ViewportWidget Multiple Textures Error
I have a simple kit app that creates a ViewportWidget from omni.kit.widget.viewport, but when I click Ctrl+S in VSCode to restart my kit app, it crashes with this error:
[Error] [omni.kit.widget.viewport.impl.texture] Multiple textures for pxr engine is not currently supported
After debugging, I realized this comes from function __set_hd_engine at texture.py file, where those two variables are different:
  • pxr_in_use = ‘/plugins/omni.hydratexture.plugin/omni_kit_widget_viewport_ViewportTexture_0/’
  • pxr_in_use_value =‘/plugins/omni.hydratexture.plugin/omni_kit_widget_viewport_ViewportTexture_1/’
I’ve seen that there is an incremental global variable (ViewportTexture.__g_hd_texture_counter) that makes those names different, how can I overcome this issue?
My kit app is so simple I don’t believe I need to upload code.
PD: I only activated and enabled pxr render engine settings in kit file.
Solved with this code.
    def on_shutdown(self):
        self._viewport_widget.destroy()
