I wanna decode the mp4 file and write the YUV file. My pipeline is
gst-launch-1.0 filesrc location=~/Desktop/sample.mp4 ! qtdemux ! queue ! h264parse ! nvv4l2decoder ! filesink location=~/Desktop/ss.yuv
The processing gets stuck and never ends. How do i get to save it as the yuv file after the decoding process ?
Please provide the complete log when executing the command, and as you are using h264parse, please be sure your mp4 file contains h264 stream, you can use command “gst-discoverer-1.0 ~/Desktop/sample.mp4” to double check.
Please also provide complete information as applicable to your setup.
• DeepStream Version
• TensorRT Version
• The pipeline being used
Hi, the pipeline works pretty well but the !nvvideoconvert! needs to be replaced with !nvvidconv! . ALSO when i playback the .yuv file it is not same as the original file. That means I am not sure what does the nvvidconv default output is. But when i include ! ‘video/x-raw format=(string)I420’ ! , I am able to play back the original video from the .yuv file .
