Hi everyone. I am trying to encode a video file, but I seem to get encoding issues. The output video comes out green!
To record the video I am using
gst-launch-1.0 v4l2src extra-controls=s,exposure=147434 device=/dev/video0 ! video/x-raw,format=BGRx ! filesink location = tester_2.mp4 -e
and then, to encode I use:
gst-launch-1.0 filesrc location=tester_2.mp4 ! videoparse ! videoconvert ! omxh265enc preset-level=0 temporal-tradeoff=0 ! qtmux ! filesink location = test.mp4 -e
I know it looks counter-intuitive to capture in BGRx, convert to YUV then convert back to be able to encode, but I am running some benchmarks, and need the intermediate step.
I am also able to capture video using v4l2-ctl with the following command:
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1456,height=1088,pixelformat=VYUY --set-ctrl bypass_mode=0 --stream-mmap --stream-count=10 --stream-to=test.raw
but I get the same issue when attempting to encode the video.
For reference, when encoding, the output looks like this:
Is my encoding pipeline wrong?
Please try the pipeline and check if you can see video preview:
$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=VYUY,width=1456,height=1088,framerate=30/1 ! videoconvert ! video/x-raw,format=NV12 ! nvvidconv ! nvoverlaysink
Hi @DaneLLL , unfortunatly this pipeline wonāt compile as V4L2 doesnāt support VYUY, as far as iām aware to get VYUY I would need to run āvideoconvertā
P.S to check which formats were compatible with V4L2src I used:
gst-inspect-1.0 v4l2src
Please check if the source can output YUYV or UYVY. Need to have the v4l2src-supported format or may not be able to run on Jetson platforms.
My Camera supports the following pixel formats:
Index : 1
Type : Video Capture
Pixel Format: 'BX24'
Name : 32-bit XRGB 8-8-8-8
Size: Discrete 1456x1088
Interval: Discrete 0.020s (49.688 fps)
Index : 2
Pixel Format: 'XR24'
Name : 32-bit BGRX 8-8-8-8
Index : 3
Pixel Format: 'VYUY'
However I know that VYUY is not supported by V4L2src.
One thing though, is I can source video from my camera using:
But Iām not sure how to then encode the created file. Perhaps @DaneLLL you have an idea?
You can try BGRx:
gst-launch-1.0 v4l2src ! video/x-raw,format=BGRx,width=1456,height=1088,framerate=50/1 ! videoconvert ! xvimagesink
check if you can launch the pipeline with the format.
alexisguiter:
49.688
It should be ok for some time, but for longer video recording, you may try to adjust framerate from 50/1 to 6211/125 according to your driver interval:
..., framerate=6211/125 ! ...
Yes this pipeline does work, I have tested it numerous times. It would just be more convenient to obtain YUV directly
@DaneLLL Any updates?
I could try to encode the data from this pipeline:
How would you recommend I do so?
Best,
Alexis
Since VYUY is not supported in v4l2src , you may consider to use jetson_multiemdia_api. Please try the sample in
/usr/src/jetson_multimedia_api/samples/12_camera_v4l2_cuda/
See if you can run it successfully and see video preview.
Hi @DaneLLL
Unfortunately that script did not work with my camera.
VYUY is supported in the sample:
-f Set output pixel format of video device (supports only YUYV/YVYU/UYVY/VYUY/GREY/MJPEG)
You may other USB cameras as comparison. Usually USB cameras output in YUYV or UYVY. We can run the sample with Logitech c930 and E-Con CU135. You may check if you can run the sample with either USB camera.
