31 vi_tstamp:3367715377 data:0x0da70002
     kworker/4:2-218   [004] ...1   104.979151: rtcpu_vinotify_handle_msg: tstamp:3367716146 tag:ATOMP_FE channel:0x02 frame:31 vi_tstamp:3367715680 data:0x00000000
     kworker/4:2-218   [004] ...1   104.979153: rtcpu_vinotify_handle_msg: tstamp:3367740412 tag:ATOMP_FS channel:0x02 frame:32 vi_tstamp:3367740003 data:0x00000000
     kworker/4:2-218   [004] ...1   104.979155: rtcpu_vinotify_handle_msg: tstamp:3367748122 tag:CHANSEL_PXL_SOF channel:0x02 frame:32 vi_tstamp:3367747716 data:0x00000001
     kworker/4:2-218   [004] ...1   105.031092: rtcpu_vinotify_handle_msg: tstamp:3368014259 tag:CSIMUX_FRAME channel:0x00 frame:17 vi_tstamp:3368013643 data:0x000000a0
     kworker/4:2-218   [004] ...1   105.031098: rtcpu_vinotify_handle_msg: tstamp:3368014390 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3368013752 data:0x00000002
     kworker/4:2-218   [004] ...1   105.031100: rtcpu_vinotify_handle_msg: tstamp:3368415044 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:32 vi_tstamp:3368414633 data:0x28000000
     kworker/4:2-218   [004] ...1   105.031102: rtcpu_vinotify_handle_msg: tstamp:3368518578 tag:CHANSEL_PXL_EOF channel:0x00 frame:51 vi_tstamp:3368517929 data:0x0da70002
     kworker/4:2-218   [004] ...1   105.031103: rtcpu_vinotify_handle_msg: tstamp:3368518686 tag:ATOMP_FE channel:0x00 frame:51 vi_tstamp:3368518231 data:0x00000000
     kworker/4:2-218   [004] ...1   105.031104: rtcpu_vinotify_handle_msg: tstamp:3368542977 tag:ATOMP_FS channel:0x00 frame:52 vi_tstamp:3368542554 data:0x00000000
     kworker/4:2-218   [004] ...1   105.031106: rtcpu_vinotify_handle_msg: tstamp:3368550670 tag:CHANSEL_PXL_SOF channel:0x00 frame:52 vi_tstamp:3368550267 data:0x00000001
     kworker/4:2-218   [004] ...1   105.031107: rtcpu_vinotify_handle_msg: tstamp:3368756331 tag:CHANSEL_PXL_EOF channel:0x02 frame:32 vi_tstamp:3368755685 data:0x0da70002
     kworker/4:2-218   [004] ...1   105.031108: rtcpu_vinotify_handle_msg: tstamp:3368756441 tag:ATOMP_FE channel:0x02 frame:32 vi_tstamp:3368755988 data:0x00000000
     kworker/4:2-218   [004] ...1   105.031110: rtcpu_vinotify_handle_msg: tstamp:3368780718 tag:ATOMP_FS channel:0x02 frame:33 vi_tstamp:3368780311 data:0x00000000
     kworker/4:2-218   [004] ...1   105.031111: rtcpu_vinotify_handle_msg: tstamp:3368788429 tag:CHANSEL_PXL_SOF channel:0x02 frame:33 vi_tstamp:3368788025 data:0x00000001
     kworker/4:2-218   [004] ...1   105.031112: rtcpu_vinotify_handle_msg: tstamp:3369001890 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:52 vi_tstamp:3369001478 data:0x08000000
     kworker/4:2-218   [004] ...1   105.031113: rtcpu_vinotify_handle_msg: tstamp:3369054563 tag:CSIMUX_FRAME channel:0x00 frame:18 vi_tstamp:3369053952 data:0x000000a0
     kworker/4:2-218   [004] ...1   105.031115: rtcpu_vinotify_handle_msg: tstamp:3369054690 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3369054058 data:0x00000002
     kworker/4:2-218   [004] ...1   105.031116: rtcpu_vinotify_handle_msg: tstamp:3369421115 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:33 vi_tstamp:3369420709 data:0x28000000
     kworker/4:2-218   [004] ...1   105.083085: rtcpu_vinotify_handle_msg: tstamp:3369558877 tag:CHANSEL_PXL_EOF channel:0x00 frame:52 vi_tstamp:3369558236 data:0x0da70002
     kworker/4:2-218   [004] ...1   105.083091: rtcpu_vinotify_handle_msg: tstamp:3369558983 tag:ATOMP_FE channel:0x00 frame:52 vi_tstamp:3369558539 data:0x00000000
     kworker/4:2-218   [004] ...1   105.083093: rtcpu_vinotify_handle_msg: tstamp:3369583268 tag:ATOMP_FS channel:0x00 frame:53 vi_tstamp:3369582863 data:0x00000000
     kworker/4:2-218   [004] ...1   105.083094: rtcpu_vinotify_handle_msg: tstamp:3369590979 tag:CHANSEL_PXL_SOF channel:0x00 frame:53 vi_tstamp:3369590575 data:0x00000001
     kworker/4:2-218   [004] ...1   105.083096: rtcpu_vinotify_handle_msg: tstamp:3369591540 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:53 vi_tstamp:3369591116 data:0x08000000
     kworker/4:2-218   [004] ...1   105.083098: rtcpu_vinotify_handle_msg: tstamp:3369796642 tag:CHANSEL_PXL_EOF channel:0x02 frame:33 vi_tstamp:3369795994 data:0x0da70002
     kworker/4:2-218   [004] ...1   105.083100: rtcpu_vinotify_handle_msg: tstamp:3369796754 tag:ATOMP_FE channel:0x02 frame:33 vi_tstamp:3369796296 data:0x00000000
     kworker/4:2-218   [004] ...1   105.083102: rtcpu_vinotify_handle_msg: tstamp:3369821028 tag:ATOMP_FS channel:0x02 frame:34 vi_tstamp:3369820619 data:0x00000000
     kworker/4:2-218   [004] ...1   105.083104: rtcpu_vinotify_handle_msg: tstamp:3369828738 tag:CHANSEL_PXL_SOF channel:0x02 frame:34 vi_tstamp:3369828334 data:0x00000001
     kworker/4:2-218   [004] ...1   105.083105: rtcpu_vinotify_handle_msg: tstamp:3370094874 tag:CSIMUX_FRAME channel:0x00 frame:19 vi_tstamp:3370094260 data:0x000000a0
     kworker/4:2-218   [004] ...1   105.083107: rtcpu_vinotify_handle_msg: tstamp:3370095005 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3370094369 data:0x00000002
     kworker/4:2-218   [004] ...1   105.083109: rtcpu_vinotify_handle_msg: tstamp:3370186329 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:34 vi_tstamp:3370185924 data:0x28000000
     kworker/4:2-218   [004] ...1   105.083111: rtcpu_vinotify_handle_msg: tstamp:3370599191 tag:CHANSEL_PXL_EOF channel:0x00 frame:53 vi_tstamp:3370598545 data:0x0da70002
     kworker/4:2-218   [004] ...1   105.083113: rtcpu_vinotify_handle_msg: tstamp:3370599304 tag:ATOMP_FE channel:0x00 frame:53 vi_tstamp:3370598847 data:0x00000000
     kworker/4:2-218   [004] ...1   105.083114: rtcpu_vinotify_handle_msg: tstamp:3370623578 tag:ATOMP_FS channel:0x00 frame:54 vi_tstamp:3370623171 data:0x00000000
     kworker/4:2-218   [004] ...1   105.083116: rtcpu_vinotify_handle_msg: tstamp:3370631285 tag:CHANSEL_PXL_SOF channel:0x00 frame:54 vi_tstamp:3370630883 data:0x00000001
     kworker/4:2-218   [004] ...1   105.083118: rtcpu_vinotify_handle_msg: tstamp:3370631853 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:54 vi_tstamp:3370631423 data:0x08000000
     kworker/4:2-218   [004] ...1   105.083120: rtcpu_vinotify_handle_msg: tstamp:3370836945 tag:CHANSEL_PXL_EOF channel:0x02 frame:34 vi_tstamp:3370836302 data:0x0da70002
     kworker/4:2-218   [004] ...1   105.083122: rtcpu_vinotify_handle_msg: tstamp:3370837051 tag:ATOMP_FE channel:0x02 frame:34 vi_tstamp:3370836605 data:0x00000000
     kworker/4:2-218   [004] ...1   105.083123: rtcpu_vinotify_handle_msg: tstamp:3370861334 tag:ATOMP_FS channel:0x02 frame:35 vi_tstamp:3370860928 data:0x00000000
     kworker/4:2-218   [004] ...1   105.083125: rtcpu_vinotify_handle_msg: tstamp:3370869043 tag:CHANSEL_PXL_SOF channel:0x02 frame:35 vi_tstamp:3370868642 data:0x00000001
     kworker/4:2-218   [004] ...1   105.083127: rtcpu_vinotify_handle_msg: tstamp:3370869609 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:35 vi_tstamp:3370869179 data:0x28000000
     kworker/4:2-218   [004] ...1   105.135094: rtcpu_vinotify_handle_msg: tstamp:3371135177 tag:CSIMUX_FRAME channel:0x00 frame:20 vi_tstamp:3371134568 data:0x000000a0
     kworker/4:2-218   [004] ...1   105.135100: rtcpu_vinotify_handle_msg: tstamp:3371135307 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3371134676 data:0x00000002
     kworker/4:2-218   [004] ...1   105.135104: rtos_queue_peek_from_isr_failed: tstamp:3371638229 queue:0x0b4a3c58
     kworker/4:2-218   [004] ...1   105.135106: rtcpu_vinotify_handle_msg: tstamp:3371639496 tag:CHANSEL_PXL_EOF channel:0x00 frame:54 vi_tstamp:3371638853 data:0x0da70002
     kworker/4:2-218   [004] ...1   105.135108: rtcpu_vinotify_handle_msg: tstamp:3371639600 tag:ATOMP_FE channel:0x00 frame:54 vi_tstamp:3371639155 data:0x00000000
     kworker/4:2-218   [004] ...1   105.135110: rtcpu_vinotify_handle_msg: tstamp:3371663888 tag:ATOMP_FS channel:0x00 frame:55 vi_tstamp:3371663479 data:0x00000000
     kworker/4:2-218   [004] ...1   105.135111: rtcpu_vinotify_handle_msg: tstamp:3371671594
Let me know if you have any recommendation/pointer on what could cause this issue.
Thanks in advance
hello josejich,
may I know did this issue happened with VI mode only?
could you please try to launch multiple camera sensors with the sample application in [L4T Multimedia API Reference]-> [Multimedia API Sample Applications]-> [13_multi_camera]
thanks
