Video Decoder Warnings and Format Probing Issues
Description
Hi all, when running the DeepStream application (deepstream-test1-app) in a Docker container, I encounter multiple warnings related to video formats and capture sizes, indicating an issue with probing pixel formats for the video decoder. This issue prevents the application from processing video streams correctly.
Environment
Model: NVIDIA Jetson Orin NX
Kernel Version: R36 (release), REVISION: 3.0
Architecture: aarch64
TensorRT Version: 8.6.1.6
GPU Type: Orin (nvgpu)
Nvidia Driver Version: The driver version is not reported in nvidia-smi. The L4T version might be relevant here.
CUDA Version: 12.2
CUDNN Version: 8.9.7.29
Operating System + Version: Ubuntu 22.04 with L4T (Linux for Tegra)
DeepStream Version: 7.0.0
Container: Docker container, nvcr.io/nvidia/deepstream:7.0-triton-arm-sbsa
Steps To Reproduce
1. Setup the environment
sudo apt update
sudo apt upgrade
curl -fsSL https://nvidia.github.io/libnvidia-container/gpgkey | sudo gpg --dearmor -o /usr/share/keyrings/nvidia-container-toolkit-keyring.gpg \
  && curl -s -L https://nvidia.github.io/libnvidia-container/stable/deb/nvidia-container-toolkit.list | \
    sed 's#deb https://#deb [signed-by=/usr/share/keyrings/nvidia-container-toolkit-keyring.gpg] https://#g' | \
    sudo tee /etc/apt/sources.list.d/nvidia-container-toolkit.list
sudo apt-get update
sudo apt-get install -y nvidia-container-toolkit
dpkg -l | grep nvidia-container-toolkit
sudo systemctl restart docker
sudo systemctl status docker
2. Run the docker container
docker pull nvcr.io/nvidia/deepstream:7.0-triton-arm-sbsa
sudo apt-get install x11-xserver-utils
export DISPLAY=:1
xhost +
mkdir -p ~/deepstream_data
docker run -it --runtime=nvidia \
    --network=host \
    -e NVIDIA_DRIVER_CAPABILITIES=compute,utility,video,graphics \
    --gpus all \
    --privileged \
    -e DISPLAY=$DISPLAY \
    -v /tmp/.X11-unix:/tmp/.X11-unix \
    -v /etc/X11:/etc/X11 \
    -v ~/deepstream_data:/data \
3. Install additional packages inside the container
apt-get install \
    libssl3 \
    libssl-dev \
    libgstreamer1.0-0 \
    gstreamer1.0-tools \
    gstreamer1.0-plugins-good \
    gstreamer1.0-plugins-bad \
    gstreamer1.0-plugins-ugly \
    gstreamer1.0-libav \
    gstreamer1.0-alsa \
    libgstrtspserver-1.0-0 \
    libjansson4 \
    libyaml-cpp-dev
4. Run the deepstream application
GST_DEBUG=3 ./deepstream-test1-app /opt/nvidia/deepstream/deepstream-7.0/samples/streams/sample_720p.h264
Full traceback of errors encountered
root@ubuntu:/opt/nvidia/deepstream/deepstream-7.0/sources/apps/sample_apps/deepstream-test1# GST_DEBUG=3 ./deepstream-test1-app /opt/nvidia/deepstream/deepstream-7.0/samples/streams/sample_720p.h264
Added elements to bin
Using file: /opt/nvidia/deepstream/deepstream-7.0/samples/streams/sample_720p.h264
0:00:00.287753145  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.287819066  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat MJPG
0:00:00.287839163  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.287851643  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat MJPG
0:00:00.287892700  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.287907869  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat AV10
0:00:00.287921341  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.287932221  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat AV10
0:00:00.287954302  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.287966782  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat DVX5
0:00:00.287976863  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.287987039  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat DVX5
0:00:00.288004351  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.288012544  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat DVX4
0:00:00.288022048  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.288028960  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat DVX4
0:00:00.288047968  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.288059201  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat MPG4
0:00:00.288067073  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.288076897  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat MPG4
0:00:00.288091842  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.288109410  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat MPG2
0:00:00.288116130  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.288122754  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat MPG2
0:00:00.288140739  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.288148323  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat H265
0:00:00.288155203  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.288161891  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat H265
0:00:00.288175492  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.288182852  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat VP90
0:00:00.288189700  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.288196260  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat VP90
0:00:00.288208421  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.288215557  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat VP80
0:00:00.288222085  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.288228741  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat VP80
0:00:00.288244550  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.288252294  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat H264
0:00:00.288259174  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.288265798  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat H264
0:00:00.288808181  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:00.288826933  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe minimum capture size for pixelformat Y444
0:00:00.288835477  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:00.288842997  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe maximum capture size for pixelformat Y444
0:00:00.288862742  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:00.288871030  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe minimum capture size for pixelformat P410
0:00:00.288877654  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:00.288884503  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe maximum capture size for pixelformat P410
0:00:00.288898999  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:00.288906423  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe minimum capture size for pixelformat PM10
0:00:00.288913271  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:00.288919512  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe maximum capture size for pixelformat PM10
0:00:00.288934264  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:00.288943000  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe minimum capture size for pixelformat NM12
0:00:00.288950104  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:00.288957593  9665 0xaaab0763f390 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe maximum capture size for pixelformat NM12
Setting min object dimensions as 16x16 instead of 1x1 to support VIC compute mode.
Hi all, is that any updates or solution for this issue? Is that the hardware problem or missing some libraries? Thank you for your help!
