I ported a driver from L4T 28.1 to L4T 28.2, in one particular mode I’m experiencing the following issue that doesn’t allow me to capture properly :
[ 5103.905963]
[ 5103.942874] tegra-vi4 15700000.vi: master error
[ 5104.020236] tegra-vi4 15700000.vi: master error
[ 5104.299234] tegra-vi4 15700000.vi: master error
[ 5104.425250] tegra-vi4 15700000.vi: master error
# entries-in-buffer/entries-written: 366/366 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:2-2579 [000] ...1 2315.466860: rtos_queue_peek_from_isr_failed: tstamp:72466564126 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2315.466864: rtcpu_start: tstamp:72466565344
kworker/0:2-2579 [000] ...1 2315.622176: rtos_queue_peek_from_isr_failed: tstamp:72471565033 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2315.830169: rtos_queue_peek_from_isr_failed: tstamp:72476565537 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2315.934225: rtcpu_vinotify_handle_msg: tstamp:72479819895 tag:CSIMUX_STREAM channel:0xff frame:1 vi_tstamp:3760342694 data:0x00000001
kworker/0:2-2579 [000] ...1 2315.934232: rtcpu_vinotify_handle_msg: tstamp:72479826181 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3760348996 data:0x00000002
kworker/0:2-2579 [000] ...1 2315.934235: rtcpu_vinotify_handle_msg: tstamp:72479899812 tag:CSIMUX_STREAM channel:0xff frame:3 vi_tstamp:3760422620 data:0x00000001
kworker/0:2-2579 [000] ...1 2315.934238: rtcpu_vinotify_handle_msg: tstamp:72479978875 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3760501681 data:0x00000001
kworker/0:2-2579 [000] ...1 2315.986232: rtos_queue_peek_from_isr_failed: tstamp:72481566043 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2315.986238: rtcpu_vinotify_handle_msg: tstamp:72481784898 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3762307705 data:0x00000002
kworker/0:2-2579 [000] ...1 2315.986241: rtcpu_vinotify_handle_msg: tstamp:72482957791 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3763480586 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.038169: rtcpu_vinotify_handle_msg: tstamp:72483533531 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3764056332 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.142166: rtcpu_vinotify_handle_msg: tstamp:72486404293 tag:CSIMUX_FRAME channel:0x02 frame:36004 vi_tstamp:3766927083 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.142173: rtos_queue_peek_from_isr_failed: tstamp:72486566562 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2316.142176: rtcpu_vinotify_handle_msg: tstamp:72486794985 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3767317792 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.142179: rtcpu_vinotify_handle_msg: tstamp:72486982098 tag:CSIMUX_FRAME channel:0x01 frame:34952 vi_tstamp:3767504903 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.142183: rtcpu_vinotify_handle_msg: tstamp:72486985970 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3767508788 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.142186: rtcpu_vinotify_handle_msg: tstamp:72487584829 tag:CSIMUX_FRAME channel:0x02 frame:50312 vi_tstamp:3768107636 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.194167: rtcpu_vinotify_handle_msg: tstamp:72488152960 tag:CSIMUX_FRAME channel:0x02 frame:8580 vi_tstamp:3768675769 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.194172: rtcpu_vinotify_handle_msg: tstamp:72488746081 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3769268889 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.246153: rtcpu_vinotify_handle_msg: tstamp:72489894401 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3770417205 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.298163: rtos_queue_peek_from_isr_failed: tstamp:72491567061 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2316.298168: rtcpu_vinotify_handle_msg: tstamp:72491657949 tag:CSIMUX_FRAME channel:0x02 frame:34052 vi_tstamp:3772180754 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.298172: rtcpu_vinotify_handle_msg: tstamp:72492209474 tag:CSIMUX_FRAME channel:0x02 frame:24960 vi_tstamp:3772732279 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.298175: rtcpu_vinotify_handle_msg: tstamp:72492221913 tag:CSIMUX_FRAME channel:0x03 frame:35716 vi_tstamp:3772744736 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.350190: rtcpu_vinotify_handle_msg: tstamp:72492801555 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3773324363 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.350196: rtcpu_vinotify_handle_msg: tstamp:72492813198 tag:CSIMUX_FRAME channel:0x00 frame:34948 vi_tstamp:3773335704 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.350199: rtcpu_vinotify_handle_msg: tstamp:72492813391 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:34948 vi_tstamp:3773335704 data:0x00000001
kworker/0:2-2579 [000] ...1 2316.350202: rtcpu_vinotify_handle_msg: tstamp:72492813587 tag:ATOMP_FE channel:0x00 frame:34948 vi_tstamp:3773335707 data:0x00000001
kworker/0:2-2579 [000] ...1 2316.350205: rtcpu_vinotify_handle_msg: tstamp:72492829852 tag:CSIMUX_FRAME channel:0x02 frame:2184 vi_tstamp:3773352658 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.350208: rtcpu_vinotify_handle_msg: tstamp:72493738524 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3774261330 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.350211: rtcpu_vinotify_handle_msg: tstamp:72493913080 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3774435888 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.350214: rtcpu_vinotify_handle_msg: tstamp:72493977739 tag:CSIMUX_FRAME channel:0x00 frame:34952 vi_tstamp:3774500342 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.350217: rtcpu_vinotify_handle_msg: tstamp:72493977936 tag:CSIMUX_FRAME channel:0x01 frame:32908 vi_tstamp:3774500688 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.350220: rtcpu_vinotify_handle_msg: tstamp:72494357174 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3774879980 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.402166: rtcpu_vinotify_handle_msg: tstamp:72495123136 tag:CSIMUX_FRAME channel:0x02 frame:8580 vi_tstamp:3775645950 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.402171: rtcpu_vinotify_handle_msg: tstamp:72495131797 tag:CSIMUX_FRAME channel:0x02 frame:34956 vi_tstamp:3775654600 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.402174: rtcpu_vinotify_handle_msg: tstamp:72495716180 tag:CSIMUX_FRAME channel:0x02 frame:33408 vi_tstamp:3776238994 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.402177: rtcpu_vinotify_handle_msg: tstamp:72495738663 tag:CSIMUX_FRAME channel:0x00 frame:33924 vi_tstamp:3776261484 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.454196: rtcpu_vinotify_handle_msg: tstamp:72496294347 tag:CSIMUX_FRAME channel:0x02 frame:33932 vi_tstamp:3776817161 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.454201: rtcpu_vinotify_handle_msg: tstamp:72496296840 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3776819661 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.454206: rtos_queue_peek_from_isr_failed: tstamp:72496567554 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2316.454209: rtcpu_vinotify_handle_msg: tstamp:72496885317 tag:CSIMUX_FRAME channel:0x02 frame:43652 vi_tstamp:3777408130 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.454212: rtcpu_vinotify_handle_msg: tstamp:72497475592 tag:CSIMUX_FRAME channel:0x03 frame:33928 vi_tstamp:3777998407 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.506167: rtcpu_vinotify_handle_msg: tstamp:72498622664 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3779145476 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.558163: rtcpu_vinotify_handle_msg: tstamp:72500379923 tag:CSIMUX_FRAME channel:0x02 frame:51332 vi_tstamp:3780902735 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.610167: rtcpu_vinotify_handle_msg: tstamp:72501298629 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3781821444 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.610172: rtcpu_vinotify_handle_msg: tstamp:72501523179 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3782045991 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.610176: rtos_queue_peek_from_isr_failed: tstamp:72501568063 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2316.662167: rtcpu_vinotify_handle_msg: tstamp:72502689822 tag:CSIMUX_FRAME channel:0x02 frame:33408 vi_tstamp:3783212634 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.662171: rtcpu_vinotify_handle_msg: tstamp:72503844848 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3784367661 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.714171: rtcpu_vinotify_handle_msg: tstamp:72505612493 tag:CSIMUX_FRAME channel:0x02 frame:2244 vi_tstamp:3786135301 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.766162: rtos_queue_peek_from_isr_failed: tstamp:72506568579 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2316.818176: rtcpu_vinotify_handle_msg: tstamp:72507697837 tag:CSIMUX_FRAME channel:0x01 frame:32776 vi_tstamp:3788220645 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.818182: rtcpu_vinotify_handle_msg: tstamp:72508307566 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3788830374 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.870194: rtcpu_vinotify_handle_msg: tstamp:72509042821 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3789565627 data:0x00000002
kworker/0:2-2579 [000] ...1 2316.922169: rtcpu_vinotify_handle_msg: tstamp:72510841945 tag:CSIMUX_FRAME channel:0x02 frame:33932 vi_tstamp:3791364753 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.922173: rtcpu_vinotify_handle_msg: tstamp:72511399005 tag:CSIMUX_FRAME channel:0x02 frame:9093 vi_tstamp:3791921813 data:0x000000a0
kworker/0:2-2579 [000] ...1 2316.922178: rtos_queue_peek_from_isr_failed: tstamp:72511569096 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2317.026166: rtcpu_vinotify_handle_msg: tstamp:72514075393 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3794598201 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.078163: rtcpu_vinotify_handle_msg: tstamp:72516079702 tag:CSIMUX_FRAME channel:0x02 frame:39296 vi_tstamp:3796602508 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.078167: rtcpu_vinotify_handle_msg: tstamp:72516084533 tag:CSIMUX_FRAME channel:0x02 frame:1408 vi_tstamp:3796607352 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.078171: rtos_queue_peek_from_isr_failed: tstamp:72516569598 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2317.130165: rtcpu_vinotify_handle_msg: tstamp:72517593874 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3798116682 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.182173: rtcpu_vinotify_handle_msg: tstamp:72518986656 tag:CSIMUX_FRAME channel:0x02 frame:35076 vi_tstamp:3799509259 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.182178: rtcpu_vinotify_handle_msg: tstamp:72518986847 tag:CSIMUX_FRAME channel:0x02 frame:31360 vi_tstamp:3799509605 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.182181: rtcpu_vinotify_handle_msg: tstamp:72518991974 tag:CSIMUX_FRAME channel:0x02 frame:34432 vi_tstamp:3799514794 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.182185: rtcpu_vinotify_handle_msg: tstamp:72519344214 tag:CSIMUX_FRAME channel:0x00 frame:32640 vi_tstamp:3799867023 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.182188: rtcpu_vinotify_handle_msg: tstamp:72520116228 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3800639033 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.234175: rtos_queue_peek_from_isr_failed: tstamp:72521570096 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2317.286171: rtcpu_vinotify_handle_msg: tstamp:72522443690 tag:CSIMUX_FRAME channel:0x02 frame:8308 vi_tstamp:3802966496 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.286176: rtcpu_vinotify_handle_msg: tstamp:72522464781 tag:CSIMUX_FRAME channel:0x02 frame:51844 vi_tstamp:3802987602 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.286179: rtcpu_vinotify_handle_msg: tstamp:72522851622 tag:CSIMUX_FRAME channel:0x01 frame:60528 vi_tstamp:3803374430 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.286182: rtcpu_vinotify_handle_msg: tstamp:72523022465 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3803545257 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.286185: rtcpu_vinotify_handle_msg: tstamp:72523630125 tag:CSIMUX_FRAME channel:0x02 frame:18312 vi_tstamp:3804152931 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.338173: rtcpu_vinotify_handle_msg: tstamp:72524587588 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3805110394 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.338178: rtcpu_vinotify_handle_msg: tstamp:72524761155 tag:CSIMUX_FRAME channel:0x00 frame:30328 vi_tstamp:3805283661 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.338181: rtcpu_vinotify_handle_msg: tstamp:72524761354 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:30328 vi_tstamp:3805283661 data:0x00000001
kworker/0:2-2579 [000] ...1 2317.338184: rtcpu_vinotify_handle_msg: tstamp:72524761550 tag:ATOMP_FE channel:0x00 frame:30328 vi_tstamp:3805283664 data:0x00000001
kworker/0:2-2579 [000] ...1 2317.338187: rtcpu_vinotify_handle_msg: tstamp:72524793367 tag:CSIMUX_FRAME channel:0x02 frame:2184 vi_tstamp:3805316185 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.338190: rtcpu_vinotify_handle_msg: tstamp:72525114903 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3805637694 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.390558: rtcpu_vinotify_handle_msg: tstamp:72525355707 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3805878512 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.390564: rtcpu_vinotify_handle_msg: tstamp:72525385025 tag:CSIMUX_FRAME channel:0x02 frame:384 vi_tstamp:3805907846 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.390568: rtcpu_vinotify_handle_msg: tstamp:72525927292 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3806450103 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.390571: rtcpu_vinotify_handle_msg: tstamp:72525945893 tag:CSIMUX_FRAME channel:0x00 frame:34948 vi_tstamp:3806468712 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.390576: rtos_queue_peek_from_isr_failed: tstamp:72526570597 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2317.494212: rtcpu_vinotify_handle_msg: tstamp:72528860953 tag:CSIMUX_FRAME channel:0x02 frame:41856 vi_tstamp:3809383767 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.494217: rtcpu_vinotify_handle_msg: tstamp:72528876170 tag:CSIMUX_FRAME channel:0x02 frame:32776 vi_tstamp:3809398991 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.494220: rtcpu_vinotify_handle_msg: tstamp:72529204260 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3809727075 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.494223: rtcpu_vinotify_handle_msg: tstamp:72529444485 tag:CSIMUX_FRAME channel:0x02 frame:39556 vi_tstamp:3809967297 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.494226: rtcpu_vinotify_handle_msg: tstamp:72529449841 tag:CSIMUX_FRAME channel:0x02 frame:27756 vi_tstamp:3809972660 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.494229: rtcpu_vinotify_handle_msg: tstamp:72529786581 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3810309395 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.546177: rtcpu_vinotify_handle_msg: tstamp:72531161858 tag:CSIMUX_FRAME channel:0x02 frame:32624 vi_tstamp:3811684670 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.546182: rtcpu_vinotify_handle_msg: tstamp:72531193337 tag:CSIMUX_FRAME channel:0x02 frame:34692 vi_tstamp:3811716157 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.546186: rtos_queue_peek_from_isr_failed: tstamp:72531571106 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2317.598190: rtcpu_vinotify_handle_msg: tstamp:72532318265 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3812841075 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.598196: rtcpu_vinotify_handle_msg: tstamp:72532916785 tag:CSIMUX_FRAME channel:0x02 frame:32932 vi_tstamp:3813439585 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.598199: rtcpu_vinotify_handle_msg: tstamp:72532922661 tag:CSIMUX_FRAME channel:0x02 frame:42368 vi_tstamp:3813445468 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.650177: rtcpu_vinotify_handle_msg: tstamp:72534083488 tag:CSIMUX_FRAME channel:0x02 frame:34696 vi_tstamp:3814606298 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.650181: rtcpu_vinotify_handle_msg: tstamp:72534084873 tag:CSIMUX_FRAME channel:0x03 frame:34692 vi_tstamp:3814607683 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.650184: rtcpu_vinotify_handle_msg: tstamp:72534684839 tag:CSIMUX_FRAME channel:0x02 frame:8580 vi_tstamp:3815207648 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.702158: rtcpu_vinotify_handle_msg: tstamp:72535274499 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3815797308 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.702162: rtcpu_vinotify_handle_msg: tstamp:72535814532 tag:CSIMUX_FRAME channel:0x02 frame:8321 vi_tstamp:3816337339 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.702166: rtcpu_vinotify_handle_msg: tstamp:72536390694 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3816913503 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.702169: rtcpu_vinotify_handle_msg: tstamp:72536427299 tag:CSIMUX_FRAME channel:0x02 frame:34696 vi_tstamp:3816950106 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.702172: rtcpu_vinotify_handle_msg: tstamp:72536436629 tag:CSIMUX_FRAME channel:0x02 frame:32004 vi_tstamp:3816959448 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.702177: rtos_queue_peek_from_isr_failed: tstamp:72536571630 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2317.806173: rtcpu_vinotify_handle_msg: tstamp:72538721626 tag:CSIMUX_FRAME channel:0x00 frame:33664 vi_tstamp:3819244435 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.806178: rtcpu_vinotify_handle_msg: tstamp:72539322632 tag:CSIMUX_FRAME channel:0x02 frame:8452 vi_tstamp:3819845438 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.806182: rtcpu_vinotify_handle_msg: tstamp:72539330577 tag:CSIMUX_FRAME channel:0x02 frame:34432 vi_tstamp:3819853396 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.806185: rtcpu_vinotify_handle_msg: tstamp:72539653078 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3820175884 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.858169: rtcpu_vinotify_handle_msg: tstamp:72539912640 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3820435447 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.858174: rtcpu_vinotify_handle_msg: tstamp:72540494187 tag:CSIMUX_FRAME channel:0x03 frame:52360 vi_tstamp:3821016996 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.858177: rtcpu_vinotify_handle_msg: tstamp:72541038868 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3821561677 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.858180: rtcpu_vinotify_handle_msg: tstamp:72541082045 tag:CSIMUX_FRAME channel:0x00 frame:34952 vi_tstamp:3821604851 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.910170: rtos_queue_peek_from_isr_failed: tstamp:72541572126 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2317.910178: rtcpu_vinotify_handle_msg: tstamp:72541626305 tag:CSIMUX_FRAME channel:0x00 frame:31876 vi_tstamp:3822149110 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.910181: rtcpu_vinotify_handle_msg: tstamp:72542021436 tag:CSIMUX_FRAME channel:0x01 frame:30842 vi_tstamp:3822544242 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.910184: rtcpu_vinotify_handle_msg: tstamp:72542207834 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3822730641 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.910186: rtcpu_vinotify_handle_msg: tstamp:72542229025 tag:CSIMUX_FRAME channel:0x02 frame:8700 vi_tstamp:3822751843 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.910189: rtcpu_vinotify_handle_msg: tstamp:72542830048 tag:CSIMUX_FRAME channel:0x02 frame:49528 vi_tstamp:3823352845 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.962182: rtcpu_vinotify_handle_msg: tstamp:72543330890 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3823853696 data:0x00000002
kworker/0:2-2579 [000] ...1 2317.962187: rtcpu_vinotify_handle_msg: tstamp:72543344880 tag:CSIMUX_FRAME channel:0x8c frame:34948 vi_tstamp:3823867689 data:0x00000400
kworker/0:2-2579 [000] ...1 2317.962191: rtcpu_vinotify_handle_msg: tstamp:72543376707 tag:CSIMUX_FRAME channel:0x02 frame:41096 vi_tstamp:3823899526 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.962194: rtcpu_vinotify_handle_msg: tstamp:72543969418 tag:CSIMUX_FRAME channel:0x02 frame:32392 vi_tstamp:3824492225 data:0x000000a0
kworker/0:2-2579 [000] ...1 2317.962197: rtcpu_vinotify_handle_msg: tstamp:72544570419 tag:CSIMUX_FRAME channel:0x02 frame:32132 vi_tstamp:3825093228 data:0x000000a0
kworker/0:2-2579 [000] ...1 2318.014178: rtcpu_vinotify_handle_msg: tstamp:72544932946 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3825455739 data:0x00000002
kworker/0:2-2579 [000] ...1 2318.014184: rtcpu_vinotify_handle_msg: tstamp:72545143478 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3825666284 data:0x00000002
kworker/0:2-2579 [000] ...1 2318.066189: rtos_queue_peek_from_isr_failed: tstamp:72546572631 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2318.066195: rtcpu_vinotify_handle_msg: tstamp:72546872017 tag:CSIMUX_FRAME channel:0x02 frame:644 vi_tstamp:3827394823 data:0x000000a0
kworker/0:2-2579 [000] ...1 2318.066198: rtcpu_vinotify_handle_msg: tstamp:72546884806 tag:CSIMUX_FRAME channel:0x02 frame:18301 vi_tstamp:3827407625 data:0x000000a0
kworker/0:2-2579 [000] ...1 2318.066201: rtcpu_vinotify_handle_msg: tstamp:72546897271 tag:CSIMUX_FRAME channel:0x02 frame:51328 vi_tstamp:3827420081 data:0x000000a0
kworker/0:2-2579 [000] ...1 2318.066204: rtcpu_vinotify_handle_msg: tstamp:72546903496 tag:CSIMUX_FRAME channel:0x02 frame:32960 vi_tstamp:3827426309 data:0x000000a0
kworker/0:2-2579 [000] ...1 2318.118179: rtcpu_vinotify_handle_msg: tstamp:72548050148 tag:CSIMUX_FRAME channel:0x00 frame:34948 vi_tstamp:3828572955 data:0x000004a0
kworker/0:2-2579 [000] ...1 2318.118184: rtcpu_vinotify_handle_msg: tstamp:72548607809 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3829130616 data:0x00000002
kworker/0:2-2579 [000] ...1 2318.118188: rtcpu_vinotify_handle_msg: tstamp:72548625268 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3829148089 data:0x00000002
kworker/0:2-2579 [000] ...1 2318.118191: rtcpu_vinotify_handle_msg: tstamp:72549208907 tag:CSIMUX_FRAME channel:0x02 frame:8332 vi_tstamp:3829731710 data:0x000000a0
kworker/0:2-2579 [000] ...1 2318.170199: rtcpu_vinotify_handle_msg: tstamp:72549758428 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3830281237 data:0x00000002
kworker/0:2-2579 [000] ...1 2318.170205: rtcpu_vinotify_handle_msg: tstamp:72550974197 tag:CSIMUX_FRAME channel:0x02 frame:1920 vi_tstamp:3831497006 data:0x000000a0
kworker/0:2-2579 [000] ...1 2318.222305: rtos_queue_peek_from_isr_failed: tstamp:72551573139 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2318.222311: rtcpu_vinotify_handle_msg: tstamp:72552695975 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3833218785 data:0x00000002
kworker/0:2-2579 [000] ...1 2318.274178: rtcpu_vinotify_handle_msg: tstamp:72553278218 tag:CSIMUX_FRAME channel:0x02 frame:31612 vi_tstamp:3833801023 data:0x000000a0
kworker/0:2-2579 [000] ...1 2318.378195: rtos_queue_peek_from_isr_failed: tstamp:72556573644 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2318.430178: rtcpu_vinotify_handle_msg: tstamp:72557905281 tag:CSIMUX_FRAME channel:0x02 frame:33176 vi_tstamp:3838428087 data:0x000000a0
kworker/0:2-2579 [000] ...1 2318.482198: rtcpu_vinotify_handle_msg: tstamp:72559664860 tag:CSIMUX_FRAME channel:0xb6 frame:400 vi_tstamp:3840187668 data:0x00000400
kworker/0:2-2579 [000] ...1 2318.482204: rtcpu_vinotify_handle_msg: tstamp:72560220100 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3840742909 data:0x00000002
kworker/0:2-2579 [000] ...1 2318.534180: rtos_queue_peek_from_isr_failed: tstamp:72561574165 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2318.534185: rtcpu_vinotify_handle_msg: tstamp:72562561411 tag:CSIMUX_FRAME channel:0x02 frame:400 vi_tstamp:3843084216 data:0x000004a0
kworker/0:2-2579 [000] ...1 2318.586183: rtcpu_vinotify_handle_msg: tstamp:72563750612 tag:CSIMUX_FRAME channel:0x02 frame:34444 vi_tstamp:3844273421 data:0x00a00260
kworker/0:2-2579 [000] ...1 2318.638213: rtcpu_vinotify_handle_msg: tstamp:72564317443 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3844840246 data:0x00000002
kworker/0:2-2579 [000] ...1 2318.638219: rtcpu_vinotify_handle_msg: tstamp:72564336377 tag:CSIMUX_FRAME channel:0x02 frame:34956 vi_tstamp:3844859199 data:0x000000a0
kworker/0:2-2579 [000] ...1 2318.690185: rtos_queue_peek_from_isr_failed: tstamp:72566574657 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2318.690190: rtcpu_vinotify_handle_msg: tstamp:72566640411 tag:CSIMUX_FRAME channel:0x02 frame:36992 vi_tstamp:3847163216 data:0x000000a0
kworker/0:2-2579 [000] ...1 2318.742182: rtcpu_vinotify_handle_msg: tstamp:72568368693 tag:CSIMUX_FRAME channel:0x02 frame:34424 vi_tstamp:3848891489 data:0x000000a0
kworker/0:2-2579 [000] ...1 2318.846195: rtos_queue_peek_from_isr_failed: tstamp:72571575166 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2318.950209: rtcpu_vinotify_handle_msg: tstamp:72574227510 tag:CSIMUX_FRAME channel:0x01 frame:29804 vi_tstamp:3854750316 data:0x000000a0
kworker/0:2-2579 [000] ...1 2318.950215: rtcpu_vinotify_handle_msg: tstamp:72574461956 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:34948 vi_tstamp:3854984760 data:0x08000000
kworker/0:2-2579 [000] ...1 2318.950219: rtcpu_vinotify_handle_msg: tstamp:72574570127 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3855092935 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.002188: rtcpu_vinotify_handle_msg: tstamp:72576320887 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3856843694 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.002196: rtos_queue_peek_from_isr_failed: tstamp:72576575671 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2319.002199: rtcpu_vinotify_handle_msg: tstamp:72577086510 tag:CSIMUX_FRAME channel:0x02 frame:35196 vi_tstamp:3857609318 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.054192: rtcpu_vinotify_handle_msg: tstamp:72578065766 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3858588574 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.054197: rtcpu_vinotify_handle_msg: tstamp:72578255990 tag:CSIMUX_FRAME channel:0x02 frame:41604 vi_tstamp:3858778799 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.054200: rtcpu_vinotify_handle_msg: tstamp:72578830697 tag:CSIMUX_FRAME channel:0x02 frame:35209 vi_tstamp:3859353506 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.054203: rtcpu_vinotify_handle_msg: tstamp:72578835184 tag:CSIMUX_FRAME channel:0x02 frame:18624 vi_tstamp:3859358004 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.106189: rtcpu_vinotify_handle_msg: tstamp:72579430316 tag:CSIMUX_FRAME channel:0x02 frame:33932 vi_tstamp:3859953125 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.158189: rtcpu_vinotify_handle_msg: tstamp:72580563478 tag:CSIMUX_FRAME channel:0x02 frame:34180 vi_tstamp:3861086277 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.158195: rtos_queue_peek_from_isr_failed: tstamp:72581576179 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2319.210202: rtcpu_vinotify_handle_msg: tstamp:72582344004 tag:CSIMUX_FRAME channel:0x02 frame:36744 vi_tstamp:3862866796 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.210208: rtcpu_vinotify_handle_msg: tstamp:72582917401 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3863440197 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.262195: rtcpu_vinotify_handle_msg: tstamp:72585221624 tag:CSIMUX_FRAME channel:0x00 frame:34948 vi_tstamp:3865744136 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.262200: rtcpu_vinotify_handle_msg: tstamp:72585221822 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:34948 vi_tstamp:3865744136 data:0x00000001
kworker/0:2-2579 [000] ...1 2319.262203: rtcpu_vinotify_handle_msg: tstamp:72585222033 tag:ATOMP_FE channel:0x00 frame:34948 vi_tstamp:3865744139 data:0x00000001
kworker/0:2-2579 [000] ...1 2319.314198: rtcpu_vinotify_handle_msg: tstamp:72585826223 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3866349022 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.314204: rtos_queue_peek_from_isr_failed: tstamp:72586576700 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2319.314207: rtcpu_vinotify_handle_msg: tstamp:72586989046 tag:CSIMUX_FRAME channel:0x02 frame:2184 vi_tstamp:3867511852 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.418193: rtcpu_vinotify_handle_msg: tstamp:72588756414 tag:CSIMUX_FRAME channel:0x02 frame:33932 vi_tstamp:3869279223 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.418198: rtcpu_vinotify_handle_msg: tstamp:72589308631 tag:CSIMUX_FRAME channel:0x03 frame:2172 vi_tstamp:3869831440 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.418201: rtcpu_vinotify_handle_msg: tstamp:72589311733 tag:CSIMUX_FRAME channel:0x02 frame:32380 vi_tstamp:3869834554 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.470204: rtcpu_vinotify_handle_msg: tstamp:72591571031 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3872093840 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.470211: rtos_queue_peek_from_isr_failed: tstamp:72591577179 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2319.470214: rtcpu_vinotify_handle_msg: tstamp:72591661170 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3872183975 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.522201: rtcpu_vinotify_handle_msg: tstamp:72592200511 tag:CSIMUX_FRAME channel:0x02 frame:8320 vi_tstamp:3872723312 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.522207: rtcpu_vinotify_handle_msg: tstamp:72592229552 tag:CSIMUX_FRAME channel:0x01 frame:31868 vi_tstamp:3872752376 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.522210: rtcpu_vinotify_handle_msg: tstamp:72592789649 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3873312457 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.522213: rtcpu_vinotify_handle_msg: tstamp:72593360659 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3873883467 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.574200: rtcpu_vinotify_handle_msg: tstamp:72594530126 tag:CSIMUX_FRAME channel:0x02 frame:34248 vi_tstamp:3875052934 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.574205: rtcpu_vinotify_handle_msg: tstamp:72594929423 tag:CSIMUX_FRAME channel:0x02 frame:10380 vi_tstamp:3875452218 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.626201: rtcpu_vinotify_handle_msg: tstamp:72595697879 tag:CSIMUX_FRAME channel:0x02 frame:24688 vi_tstamp:3876220685 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.626208: rtcpu_vinotify_handle_msg: tstamp:72596309605 tag:CSIMUX_FRAME channel:0x02 frame:32384 vi_tstamp:3876832414 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.626212: rtos_queue_peek_from_isr_failed: tstamp:72596577701 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2319.678207: rtcpu_vinotify_handle_msg: tstamp:72597441375 tag:CSIMUX_FRAME channel:0x02 frame:33408 vi_tstamp:3877964181 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.678213: rtcpu_vinotify_handle_msg: tstamp:72597444129 tag:CSIMUX_FRAME channel:0x00 frame:34440 vi_tstamp:3877966950 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.678216: rtcpu_vinotify_handle_msg: tstamp:72597455274 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3877978095 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.730194: rtcpu_vinotify_handle_msg: tstamp:72598588021 tag:CSIMUX_FRAME channel:0x02 frame:8580 vi_tstamp:3879110827 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.730198: rtcpu_vinotify_handle_msg: tstamp:72599170684 tag:CSIMUX_FRAME channel:0x02 frame:33672 vi_tstamp:3879693493 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.730201: rtcpu_vinotify_handle_msg: tstamp:72599180095 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3879702916 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.730205: rtcpu_vinotify_handle_msg: tstamp:72599773154 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3880295959 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.730208: rtcpu_vinotify_handle_msg: tstamp:72599792091 tag:CSIMUX_FRAME channel:0x02 frame:32914 vi_tstamp:3880314909 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.782193: rtcpu_vinotify_handle_msg: tstamp:72600342588 tag:CSIMUX_FRAME channel:0x02 frame:33408 vi_tstamp:3880865396 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.782199: rtcpu_vinotify_handle_msg: tstamp:72600946095 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3881468903 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.782202: rtcpu_vinotify_handle_msg: tstamp:72601529371 tag:CSIMUX_FRAME channel:0x02 frame:51336 vi_tstamp:3882052177 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.782205: rtcpu_vinotify_handle_msg: tstamp:72601542454 tag:CSIMUX_FRAME channel:0x00 frame:35972 vi_tstamp:3882064979 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.782208: rtcpu_vinotify_handle_msg: tstamp:72601542649 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:35972 vi_tstamp:3882064980 data:0x00000001
kworker/0:2-2579 [000] ...1 2319.782211: rtcpu_vinotify_handle_msg: tstamp:72601542843 tag:ATOMP_FE channel:0x00 frame:35972 vi_tstamp:3882064983 data:0x00000001
kworker/0:2-2579 [000] ...1 2319.782216: rtos_queue_peek_from_isr_failed: tstamp:72601578205 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2319.834196: rtcpu_vinotify_handle_msg: tstamp:72602096468 tag:CSIMUX_FRAME channel:0x02 frame:32104 vi_tstamp:3882619272 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.834200: rtcpu_vinotify_handle_msg: tstamp:72602107177 tag:CSIMUX_FRAME channel:0x02 frame:8332 vi_tstamp:3882629999 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.886199: rtcpu_vinotify_handle_msg: tstamp:72603830006 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3884352814 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.886204: rtcpu_vinotify_handle_msg: tstamp:72604444770 tag:CSIMUX_FRAME channel:0x00 frame:33664 vi_tstamp:3884967578 data:0x000000a0
kworker/0:2-2579 [000] ...1 2319.950200: rtcpu_vinotify_handle_msg: tstamp:72605376971 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3885899780 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.950205: rtcpu_vinotify_handle_msg: tstamp:72605993202 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3886516008 data:0x00000002
kworker/0:2-2579 [000] ...1 2319.950209: rtos_queue_peek_from_isr_failed: tstamp:72606578714 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2320.002293: rtcpu_vinotify_handle_msg: tstamp:72607313808 tag:CSIMUX_FRAME channel:0x02 frame:1668 vi_tstamp:3887836614 data:0x000000a0
kworker/0:2-2579 [000] ...1 2320.002299: rtcpu_vinotify_handle_msg: tstamp:72608249750 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3888772560 data:0x00000002
kworker/0:2-2579 [000] ...1 2320.002302: rtcpu_vinotify_handle_msg: tstamp:72608477070 tag:CSIMUX_FRAME channel:0x02 frame:32960 vi_tstamp:3888999868 data:0x000000a0
kworker/0:2-2579 [000] ...1 2320.002305: rtcpu_vinotify_handle_msg: tstamp:72608509647 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3889032472 data:0x00000002
kworker/0:2-2579 [000] ...1 2320.054213: rtcpu_vinotify_handle_msg: tstamp:72609077025 tag:CSIMUX_FRAME channel:0x02 frame:33668 vi_tstamp:3889599833 data:0x000000a0
kworker/0:2-2579 [000] ...1 2320.106215: rtcpu_vinotify_handle_msg: tstamp:72611391506 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3891914311 data:0x00000002
kworker/0:2-2579 [000] ...1 2320.106222: rtos_queue_peek_from_isr_failed: tstamp:72611579233 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2320.158215: rtcpu_vinotify_handle_msg: tstamp:72611976337 tag:CSIMUX_FRAME channel:0x02 frame:34434 vi_tstamp:3892499144 data:0x000000a0
kworker/0:2-2579 [000] ...1 2320.158221: rtcpu_vinotify_handle_msg: tstamp:72612573707 tag:CSIMUX_FRAME channel:0x01 frame:33404 vi_tstamp:3893096515 data:0x000000a0
kworker/0:2-2579 [000] ...1 2320.158224: rtcpu_vinotify_handle_msg: tstamp:72612581843 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3893104662 data:0x00000002
kworker/0:2-2579 [000] ...1 2320.210202: rtcpu_vinotify_handle_msg: tstamp:72613483765 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3894006573 data:0x00000002
kworker/0:2-2579 [000] ...1 2320.262198: rtos_queue_peek_from_isr_failed: tstamp:72616579726 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2320.418214: rtcpu_vinotify_handle_msg: tstamp:72621309872 tag:CSIMUX_FRAME channel:0x00 frame:34688 vi_tstamp:3901832680 data:0x000000a0
kworker/0:2-2579 [000] ...1 2320.470202: rtos_queue_peek_from_isr_failed: tstamp:72621580235 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2320.470209: rtcpu_vinotify_handle_msg: tstamp:72622417152 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3902939959 data:0x00000002
kworker/0:2-2579 [000] ...1 2320.626199: rtos_queue_peek_from_isr_failed: tstamp:72626580746 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2320.678201: rtcpu_vinotify_handle_msg: tstamp:72629432754 tag:CSIMUX_FRAME channel:0x02 frame:48640 vi_tstamp:3909955562 data:0x000000a0
kworker/0:2-2579 [000] ...1 2320.730193: rtcpu_vinotify_handle_msg: tstamp:72630565389 tag:CSIMUX_FRAME channel:0x01 frame:32896 vi_tstamp:3911088194 data:0x000000a0
kworker/0:2-2579 [000] ...1 2320.730198: rtcpu_vinotify_handle_msg: tstamp:72630567527 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3911090346 data:0x00000002
kworker/0:2-2579 [000] ...1 2320.730204: rtcpu_vinotify_handle_msg: tstamp:72630585097 tag:CSIMUX_FRAME channel:0x02 frame:45696 vi_tstamp:3911107916 data:0x000000a0
kworker/0:2-2579 [000] ...1 2320.782223: rtos_queue_peek_from_isr_failed: tstamp:72631581248 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2320.834203: rtcpu_vinotify_handle_msg: tstamp:72633331396 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3913854202 data:0x00000002
kworker/0:2-2579 [000] ...1 2320.938226: rtcpu_vinotify_handle_msg: tstamp:72636368162 tag:CSIMUX_FRAME channel:0x02 frame:33921 vi_tstamp:3916890968 data:0x000000a0
kworker/0:2-2579 [000] ...1 2320.938232: rtcpu_vinotify_handle_msg: tstamp:72636399290 tag:CSIMUX_FRAME channel:0x02 frame:18572 vi_tstamp:3916922109 data:0x000000a0
kworker/0:2-2579 [000] ...1 2320.938236: rtos_queue_peek_from_isr_failed: tstamp:72636581769 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2320.938239: rtcpu_vinotify_handle_msg: tstamp:72637086351 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:2176 vi_tstamp:3917609126 data:0x08000000
kworker/0:2-2579 [000] ...1 2320.938243: rtcpu_vinotify_handle_msg: tstamp:72637309018 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3917831824 data:0x00000002
kworker/0:2-2579 [000] ...1 2321.094212: rtos_queue_peek_from_isr_failed: tstamp:72641582261 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2321.094219: rtcpu_vinotify_handle_msg: tstamp:72641647783 tag:CSIMUX_FRAME channel:0x02 frame:35008 vi_tstamp:3922170591 data:0x000000a0
kworker/0:2-2579 [000] ...1 2321.094223: rtcpu_vinotify_handle_msg: tstamp:72642192056 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3922714865 data:0x00000002
kworker/0:2-2579 [000] ...1 2321.250212: rtos_queue_peek_from_isr_failed: tstamp:72646582766 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2321.406198: rtos_queue_peek_from_isr_failed: tstamp:72651583274 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2321.406203: rtcpu_vinotify_handle_msg: tstamp:72652073769 tag:CSIMUX_FRAME channel:0x00 frame:2176 vi_tstamp:3932596278 data:0x000000a0
kworker/0:2-2579 [000] ...1 2321.406207: rtcpu_vinotify_handle_msg: tstamp:72652073969 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:2176 vi_tstamp:3932596278 data:0x00000001
kworker/0:2-2579 [000] ...1 2321.406210: rtcpu_vinotify_handle_msg: tstamp:72652074165 tag:ATOMP_FE channel:0x00 frame:2176 vi_tstamp:3932596280 data:0x00000001
kworker/0:2-2579 [000] ...1 2321.458214: rtcpu_vinotify_handle_msg: tstamp:72652546135 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3933068941 data:0x00000002
kworker/0:2-2579 [000] ...1 2321.562218: rtos_queue_peek_from_isr_failed: tstamp:72656583783 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2321.614217: rtcpu_vinotify_handle_msg: tstamp:72657307077 tag:CSIMUX_FRAME channel:0x02 frame:33920 vi_tstamp:3937829882 data:0x000000a0
kworker/0:2-2579 [000] ...1 2321.614225: rtcpu_vinotify_handle_msg: tstamp:72657701242 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3938224051 data:0x00000002
kworker/0:2-2579 [000] ...1 2321.718216: rtcpu_vinotify_handle_msg: tstamp:72660577817 tag:CSIMUX_FRAME channel:0x03 frame:30848 vi_tstamp:3941100625 data:0x000000a0
kworker/0:2-2579 [000] ...1 2321.718223: rtcpu_vinotify_handle_msg: tstamp:72660720620 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3941243428 data:0x00000002
kworker/0:2-2579 [000] ...1 2321.718228: rtos_queue_peek_from_isr_failed: tstamp:72661584290 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2321.822217: rtcpu_vinotify_handle_msg: tstamp:72665206615 tag:CSIMUX_FRAME channel:0x03 frame:4460 vi_tstamp:3945729419 data:0x000000a0
kworker/0:2-2579 [000] ...1 2321.874220: rtcpu_vinotify_handle_msg: tstamp:72665801399 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3946324209 data:0x00000002
kworker/0:2-2579 [000] ...1 2321.874227: rtos_queue_peek_from_isr_failed: tstamp:72666584796 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2321.874230: rtcpu_vinotify_handle_msg: tstamp:72666630749 tag:CSIMUX_FRAME channel:0x02 frame:51260 vi_tstamp:3947153558 data:0x000000a0
kworker/0:2-2579 [000] ...1 2321.978223: rtcpu_vinotify_handle_msg: tstamp:72669472177 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3949994984 data:0x00000002
kworker/0:2-2579 [000] ...1 2321.978228: rtcpu_vinotify_handle_msg: tstamp:72670093869 tag:CSIMUX_FRAME channel:0x02 frame:8452 vi_tstamp:3950616677 data:0x000000a0
kworker/0:2-2579 [000] ...1 2322.030234: rtos_queue_peek_from_isr_failed: tstamp:72671585302 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2322.030240: rtcpu_vinotify_handle_msg: tstamp:72671652285 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3952175078 data:0x00000002
kworker/0:2-2579 [000] ...1 2322.186215: rtos_queue_peek_from_isr_failed: tstamp:72676585809 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2322.342219: rtos_queue_peek_from_isr_failed: tstamp:72681586318 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2322.550226: rtos_queue_peek_from_isr_failed: tstamp:72686586822 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2322.602222: rtcpu_vinotify_handle_msg: tstamp:72688697974 tag:CSIMUX_FRAME channel:0x02 frame:32964 vi_tstamp:3969220778 data:0x000000a0
kworker/0:2-2579 [000] ...1 2322.706227: rtcpu_vinotify_handle_msg: tstamp:72691529482 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3972052289 data:0x00000002
kworker/0:2-2579 [000] ...1 2322.706235: rtos_queue_peek_from_isr_failed: tstamp:72691587331 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2322.706238: rtcpu_vinotify_handle_msg: tstamp:72691600556 tag:CSIMUX_FRAME channel:0x02 frame:35972 vi_tstamp:3972123376 data:0x000000a0
kworker/0:2-2579 [000] ...1 2322.706242: rtcpu_vinotify_handle_msg: tstamp:72691951066 tag:CSIMUX_FRAME channel:0x02 frame:55312 vi_tstamp:3972473875 data:0x000000a0
kworker/0:2-2579 [000] ...1 2322.706245: rtcpu_vinotify_handle_msg: tstamp:72692690544 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3973213353 data:0x00000002
kworker/0:2-2579 [000] ...1 2322.862231: rtos_queue_peek_from_isr_failed: tstamp:72696587835 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2323.018233: rtos_queue_peek_from_isr_failed: tstamp:72701588344 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2323.122226: rtcpu_vinotify_handle_msg: tstamp:72705556500 tag:CSIMUX_FRAME channel:0x02 frame:27724 vi_tstamp:3986079307 data:0x000000a0
kworker/0:2-2579 [000] ...1 2323.122232: rtcpu_vinotify_handle_msg: tstamp:72705909765 tag:CSIMUX_FRAME channel:0x03 frame:9324 vi_tstamp:3986432574 data:0x000000a0
kworker/0:2-2579 [000] ...1 2323.122235: rtcpu_vinotify_handle_msg: tstamp:72705941933 tag:CSIMUX_FRAME channel:0x00 frame:32900 vi_tstamp:3986464752 data:0x000000a0
kworker/0:2-2579 [000] ...1 2323.174251: rtos_queue_peek_from_isr_failed: tstamp:72706588850 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2323.174258: rtcpu_vinotify_handle_msg: tstamp:72707048877 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3987571683 data:0x00000002
kworker/0:2-2579 [000] ...1 2323.226244: rtcpu_vinotify_handle_msg: tstamp:72707786378 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3988309185 data:0x00000002
kworker/0:2-2579 [000] ...1 2323.330235: rtos_queue_peek_from_isr_failed: tstamp:72711589354 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2323.434247: rtcpu_vinotify_handle_msg: tstamp:72714615906 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:3995138714 data:0x00000002
kworker/0:2-2579 [000] ...1 2323.486238: rtos_queue_peek_from_isr_failed: tstamp:72716589865 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2323.642255: rtos_queue_peek_from_isr_failed: tstamp:72721590370 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2323.798243: rtcpu_vinotify_handle_msg: tstamp:72726480141 tag:CSIMUX_FRAME channel:0x00 frame:61564 vi_tstamp:4007002650 data:0x000000a0
kworker/0:2-2579 [000] ...1 2323.798249: rtcpu_vinotify_handle_msg: tstamp:72726480341 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:61564 vi_tstamp:4007002651 data:0x00000001
kworker/0:2-2579 [000] ...1 2323.798252: rtcpu_vinotify_handle_msg: tstamp:72726480537 tag:ATOMP_FE channel:0x00 frame:61564 vi_tstamp:4007002653 data:0x00000001
kworker/0:2-2579 [000] ...1 2323.798257: rtos_queue_peek_from_isr_failed: tstamp:72726590878 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2323.850257: rtcpu_vinotify_handle_msg: tstamp:72728658516 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4009181320 data:0x00000002
kworker/0:2-2579 [000] ...1 2323.957384: rtcpu_vinotify_handle_msg: tstamp:72730553307 tag:CSIMUX_FRAME channel:0x02 frame:38024 vi_tstamp:4011076113 data:0x000000a0
kworker/0:2-2579 [000] ...1 2323.957389: rtcpu_vinotify_handle_msg: tstamp:72731522527 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4012045338 data:0x00000002
kworker/0:2-2579 [000] ...1 2323.957392: rtos_queue_peek_from_isr_failed: tstamp:72731591383 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2324.110239: rtos_queue_peek_from_isr_failed: tstamp:72736591897 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2324.266239: rtcpu_vinotify_handle_msg: tstamp:72740768641 tag:CSIMUX_FRAME channel:0x02 frame:36228 vi_tstamp:4021291432 data:0x000000a0
kworker/0:2-2579 [000] ...1 2324.266245: rtos_queue_peek_from_isr_failed: tstamp:72741592396 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2324.370249: rtcpu_vinotify_handle_msg: tstamp:72744498245 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4025021051 data:0x00000002
kworker/0:2-2579 [000] ...1 2324.422257: rtcpu_vinotify_handle_msg: tstamp:72746062780 tag:CSIMUX_FRAME channel:0x03 frame:59500 vi_tstamp:4026585587 data:0x000000a0
kworker/0:2-2579 [000] ...1 2324.422262: rtcpu_vinotify_handle_msg: tstamp:72746583164 tag:CSIMUX_FRAME channel:0x01 frame:35988 vi_tstamp:4027105972 data:0x000000a0
kworker/0:2-2579 [000] ...1 2324.422266: rtos_queue_peek_from_isr_failed: tstamp:72746592893 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2324.474246: rtcpu_vinotify_handle_msg: tstamp:72746709703 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4027232512 data:0x00000002
kworker/0:2-2579 [000] ...1 2324.474252: rtcpu_vinotify_handle_msg: tstamp:72747405856 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4027928663 data:0x00000002
kworker/0:2-2579 [000] ...1 2324.578247: rtcpu_vinotify_handle_msg: tstamp:72751483224 tag:CSIMUX_FRAME channel:0x02 frame:27756 vi_tstamp:4032006030 data:0x000000a0
kworker/0:2-2579 [000] ...1 2324.630252: rtos_queue_peek_from_isr_failed: tstamp:72751593410 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2324.682275: rtcpu_vinotify_handle_msg: tstamp:72754385820 tag:CSIMUX_FRAME channel:0x02 frame:51260 vi_tstamp:4034908629 data:0x000000a0
kworker/0:2-2579 [000] ...1 2324.682281: rtcpu_vinotify_handle_msg: tstamp:72754410029 tag:CSIMUX_FRAME channel:0x02 frame:50820 vi_tstamp:4034932849 data:0x000000a0
kworker/0:2-2579 [000] ...1 2324.786246: rtos_queue_peek_from_isr_failed: tstamp:72756593918 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2324.786251: rtcpu_vinotify_handle_msg: tstamp:72756707218 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4037230026 data:0x00000002
kworker/0:2-2579 [000] ...1 2324.942246: rtos_queue_peek_from_isr_failed: tstamp:72761594439 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2324.942252: rtcpu_vinotify_handle_msg: tstamp:72761706500 tag:CSIMUX_FRAME channel:0x02 frame:54152 vi_tstamp:4042229308 data:0x000000a0
kworker/0:2-2579 [000] ...1 2324.994257: rtcpu_vinotify_handle_msg: tstamp:72763641589 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4044164392 data:0x00000002
kworker/0:2-2579 [000] ...1 2325.098252: rtos_queue_peek_from_isr_failed: tstamp:72766594931 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2325.150252: rtcpu_vinotify_handle_msg: tstamp:72768949674 tag:CSIMUX_FRAME channel:0x02 frame:27748 vi_tstamp:4049472482 data:0x000000a0
kworker/0:2-2579 [000] ...1 2325.254255: rtos_queue_peek_from_isr_failed: tstamp:72771595439 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2325.306246: rtcpu_vinotify_handle_msg: tstamp:72772993036 tag:CSIMUX_FRAME channel:0x02 frame:35456 vi_tstamp:4053515844 data:0x000000a0
kworker/0:2-2579 [000] ...1 2325.306250: rtcpu_vinotify_handle_msg: tstamp:72774144179 tag:CSIMUX_FRAME channel:0x02 frame:34432 vi_tstamp:4054666988 data:0x000000a0
kworker/0:2-2579 [000] ...1 2325.358262: rtcpu_vinotify_handle_msg: tstamp:72775160287 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4055683096 data:0x00000002
kworker/0:2-2579 [000] ...1 2325.410253: rtos_queue_peek_from_isr_failed: tstamp:72776595944 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2325.462255: rtcpu_vinotify_handle_msg: tstamp:72778804117 tag:CSIMUX_FRAME channel:0x02 frame:8832 vi_tstamp:4059326922 data:0x000000a0
kworker/0:2-2579 [000] ...1 2325.514258: rtcpu_vinotify_handle_msg: tstamp:72779778183 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4060300990 data:0x00000002
kworker/0:2-2579 [000] ...1 2325.566253: rtos_queue_peek_from_isr_failed: tstamp:72781596453 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2325.618267: rtcpu_vinotify_handle_msg: tstamp:72782876887 tag:CSIMUX_FRAME channel:0x02 frame:34956 vi_tstamp:4063399695 data:0x000000a0
kworker/0:2-2579 [000] ...1 2325.670271: rtcpu_vinotify_handle_msg: tstamp:72784947776 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4065470585 data:0x00000002
kworker/0:2-2579 [000] ...1 2325.722264: rtos_queue_peek_from_isr_failed: tstamp:72786596973 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2325.774263: rtcpu_vinotify_handle_msg: tstamp:72787273510 tag:CSIMUX_FRAME channel:0x03 frame:12404 vi_tstamp:4067796323 data:0x000000a0
kworker/0:2-2579 [000] ...1 2325.774268: rtcpu_vinotify_handle_msg: tstamp:72788680429 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4069203234 data:0x00000002
kworker/0:2-2579 [000] ...1 2325.878256: rtos_queue_peek_from_isr_failed: tstamp:72791597458 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2326.034274: rtcpu_vinotify_handle_msg: tstamp:72795649837 tag:CSIMUX_FRAME channel:0x00 frame:34836 vi_tstamp:4076172649 data:0x000000a0
kworker/0:2-2579 [000] ...1 2326.034281: rtcpu_vinotify_handle_msg: tstamp:72796091149 tag:CHANSEL_PXL_SOF channel:0x00 frame:33928 vi_tstamp:4076613629 data:0x00000001
kworker/0:2-2579 [000] ...1 2326.034285: rtcpu_vinotify_handle_msg: tstamp:72796091393 tag:ATOMP_FS channel:0x00 frame:33928 vi_tstamp:4076613632 data:0x00000000
kworker/0:2-2579 [000] ...1 2326.034288: rtcpu_vinotify_handle_msg: tstamp:72796091564 tag:CHANSEL_FAULT channel:0x00 frame:33928 vi_tstamp:4076613770 data:0x00000100
kworker/0:2-2579 [000] ...1 2326.034291: rtcpu_vinotify_handle_msg: tstamp:72796092127 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:33928 vi_tstamp:4076614992 data:0x08000000
kworker/0:2-2579 [000] ...1 2326.034296: rtos_queue_peek_from_isr_failed: tstamp:72796597967 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2326.190266: rtos_queue_peek_from_isr_failed: tstamp:72801598471 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2326.190273: rtcpu_vinotify_handle_msg: tstamp:72801856125 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4082378937 data:0x00000002
kworker/0:2-2579 [000] ...1 2326.346262: rtos_queue_peek_from_isr_failed: tstamp:72806598980 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2326.502282: rtos_queue_peek_from_isr_failed: tstamp:72811599500 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2326.658262: rtcpu_vinotify_handle_msg: tstamp:72815415463 tag:CSIMUX_FRAME channel:0x02 frame:33672 vi_tstamp:4095938274 data:0x000000a0
kworker/0:2-2579 [000] ...1 2326.710264: rtos_queue_peek_from_isr_failed: tstamp:72816599993 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2326.710268: rtcpu_vinotify_handle_msg: tstamp:72817751311 tag:CSIMUX_FRAME channel:0x02 frame:34432 vi_tstamp:4098274124 data:0x000000a0
kworker/0:2-2579 [000] ...1 2326.710272: rtcpu_vinotify_handle_msg: tstamp:72817757541 tag:CSIMUX_FRAME channel:0x02 frame:42368 vi_tstamp:4098280352 data:0x000000a0
kworker/0:2-2579 [000] ...1 2326.762261: rtcpu_vinotify_handle_msg: tstamp:72818232857 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4098755663 data:0x00000002
kworker/0:2-2579 [000] ...1 2326.866272: rtos_queue_peek_from_isr_failed: tstamp:72821600506 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2326.970280: rtcpu_vinotify_handle_msg: tstamp:72826088172 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:33928 vi_tstamp:4106610961 data:0x08000000
kworker/0:2-2579 [000] ...1 2326.970286: rtcpu_vinotify_handle_msg: tstamp:72826235251 tag:CSIMUX_FRAME channel:0x02 frame:18561 vi_tstamp:4106758056 data:0x000000a0
kworker/0:2-2579 [000] ...1 2327.022274: rtos_queue_peek_from_isr_failed: tstamp:72826601013 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2327.022279: rtcpu_vinotify_handle_msg: tstamp:72827621327 tag:CSIMUX_FRAME channel:0x03 frame:27880 vi_tstamp:4108144135 data:0x000000a0
kworker/0:2-2579 [000] ...1 2327.074293: rtcpu_vinotify_handle_msg: tstamp:72828151992 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4108674804 data:0x00000002
kworker/0:2-2579 [000] ...1 2327.074299: rtcpu_vinotify_handle_msg: tstamp:72829201759 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4109724567 data:0x00000002
kworker/0:2-2579 [000] ...1 2327.178286: rtos_queue_peek_from_isr_failed: tstamp:72831601522 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2327.230285: rtcpu_vinotify_handle_msg: tstamp:72832865658 tag:CSIMUX_FRAME channel:0x02 frame:8048 vi_tstamp:4113388464 data:0x000000a0
kworker/0:2-2579 [000] ...1 2327.334274: rtos_queue_peek_from_isr_failed: tstamp:72836602040 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2327.386282: rtcpu_vinotify_handle_msg: tstamp:72838592906 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:4119115713 data:0x00000002
kworker/0:2-2579 [000] ...1 2327.438273: rtcpu_vinotify_handle_msg: tstamp:72839269040 tag:CSIMUX_FRAME channel:0x00 frame:33928 vi_tstamp:4119791550 data:0x000000a0
kworker/0:2-2579 [000] ...1 2327.438281: rtcpu_vinotify_handle_msg: tstamp:72839269239 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:33928 vi_tstamp:4119791551 data:0x00000001
kworker/0:2-2579 [000] ...1 2327.438284: rtcpu_vinotify_handle_msg: tstamp:72839269433 tag:ATOMP_FE channel:0x00 frame:33928 vi_tstamp:4119791554 data:0x00000000
kworker/0:2-2579 [000] ...1 2327.490278: rtos_queue_peek_from_isr_failed: tstamp:72841602535 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2327.646277: rtos_queue_peek_from_isr_failed: tstamp:72846603043 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2327.802279: rtos_queue_peek_from_isr_failed: tstamp:72851603547 queue:0x0b4a3c58
kworker/0:2-2579 [000] ...1 2327.958279: rtos_queue_peek_from_isr_failed: tstamp:72856604056 queue:0x0b4a3c58
I was wondering if anyone has experiencing this issue before, and if so point to to any changes made that could be cause it.
Regards,
JJ
