how do I fix this?
安装 View 时出错:[1b975f3d-7359-42a7-b75e-90fc4e2ca0a9] Cannot sign URL for download – FetchError: request to https://api.launcher.omniverse.nvidia.com/app/url?path=https%3A%2F%2Flauncher-prod.s3.us-east-2.amazonaws.com%2Fview%2F2022.1.2%2Fwindows-x86_64%2Fpackage.zip failed, reason: connect ETIMEDOUT 99.86.199.8:443
Is this still failing for you with View 2022.1.2?
Have you checked that you have enough disk space available for installation? You need 3-4Gb.
Brian
I got over 750gb left. here is the latest note, please tell me where went wrong so I can fix. (Plus it’s SUPER HARD to download anything from the exchange in daytime in China, I can’t tell how many times I can’t even download the package or even sign in at Omniverse. Even when I download it past midnight time in China , the downloading rate is merely 500kb/sec. Please do something to improve the download experience! )
安装 View 时出错:Command failed: “E:\Program Files\Omiverse路径\view-2022.1.2\omni.view.warmup.bat”
2022-07-06 21:13:01 [4,398ms] [Error] [rtx.neuraylib.plugin] [DYNLIB:MAIN] 0.1 DYNLIB main error: Failed to load library
2022-07-06 21:13:01 [4,398ms] [Error] [rtx.neuraylib.plugin] [INDEX:MAIN] 0.1 INDEX main error: Failed to load e:/program files/omiverse路径/view-2022.1.2/kit/libs/iray/libnvindex.dll
2022-07-06 21:13:01 [4,578ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/e:/program%20files/omiverse%E8%B7%AF%E5%BE%84/view-2022.1.2/kit/mdl/rtx/iray/omni_light.mdl(1,1): C100 “mdl” expected
2022-07-06 21:13:01 [4,578ms] [Error] [carb.scenerenderer-iray.plugin] Import Error (4003): The module “::omni_light” was not found or failed to compile.
2022-07-06 21:13:01 [4,579ms] [Error] [carb.scenerenderer-iray.plugin] Import Error (4006): file:/e:/program%20files/omiverse%E8%B7%AF%E5%BE%84/view-2022.1.2/kit/mdl/rtx/iray/omni_light.mdl(1,1): C100 “mdl” expected
2022-07-06 21:13:01 [4,579ms] [Error] [carb.scenerenderer-iray.plugin] Failed to import module ‘omni_light.mdl’.
2022-07-06 21:13:01 [4,579ms] [Error] [carb.scenerenderer-iray.plugin] Failed to import default modules.
2022-07-06 21:13:01 [5,097ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/e:/program%20files/omiverse%E8%B7%AF%E5%BE%84/view-2022.1.2/kit/mdl/rtx/Default.mdl(1,1): C100 “mdl” expected
2022-07-06 21:13:01 [5,097ms] [Error] [rtx.neuraylib.plugin] Compiler Core: file:/e:/program%20files/omiverse%E8%B7%AF%E5%BE%84/view-2022.1.2/kit/mdl/rtx/Default.mdl(1,1): C100 “mdl” expected
2022-07-06 21:13:01 [5,098ms] [Error] [rtx.neuraylib.plugin] Failed to resolve overloads. The MdlModule ‘mdl::ZD8Default_2Emdl’ is not loaded.
2022-07-06 21:13:02 [5,745ms] [Error] [carb.crashreporter-breakpad.plugin] crash detected
2022-07-06 21:13:27 [30,987ms] [Error] [carb.crashreporter-breakpad.plugin] dump file size is -1 bytes, file is not readable.
2022-07-06 21:13:28 [32,004ms] [Fatal] [carb.crashreporter-breakpad.plugin] Crash detected in pid 43692 thread 42612
2022-07-06 21:13:28 [32,005ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 42612 backtrace follows:
2022-07-06 21:13:28 [32,006ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: carb.scenerenderer-rtx.plugin.dll!+0x73c11
2022-07-06 21:13:28 [32,006ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: carb.scenerenderer-rtx.plugin.dll!+0x74929
2022-07-06 21:13:28 [32,006ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: carb.scenerenderer-rtx.plugin.dll!+0x6b7ee
2022-07-06 21:13:28 [32,006ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: carb.scenerenderer-rtx.plugin.dll!carbOnPluginShutdown+0x1a2b1
2022-07-06 21:13:28 [32,007ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: omni.hydra.rtx.plugin.dll!+0x2fb7
2022-07-06 21:13:28 [32,007ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: omni.usd.dll!omni::usd::UsdManager::advanceAllSyncScopes+0x5ff
2022-07-06 21:13:28 [32,007ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: omni.usd.dll!omni::usd::UsdManager::attachAllHydraEngines+0x23
2022-07-06 21:13:28 [32,009ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: omni.ext-viewport_window.plugin.dll!+0x82972
2022-07-06 21:13:28 [32,009ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: omni.ext.plugin.dll!carbOnPluginShutdown+0x24404
2022-07-06 21:13:28 [32,009ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: omni.ext.plugin.dll!carbOnPluginShutdown+0x20b14
2022-07-06 21:13:28 [32,009ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: omni.ext.plugin.dll!carbOnPluginShutdown+0x14fac
2022-07-06 21:13:28 [32,009ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: omni.ext.plugin.dll!carbOnPluginShutdown+0x3ba8d
2022-07-06 21:13:28 [32,009ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: omni.ext.plugin.dll!carbOnPluginShutdown+0x398eb
2022-07-06 21:13:28 [32,009ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: omni.ext.plugin.dll!carbOnPluginShutdown+0x41765
2022-07-06 21:13:28 [32,010ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: omni.kit.app.plugin.dll!+0x13911
2022-07-06 21:13:28 [32,010ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: omni.kit.app.plugin.dll!+0xeaba
2022-07-06 21:13:28 [32,010ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: omni.kit.app.plugin.dll!+0x47287
2022-07-06 21:13:28 [32,011ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: kit.exe!+0x371e
2022-07-06 21:13:28 [32,011ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: kit.exe!+0x431e
2022-07-06 21:13:28 [32,011ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: kit.exe!+0x28804
2022-07-06 21:13:28 [32,011ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: KERNEL32.DLL!BaseThreadInitThunk+0x14
2022-07-06 21:13:28 [32,011ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: ntdll.dll!RtlUserThreadStart+0x21
I tried another time , and this time is:
2022-07-06 22:29:39 [3,810ms] [Error] [rtx.neuraylib.plugin] [DYNLIB:MAIN] 0.1 DYNLIB main error: Failed to load library
2022-07-06 22:29:39 [3,810ms] [Error] [rtx.neuraylib.plugin] [INDEX:MAIN] 0.1 INDEX main error: Failed to load e:/program files/omiverse路径/view-2022.1.2/kit/libs/iray/libnvindex.dll
2022-07-06 22:29:40 [4,001ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/e:/program%20files/omiverse%E8%B7%AF%E5%BE%84/view-2022.1.2/kit/mdl/rtx/iray/omni_light.mdl(1,1): C100 “mdl” expected
2022-07-06 22:29:40 [4,001ms] [Error] [carb.scenerenderer-iray.plugin] Import Error (4003): The module “::omni_light” was not found or failed to compile.
2022-07-06 22:29:40 [4,001ms] [Error] [carb.scenerenderer-iray.plugin] Import Error (4006): file:/e:/program%20files/omiverse%E8%B7%AF%E5%BE%84/view-2022.1.2/kit/mdl/rtx/iray/omni_light.mdl(1,1): C100 “mdl” expected
2022-07-06 22:29:40 [4,001ms] [Error] [carb.scenerenderer-iray.plugin] Failed to import module ‘omni_light.mdl’.
2022-07-06 22:29:40 [4,001ms] [Error] [carb.scenerenderer-iray.plugin] Failed to import default modules.
2022-07-06 22:29:40 [4,548ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/e:/program%20files/omiverse%E8%B7%AF%E5%BE%84/view-2022.1.2/kit/mdl/rtx/Default.mdl(1,1): C100 “mdl” expected
2022-07-06 22:29:40 [4,548ms] [Error] [rtx.neuraylib.plugin] Compiler Core: file:/e:/program%20files/omiverse%E8%B7%AF%E5%BE%84/view-2022.1.2/kit/mdl/rtx/Default.mdl(1,1): C100 “mdl” expected
2022-07-06 22:29:40 [4,548ms] [Error] [rtx.neuraylib.plugin] Failed to resolve overloads. The MdlModule ‘mdl::ZD8Default_2Emdl’ is not loaded.
2022-07-06 22:29:41 [5,222ms] [Error] [carb.crashreporter-breakpad.plugin] crash detected
2022-07-06 22:30:12 [36,162ms] [Error] [carb.crashreporter-breakpad.plugin] dump file size is -1 bytes, file is not readable.
2022-07-06 22:30:12 [36,433ms] [Fatal] [carb.crashreporter-breakpad.plugin] Crash detected in pid 13832 thread 28368
2022-07-06 22:30:12 [36,434ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 28368 backtrace follows:
2022-07-06 22:30:12 [36,435ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: carb.scenerenderer-rtx.plugin.dll!+0x73c11
2022-07-06 22:30:12 [36,435ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: carb.scenerenderer-rtx.plugin.dll!+0x74929
2022-07-06 22:30:12 [36,435ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: carb.scenerenderer-rtx.plugin.dll!+0x6b7ee
2022-07-06 22:30:12 [36,435ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: carb.scenerenderer-rtx.plugin.dll!carbOnPluginShutdown+0x1a2b1
2022-07-06 22:30:12 [36,436ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: omni.hydra.rtx.plugin.dll!+0x2fb7
2022-07-06 22:30:12 [36,436ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: omni.usd.dll!omni::usd::UsdManager::advanceAllSyncScopes+0x5ff
2022-07-06 22:30:12 [36,436ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: omni.usd.dll!omni::usd::UsdManager::attachAllHydraEngines+0x23
2022-07-06 22:30:12 [36,437ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: omni.ext-viewport_window.plugin.dll!+0x82972
2022-07-06 22:30:12 [36,437ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: omni.ext.plugin.dll!carbOnPluginShutdown+0x24404
2022-07-06 22:30:12 [36,437ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: omni.ext.plugin.dll!carbOnPluginShutdown+0x20b14
2022-07-06 22:30:12 [36,437ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: omni.ext.plugin.dll!carbOnPluginShutdown+0x14fac
2022-07-06 22:30:12 [36,437ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: omni.ext.plugin.dll!carbOnPluginShutdown+0x3ba8d
2022-07-06 22:30:12 [36,437ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: omni.ext.plugin.dll!carbOnPluginShutdown+0x398eb
2022-07-06 22:30:12 [36,437ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: omni.ext.plugin.dll!carbOnPluginShutdown+0x41765
2022-07-06 22:30:12 [36,438ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: omni.kit.app.plugin.dll!+0x13911
2022-07-06 22:30:12 [36,438ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: omni.kit.app.plugin.dll!+0xeaba
2022-07-06 22:30:12 [36,438ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: omni.kit.app.plugin.dll!+0x47287
2022-07-06 22:30:12 [36,439ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: kit.exe!+0x371e
2022-07-06 22:30:12 [36,439ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: kit.exe!+0x431e
2022-07-06 22:30:12 [36,439ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: kit.exe!+0x28804
2022-07-06 22:30:12 [36,439ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: KERNEL32.DLL!BaseThreadInitThunk+0x14
2022-07-06 22:30:12 [36,439ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: ntdll.dll!RtlUserThreadStart+0x21
