hello,
there is question that i want to encode video(H264) with 75fps,i refer to sample:
jetson_multimedia_api/samples/01_video_encode,
but in any case, it can only produce a maximum frame rate of 60(h264 ES stream)
i set --insert-vui and fps like this:
sudo ./video_encode trailer.yuv 854 480 H264 b.h264 -fps 75 1 --insert-vui
Now I suspect the driver limits this setting???
We will check and update. For information, please share your release version( $ head -1 /etc/nv_tegra_release )
R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t210ref, EABI: aarch64, DATE: Fri Jun 26 04:38:25 UTC 2020
it is the lastest version, jetpack 4.4
Thanks for information. It is under investigation. Will update once there is new finding.
Please try the attachment.
/usr/lib/aarch64-linux-gnu/tegra/libnvtvmr.so
r32_4_3_TEST_libnvtvmr.zip (254.5 KB)
thanks, and i will try it.
It is useful. Hope to fix it in future release. Thanks.
