import omni.ui as ui
def _on_accept_drop(url):
# only accept .png files
if ".png" in url:
return True
else:
return False
def _on_value(field):
field.model.get_value_as_string()
def _on_drag(image_path):
ui.Image(image_path, height=50, width=50)
return image_path
window = ui.Window(title="Drag and Drop", width= 500, height=500)
with window.frame:
with ui.VStack():
image_path = "/img/path/im.png"
image = ui.Image(image_path, height=100, width=100, drag_fn=lambda: _on_drag(image_path))
path_widget = path_widget = ui.StringField(height=30)
path_widget.model.add_value_changed_fn(lambda _: _on_value(path_widget))
drop_area = ui.Workspace.get_window("Viewport").frame
drop_area.set_accept_drop_fn(lambda url: _on_accept_drop(url))
def _on_drop(e: ui.WidgetMouseDropEvent):
path = e.mime_data
path_widget.model.set_value(path)
drop_area.set_drop_fn(_on_drop) # internal drop
external_drag_drop = None
def _on_ext_drag_drop(e, payload, drop_area, path_widget, ):
path = payload[0]
def setup_external_drag_drop(window_name :str, drop_area, path_widget):
global external_drag_drop
if external_drag_drop:
external_drag_drop.destroy()
try:
from omni.kit.window.drop_support import ExternalDragDrop
external_drag_drop = ExternalDragDrop(window_name=window_name,
drag_drop_fn=lambda e, p, drop_area=drop_area, path_widget=path_widget: _on_ext_drag_drop(e, p, drop_area, path_widget))
except ImportError:
pass
# if the image lives outside of the omniverse app, e.g filr explorer
setup_external_drag_drop("Viewport", drop_area, path_widget) # external drop
