I’m trying to run AppTrans app from Video_Codec_SDK_9.1.23/Samples/AppTranscode on Ubuntu machine with GeForce RTX 2070 gpu.
I’m trying to transcode the input file to two hevc files with different bitrates. On output I do have two files, they both are playable, but has exactly the same size and diff returns nothing, it’s just the same file.
At the beginning of the run the encoder parameters are dumped out, and I do see the assigned bitrate.
mediainfo returns no bitrate info(but, for example, correct fps), and ffprobe gives N/A for bitrate.
Please advice. Thanks in advance. Here is my console output:
ericsson@z1:~/NVIDIA/Video_Codec_SDK_9.1.23/Samples/AppTranscode/AppTrans$ time ./AppTrans -i ~/sync/archive/bbb_sunflower_2160p_60fps_normal.mp4 -o out_2021-6m.hevc -codec hevc -bitrate 6m -fps 60
GPU in use: GeForce RTX 2070
[INFO ][00:57:49] Media format: QuickTime / MOV (mov,mp4,m4a,3gp,3g2,mj2)
Session Initialization Time: 17 ms
[INFO ][00:57:49] Encoding Parameters:
codec : hevc
preset : default
profile : (default)
chroma : yuv420
bitdepth : 8
rc : constqp (P,B,I=28,31,25)
fps : 60/1
gop : INF
bf : 0
bitrate : 6000000
maxbitrate : 0
vbvbufsize : 0
vbvinit : 0
aq : disabled
temporalaq : disabled
lookahead : disabled
cq :
qmin : P,B,I=0,0,0
qmax : P,B,I=0,0,0
initqp : P,B,I=0,0,0
209468
Total frame transcoded: 38072
Saved in file out_2021-6m.hevc of 8 bit depth
Session Deinitialization Time: 23 ms
real 7m7.802s
user 6m57.028s
sys 0m1.456s
ericsson@z1:~/NVIDIA/Video_Codec_SDK_9.1.23/Samples/AppTranscode/AppTrans$ time ./AppTrans -i ~/sync/archive/bbb_sunflower_2160p_60fps_normal.mp4 -o out_2021-3m.hevc -codec hevc -bitrate 3m -fps 60
[INFO ][01:13:55] Media format: QuickTime / MOV (mov,mp4,m4a,3gp,3g2,mj2)
Session Initialization Time: 16 ms
[INFO ][01:13:56] Encoding Parameters:
codec : hevc
preset : default
profile : (default)
chroma : yuv420
bitdepth : 8
fps : 60/1
gop : INF
bf : 0
bitrate : 3000000
maxbitrate : 0
vbvbufsize : 0
vbvinit : 0
aq : disabled
cq :
qmin : P,B,I=0,0,0
qmax : P,B,I=0,0,0
209468
Saved in file out_2021-3m.hevc of 8 bit depth
Session Deinitialization Time: 17 ms
real 7m8.323s
user 6m57.515s
sys 0m1.336s
ericsson@z1:~/NVIDIA/Video_Codec_SDK_9.1.23/Samples/AppTranscode/AppTrans$ ls -la *.hevc
-rw-r–r-- 1 ericsson ericsson 696188003 Jan 19 01:21 out_2021-3m.hevc
-rw-r–r-- 1 ericsson ericsson 696188003 Jan 19 01:04 out_2021-6m.hevc
ericsson@z1:~/NVIDIA/Video_Codec_SDK_9.1.23/Samples/AppTranscode/AppTrans$ diff out_2021-6m.hevc out_2021-3m.hevc
ericsson@z1:~/clean_Video_Codec_SDK_9.1.23/Video_Codec_SDK_9.1.23/Samples/AppTranscode/AppTrans$
