Videos are being flipped in 4.3 Jetpack, these are not live stream, stored on the hard disk
image url
https://ibb.co/gTpX4Md
[source2]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
#orginal#uri=file:/media/LFS/PIXEL_4K_30FPS_INORBIT01.mp4
uri=file:/media/LFS/PIXEL_4K_30FPS_IKEA01.mp4
num-sources=1
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[source3]
enable=3
type=3
uri=file:/media/LFS/PIXEL_4K_30FPS_INORBIT02.mp4
num-sources=1
gpu-id=0
cudadec-memtype=0
mediainfo PIXEL_4K_30FPS_INORBIT01.mp4
General
Complete name : PIXEL_4K_30FPS_INORBIT01.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/mp42)
File size : 1.45 GiB
Duration : 4 min 19 s
Overall bit rate : 48.1 Mb/s
Encoded date : UTC 2019-12-19 05:45:19
Tagged date : UTC 2019-12-19 05:45:19
xyz : +17.4337+078.3846/
com.android.version : 10
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.1
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Source duration : 4 min 19 s
Bit rate : 48.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Rotation : 180°
Frame rate mode : Variable
Frame rate : 30.000 FPS
Minimum frame rate : 29.880 FPS
Maximum frame rate : 30.161 FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.193
Stream size : 1.45 GiB (100%)
Source stream size : 1.45 GiB (100%)
Title : VideoHandle
Language : English
Color range : Full
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
mdhd_Duration : 259221
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : mp4a-40-2
Bit rate mode : Constant
Bit rate : 96.0 kb/s
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 2.97 MiB (0%)
Source stream size : 2.97 MiB (0%)
Title : SoundHandle
Language : English
mdhd_Duration : 259203
