This is my pipe setup
print("Creating Pgie \n ")
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
print("Creating nvvidconv1 \n ")
nvvidconv1 = Gst.ElementFactory.make("nvvideoconvert", "convertor1")
if not nvvidconv1:
sys.stderr.write(" Unable to create nvvidconv1 \n")
nvvidconv1.set_property("src-crop","320:200:1280:720")
print("Creating filter1 \n ")
caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
filter1 = Gst.ElementFactory.make("capsfilter", "filter1")
if not filter1:
sys.stderr.write(" Unable to get the caps filter1 \n")
filter1.set_property("caps", caps1)
tracker = Gst.ElementFactory.make("nvtracker", "tracker")
if not tracker:
sys.stderr.write(" Unable to create tracker \n")
print("Creating tiler \n ")
tiler=Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
if not tiler:
sys.stderr.write(" Unable to create tiler \n")
print("Creating nvvidconv \n ")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
print("Creating nvosd \n ")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
print("Creating EGLSink \n")
sink = Gst.ElementFactory.make("nvoverlaysink", "nvvideo-renderer")
sink.set_property('sync',False)
sink.set_property('overlay-x',150)
sink.set_property('overlay-y',10)
sink.set_property('overlay-w',1280)
sink.set_property('overlay-h',720)
if not sink:
sys.stderr.write(" Unable to create egl sink \n")
if is_live:
print("Atleast one of the sources is live")
streammux.set_property('live-source', 1)
streammux.set_property('width', 1280)
streammux.set_property('height', 720)
streammux.set_property('batch-size', 8)
streammux.set_property('batched-push-timeout', 400000)
pgie.set_property('config-file-path', "./primaryInference/dstest3_pgie_config.txt")
pgie_batch_size=pgie.get_property("batch-size")
if(pgie_batch_size != 8):
print("WARNING: Overriding infer-config batch-size",pgie_batch_size," with number of sources ", 8," \n")
pgie.set_property("batch-size",8)
face_classifier.set_property('config-file-path', "dstest2_sgie1_config.txt")
face_classifier_batch_size=face_classifier.get_property("batch-size")
if(face_classifier_batch_size != 8):
print("WARNING: Overriding infer-config batch-size",face_classifier_batch_size," with number of sources ", 8," \n")
face_classifier.set_property("batch-size",8)
tiler_rows=int(math.sqrt(8))
tiler_columns=int(math.ceil((1.0*8)/tiler_rows))
tiler.set_property("rows",tiler_rows)
tiler.set_property("columns",tiler_columns)
tiler.set_property("width", TILED_OUTPUT_WIDTH)
tiler.set_property("height", TILED_OUTPUT_HEIGHT)
sink.set_property("qos",0)
#Set properties of tracker
config = configparser.ConfigParser()
config.read('dstest2_tracker_config.txt')
config.sections()
for key in config['tracker']:
if key == 'tracker-width' :
tracker_width = config.getint('tracker', key)
tracker.set_property('tracker-width', tracker_width)
if key == 'tracker-height' :
tracker_height = config.getint('tracker', key)
tracker.set_property('tracker-height', tracker_height)
if key == 'gpu-id' :
tracker_gpu_id = config.getint('tracker', key)
tracker.set_property('gpu_id', tracker_gpu_id)
if key == 'll-lib-file' :
tracker_ll_lib_file = config.get('tracker', key)
tracker.set_property('ll-lib-file', tracker_ll_lib_file)
if key == 'll-config-file' :
tracker_ll_config_file = config.get('tracker', key)
tracker.set_property('ll-config-file', tracker_ll_config_file)
if key == 'enable-batch-process' :
tracker_enable_batch_process = config.getint('tracker', key)
tracker.set_property('enable_batch_process', tracker_enable_batch_process)
if key == 'enable-past-frame' :
tracker_enable_past_frame = config.getint('tracker', key)
tracker.set_property('enable_past_frame', tracker_enable_past_frame)
print("Adding elements to Pipeline \n")
pipeline.add(pgie)
pipeline.add(tracker)
pipeline.add(nvvidconv1)
pipeline.add(filter1)
pipeline.add(tiler)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(sink)
print("Linking elements in the Pipeline \n")
streammux.link(queue1)
queue1.link(nvvidconv1)
nvvidconv1.link(queue2)
queue2.link(pgie)
pgie.link(queue3)
queue3.link(filter1)
filter1.link(queue4)
queue4.link(tracker)
tracker.link(queue5)
queue5.link(tiler)
tiler.link(queue6)
queue6.link(nvvidconv)
nvvidconv.link(queue7)
queue7.link(nvosd)
nvosd.link(queue8)
queue8.link(sink)
# create an event loop and feed gstreamer bus mesages to it
loop = GObject.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect ("message", bus_call, loop)
queue3srcpad = queue5.get_static_pad("src")
if not queue3srcpad:
sys.stderr.write(" Unable to get sink pad of nvvidconv \n")
else:
queue3srcpad.add_probe(Gst.PadProbeType.BUFFER, sgie_sink_pad_buffer_probe, 0)
In the primary network, I use the face coordinates obtained by centerface to directly intercept the face in the original image
def sgie_sink_pad_buffer_probe(pad,info,u_data):
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
except StopIteration:
break
l_obj=frame_meta.obj_meta_list
n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
while l_obj is not None:
try:
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
break
rect_params = obj_meta.rect_params
h, w, _ = n_frame.shape
top = max(int(rect_params.top) - 100, 0)
left = max(int(rect_params.left) - 100, 0)
right = min(int(rect_params.width + rect_params.left) + 100, w)
bottom = min(int(rect_params.height + rect_params.top) + 100, h)
face = n_frame[top: bottom, left: right]
face = np.array(face, copy=True, order='C')
face_copy = cv2.cvtColor(face, cv2.COLOR_RGBA2BGRA)
// ================== Save face image =====================
try:
l_obj=l_obj.next
break
try:
l_frame=l_frame.next
break
return Gst.PadProbeReturn.OK
