I wish to run visual odometry app with custom hardware, I successfully implemented a pipeline to retrieve image from my camera and split it.
I can convert the video feed to RGB with gst without issues but when I try to convert it to gray scale the application terminate unexpectedly. Could you try to spot my error please.
This is the line working :
"pipeline": "gst-launch-1.0 -v v4l2src device=/dev/video0 ! avdec_mjpeg ! videoconvert ! video/x-raw,format=RGB,height=480,framerate=30/1 ! appsink name = acquired_image "
This is what I want to do :
"pipeline": "gst-launch-1.0 -v v4l2src device=/dev/video0 ! avdec_mjpeg ! videoconvert ! video/x-raw,format=GRAY8,height=480,framerate=30/1 ! appsink name = acquired_image "
Thank you
This is the successful app :
"name": "odov1",
"modules": [
"deepstream",
"perception",
"sight",
"viewers"
"graph": {
"nodes": [
"name": "acquisition",
"components": [
"name": "message_ledger",
"type": "isaac::alice::MessageLedger"
"name": "pipeline",
"type": "isaac::deepstream::Pipeline"
"name": "compute",
"components": [
"name": "operation1",
"type": "isaac::perception::CropAndDownsampleCuda"
"name": "operation2",
"name": "publishing",
"components": [
"name": "viewer1",
"type": "isaac::viewers::ColorCameraViewer"
"name": "viewer2",
"name": "viewer3",
"name": "viewer1_widget",
"type": "isaac::sight::SightWidget"
"name": "viewer2_widget",
"name": "viewer3_widget",
"edges": [
"source": "acquisition/pipeline/acquired_image",
"target": "compute/operation1/input_image"
"target": "compute/operation2/input_image"
"target": "publishing/viewer3/color_listener"
"source": "compute/operation1/output_image",
"target": "publishing/viewer1/color_listener"
"source": "compute/operation2/output_image",
"target": "publishing/viewer2/color_listener"
"config": {
"acquisition": {
"pipeline": {
"compute": {
"operation1": {
"crop_start": [0, 0],
"crop_size": [480, 640]
"operation2": {
"crop_start": [0, 640],
"publishing": {
"viewer1_widget": {
"title": "Viewer: Video Left",
"type": "2d",
"channels": [
"name": "publishing/viewer1/Color"
"viewer2_widget": {
"title": "Viewer: Video Right",
"type": "2d",
"channels": [
"name": "publishing/viewer2/Color"
"viewer3_widget": {
"title": "Viewer: Acquis ",
"type": "2d",
"channels": [
"name": "publishing/viewer3/Color"
