Hi there,
I’m using the NVENC library in a simple custom app, and it works very well. I can easily generate an h264 stream, and use a socket to send it anywhere I want. I’ve verified that it’s valid, and I can save the stream and covert it to another format.
Here’s the problem: What my client really wants (which I assume is the most common use for NVENC) is to be able to view the output live. Open a browser (or even a custom app) and watch the video as it’s generated. I’ve searched, and so far not found any way to do this, short of developing a brand new special-case video-streaming client.
What do other people use to view the output of the NVENC lib? (I’m encoding using the CNvEncoderH264 sample, which is spiffy and easy.)
Thanks very much.
