Videoflip
Does the videoflip plugin actually crop the frame?
I have a camera with input stream of 1280*720, when I use videoflip with 90 deg rotation, I see only the central part of the scene, zoomed in, as like the flip actually cropped the central part, executed rotation and then resize the frame to match the output resolution…
Is that how this plugin works?
If so, what is the way to actually rotate a stream?
