Video flip while using for inference
Hi!
• Hardware Platform (Jetson Nano/ GPU)
**• DeepStream Version5
**• JetPack Version (valid for Jetson only)4.4
**• TensorRT Version*7.1.3+Cuda10.2
I have an issue while using a video for inference taken from mobile camera, but when I use it for inference it flips and if I am running with its remain same. If someone has faced the same issue, kindly help.
Can you provide the video to us? Which application are you using? Can you tell us your configuration?
Thanks for your reply. Actually I was using deepstream and Yolo custom model, but when I tried with the video viewer the video flips. If I am using sample videos there is no problem like this. Kindly guide.
demo_2.mp4
I can not access the link
There is an internal error while sharing with you accur.
Kindly use this link
https://drive.google.com/file/d/1hwkuhX6bhkolfgR_28VxfEHEgs_l-ouY/view?usp=sharing.
Can you tell us which app are you using? What is your configuration?
