Dear OpenCL users at the NVIDIA forums,
I am proud to announce the release of the Vienna Computing Library (ViennaCL), a scientific computing library written in C++ and based on OpenCL. It allows simple, high-level access to the vast computing resources available on parallel architectures such as GPUs and is primarily focused on common linear algebra operations (BLAS level 1 and 2) and the solution of large systems of equations by means of iterative methods. At present, the following iterative solvers are implemented:
* Conjugate Gradient (CG)
* Stabilized BiConjugate Gradient (BiCGStab)
* Generalized Minimum Residual (GMRES)
An optional ILU preconditioner can be used, which is so far precomputed on the CPU and may thus not lead to overall performance gains.
The library interface is similar to that of the ublas library, which is shipped with Boost. The iterative solvers can be used either on the CPU with ublas types or on the GPU using ViennaCL types. Consequently, there are only a few code changes in existing simulators necessary to get the iterative solvers running on the GPU. For further information, please visit [url=“http://viennacl.sourceforge.net/”]http://viennacl.sourceforge.net/[/url]. If you have any questions, feel free to ask them here :-)
Best regards,
Karli
