Video analytics
Jetpack-4.5.1
deepstream-5.1
Ubentu 18.04 LTS
cuda version-10.2
TenserRT-7.1.3.1
Use Trafficcamnet model for detection please refere below pgie config file data and suggest me improve true detection(Miss incidents small size vehicles in view) and reduce false detection and detect 15 vehicles in zone than as queue event.
Copyright (c) 2018-2021, NVIDIA CORPORATION. All rights reserved.
Permission is hereby granted, free of charge, to any person obtaining a
copy of this software and associated documentation files (the “Software”),
to deal in the Software without restriction, including without limitation
the rights to use, copy, modify, merge, publish, distribute, sublicense,
and/or sell copies of the Software, and to permit persons to whom the
Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
DEALINGS IN THE SOFTWARE.
Following properties are mandatory when engine files are not specified:
int8-calib-file(Only in INT8)
Caffemodel mandatory properties: model-file, proto-file, output-blob-names
UFF: uff-file, input-dims, uff-input-blob-name, output-blob-names
ONNX: onnx-file
Mandatory properties for detectors:
num-detected-classes
Optional properties for detectors:
cluster-mode(Default=Group Rectangles), interval(Primary mode only, Default=0)
custom-lib-path
parse-bbox-func-name
Mandatory properties for classifiers:
classifier-threshold, is-classifier
Optional properties for classifiers:
classifier-async-mode(Secondary mode only, Default=false)
Optional properties in secondary mode:
operate-on-gie-id(Default=0), operate-on-class-ids(Defaults to all classes),
input-object-min-width, input-object-min-height, input-object-max-width,
input-object-max-height
Following properties are always recommended:
batch-size(Default=1)
Other optional properties:
net-scale-factor(Default=1), network-mode(Default=0 i.e FP32),
model-color-format(Default=0 i.e. RGB) model-engine-file, labelfile-path,
mean-file, gie-unique-id(Default=0), offsets, process-mode (Default=1 i.e. primary),
custom-lib-path, network-mode(Default=0 i.e FP32)
The values in the config file are overridden by values set through GObject
properties.
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-engine-file=/opt/nvidia/deepstream/deepstream-5.1/sources/deepstream_python_apps/models/tlt_pretrained_models/trafficcamnet/resnet18_trafficcamnet_pruned.etlt_b1_gpu0_fp16.engine
labelfile-path=/opt/nvidia/deepstream/deepstream-5.1/sources/deepstream_python_apps/models/tlt_pretrained_models/trafficcamnet/labels.txt
int8-calib-file=/opt/nvidia/deepstream/deepstream-5.1/sources/deepstream_python_apps/models/tlt_pretrained_models/trafficcamnet/cal_trt.bin
input-dims=3;544;960;0
uff-input-blob-name=input_1
batch-size=30
process-mode=1
model-color-format=0
0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=4
interval=0
gie-unique-id=1
output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
force-implicit-batch-dim=1
#parse-bbox-func-name=NvDsInferParseCustomResnet
#custom-lib-path=/path/to/libnvdsparsebbox.so
0=Group Rectangles, 1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
cluster-mode=3
#scaling-filter=0
#scaling-compute-hw=0
[class-attrs-all]
pre-cluster-threshold=0.1
group-threshold=1
Set eps=0.7 and minBoxes for cluster-mode=1(DBSCAN)
eps=0.7
minBoxes=3
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
Per class configurations
[class-attrs-0]
pre-cluster-threshold=0.15
eps=0.5
dbscan-min-score=0.45
[class-attrs-1]
pre-cluster-threshold=0.01
eps=0.5
dbscan-min-score=0.50
[class-attrs-2]
pre-cluster-threshold=0.3
eps=0.25
dbscan-min-score=0.90
regards
gaurang patel
  1. The TAO TrafficCamNet has been updated for several versions. You may try the newer version to get better performence.
  2. The cluster parameters Gst-nvinfer — DeepStream documentation 6.4 documentation can be adjusted. You may try to set “threshold=0”, “pre-cluster-threshold=0” to keep the bboxes as much as possible.
Please give me link of Tao newer model
It’s give me false wrong direction detection for nvanalytics in deepstram python code.
I used above configure for detection
Regards
GaurangKumar patel
The TAO trafficcamnet is published in TrafficCamNet | NVIDIA NGC
Can you provide the video and your configurations(including nvanalytics configuration) you got the wrong direction?
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=1
[property]
enable=1
enable_perf_measurement=1
config-width=1280
config-height=960
osd-mode=0
display-font-size=15
[roi-filtering-stream-0]
enable=1
roi-RF1=576;126;645;125;577;928;121;928
roi-RF2=659;171;705;101;1189;887;650;907
class-id=-1
inverse-roi=0
[direction-detection-stream-0]
enable=1
direction-FORWARD=436;658;571;241
direction-REVERSE=712;197;853;618
Wrong_direction_RF1=REVERSE
Wrong_direction_RF2=FORWARD
class-id=-1
Please find configuration for zone
Please suggest me model and how configure new model for above image seen. That new model.
Method to deploy with existing code.
Regards
GaurangKumar patel
There is already sample nvinfer configuration file in the NGC link. TrafficCamNet | NVIDIA NGC
I also require Truck class in that model. Please tell me major difference. From previous version.
Regards
GaurangKumar patel
For the model itself, please consult in TAO forum. Latest Intelligent Video Analytics/TAO Toolkit topics - NVIDIA Developer Forums
Please add my topic on Tao forums.
Regards
GaurangKumar patel
Topic closed as model related discssion in TAO already Trafficcamnet add truck class detection with other class and false detection occur.issue to detect small vehicles.miss detection.
