VibeVoice-ASR on DGX Spark: a 59-minute recording in one pass, with speakers and timestamps (no chunking)
A while back someone asked how to transcribe long recordings on a Spark. The answers were Parakeet and Whisper, both with the audio cut into chunks. I wanted to see what happens if you don’t cut it at all.
Microsoft’s VibeVoice-ASR (8.7B) takes up to 60 minutes of audio in a single pass and returns who spoke when, in the same output. So I gave it a 59-minute NASA press conference and a 39-minute four-person meeting on a Spark.
Repo with a one-command setup and the full write-up: MindrLabs/speech-to-text-vibevoice
39-minute AMI meeting, 4 speakers. For each speaker, top lane is the human reference, bottom lane is the model.
Short version
  • The whole 59:24 recording went in at once. 28.1 GB peak, 230 segments, last one ending at 59:23. A 24 GB RTX 4090 ran out of memory at 39 minutes.
  • Speakers come out consistent across the whole file. No stitching speaker labels across chunk boundaries. On the 4-person meeting it got the speaker count right with both headset and table-mic audio.
  • It’s slow. A 10-minute file finishes faster than real time; from 39 minutes on it takes longer than the recording. This is an overnight-batch tool on a Spark, not live captions.
  • One trap worth knowing before you batch anything: on noisy audio it can loop, and the result comes back as an empty list with no error.
How long it takes on a Spark
Recording Length Time RTF Peak memory
Press conference excerpt 10 min 6 min 7 s 0.61 21.3 GB
AMI meeting 38 min 54 s ~51 min 1.30–1.32 24.4 GB
Press conference, full 59 min 24 s 85 min 36 s 1.44 28.1 GB
RTF climbs with length because the transcript is generated token by token and each token attends to the whole audio context (7.5 audio tokens per second).
For scale, the same 10-minute file on a 4090 took 80 s instead of 367 s: 41.5 vs 8.9 generated tokens/s. That gap looks like decode bandwidth to me (1,008 vs 273 GB/s), though I haven’t profiled it. So the 4090 wins on anything it can hold, and the Spark’s job here is the files the 4090 can’t.
How good are the speakers
AMI ES2004c, the same meeting recorded with headsets and with one table microphone at the same time:
%, lower is better Headset Table mic
WER 17.1 21.4
cpWER (per speaker) 15.5 20.4
DER (±0.25 s collar) 11.3 17.5
Speakers found (truth: 4) 4 4
One table mic, which is roughly what you get recording a meeting on a laptop, cost about 4 points of WER and 6 of DER. These are in the same range as the numbers in the VibeVoice paper, but it’s one meeting, and AMI may well be in the training data.
The press conference was messier: rotating questioners came out as 25 speakers, 18 of them with only 1–3 segments. It probably split some people into several IDs.
The trap: an empty result that isn’t silence
Two 1962 Friendship 7 radio clips came back as []. The model did hear them. The raw output starts right:
Fifteen seconds. Godspeed, John Glenn. Ten, nine, eight, seven.
Then, in a noisy stretch, it repeated “Roger, turn around.” 280 times until the token limit. The segment JSON never closes, the VibeVoice parser logs a warning and returns an empty list, and your pipeline records “nobody spoke”.
What I checked:
  • Every run looped: with and without hotwords, 45 s and 100 s clips, through a server and a direct call.
  • Pure noise (silence, white, pink, radio band) did not loop. It returned a single [Silence] or [Noise] tag.
  • Clean long recordings (39 and 59 min) ended normally.
So it’s speech mixed with heavy noise that sets it off. A repetition check caught all four loops between 450 and 1,100 tokens and never fired on normal output. The idea is to stop when the last 400 tokens repeat with a period of 100 tokens or less:
def is_looping(token_ids, window=400, max_period=100):
    tail = token_ids[-window:]
    if len(tail) < window:
        return False
    return any(tail[p:] == tail[:-p] for p in range(1, max_period + 1))
If you’re pointing this at an archive overnight, add a token limit and a check like this, and treat an empty result as “go look at the raw output”.
Other things that might save you time
  • Hotwords work for names. Pass names and terms as context_info. They fixed misspelled Korean names and didn’t change processing time on the Spark (366.6 s vs 369.3 s).
  • For short clips without speakers, Whisper large-v3 is still the better pick. On the same read sentences (FLEURS, English/Korean/Chinese), Whisper with the language set dropped no sentences. VibeVoice dropped some whole Korean and Chinese sentences. Whisper also used about a quarter of the memory. That comparison ran on the 4090.
  • Strip the trailing tags. Outputs often end with [Silence] or [Music]. Remove them before display.
  • There’s a streaming variant (VibeVoice-ASR-Streaming-7B). On the 4090 it showed first text in 0.7–2.3 s and kept the 4 meeting speakers apart. I haven’t run it on the Spark.
Try it
pip install model-compose
git clone https://github.com/MindrLabs/speech-to-text-vibevoice
cd speech-to-text-vibevoice
model-compose up
Gradio on :8102, HTTP API on :8101. The first start installs torch into a venv and pulls the 17.3 GB checkpoint.
curl -o out.json localhost:8101/api/workflows/runs \
  -F workflow_id=transcribe -F wait_for_completion=true -F output_only=true \
  -F "input.audio=@meeting.wav" -F "input.context_info=Alice, Bob, Project Falcon"
You get back {text, start_time, end_time, speaker_id} segments.
Full write-up, with hotwords, code-switching, number formatting, the Whisper comparison and a 16 GB Mac running a 4-bit conversion: MindrLabs/speech-to-text-vibevoice
Setup and how it was measured
  • DGX Spark: GB10, 120 GB unified, shared machine, driver 580.126.09, CUDA 13.0.
  • Weights: microsoft/VibeVoice-ASR rev d0c9efdb, bf16, sdpa attention, greedy decoding (temperature 0, beam 1).
  • Spark timings and memory: a script calling transformers directly, one run per file. Memory is PyTorch peak allocation.
  • RTX 4090 comparison: the same script and settings on the same two files.
  • Not measured: quantization (NVFP4/FP8) or vLLM on the Spark, the streaming model on the Spark, live mic input, the exact length where Spark RTF crosses 1.0, and long-recording comparisons against Parakeet or WhisperX.
Two questions for people already doing long-form ASR on a Spark:
  1. If you chunk with Parakeet or WhisperX, how do you keep speaker IDs consistent across chunks? That’s the part that made me try a one-pass model.
  2. Has anyone got VibeVoice-ASR running under vLLM on GB10? I’d like to know how much of that 8.9 tok/s is the transformers path rather than the hardware.
