hey all
i want to stream video data from multiple orins onto a seperate screen and i want to know if the onboard wifi module supports point to point wifi connection with a host computer and if it supports the range aswell.
hey all
You may try UDP and assign IP address of client so that each stream can be sent to individual client. Please refer to the set up:
Gstreamer TCPserversink 2-3 seconds latency - #5 by DaneLLL
should i add a EDIMAX - Wireless Adapters - AC1750 - AC1750 Dual-Band Wi-Fi USB 3.0 Adapter with 180-degree Adjustable Antenna or is the onboard m.2 key E Wifi module powerful enough?
