• Hardware Platform (Jetson / GPU) - Jetson Nano • DeepStream Version - 6.0 • JetPack Version (valid for Jetson only) - 4.6.1-b110 • TensorRT Version - 8.2.1.8 • NVIDIA GPU Driver Version (valid for GPU only) - 10.2 • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
please refer this link, it a continuation of this thread
we add valve and tee component in deepstream pipeline
frames dropping working properly using valve, but it is not restarting again, could you please assist me to solve this issue
Hi , I’m using valve to start and stop a recording with a tee branch , but
the problem is when i set valve’s “drop” property to true , the video
recording won’t stop.
You can not use “valve” in this way. The set “valve” drop to True from the beggining will cause the sink goes into preroll state. Preroll (gstreamer.freedesktop.org). Please unlock preroll when you want to send buffer to preroll sink.
This issue is not DeepStream related. Please refer to GStreamer resources.
