Virtnet does not work correctly
I try to run virtnet hotplug to make virtio for guest OS, made by VM. But it failed to make it.
$ sudo virtnet hotplug -i mlx5_0 -f 0x0 -m 0C:C4:7A:FF:22:93 -t 1500 -n 3 -s 1024
{'ib_device': 'mlx5_0', 'mac': '0C:C4:7A:FF:22:93', 'mtu': '0x5dc', 'num_queues': '0x3', 'max_queue_size': '0x400', 'features': '0x0', 'legacy': '0x0'}
  "errno": -1071,
  "errstr": "Failed to hotplug/unplug device, host is not ready"
Since firmware configuration setting is already set, it can’t make it.
$ sudo mlxconfig -d 03:00.0 -e q | grep -i \*
*       NVME_EMULATION_NUM_PF                       1                    0                    2
*       PCI_SWITCH_EMULATION_ENABLE                 False(0)             True(1)              True(1)
*       VIRTIO_BLK_EMULATION_NUM_MSIX               2                    0                    2
*       VIRTIO_FS_EMULATION_NUM_MSIX                2                    0                    2
*       VIRTIO_NET_EMULATION_ENABLE                 False(0)             True(1)              True(1)
*       VIRTIO_NET_EMULATION_NUM_MSIX               2                    0                    10
*       PER_PF_NUM_SF                               False(0)             True(1)              True(1)
*       PF_BAR2_ENABLE                              True(1)              False(0)             False(0)
*       SRIOV_EN                                    True(1)              False(0)             False(0)
*       NUM_VF_MSIX                                 11                   0                    11
*       PF_TOTAL_SF                                 0                    64                   64
*       PF_SF_BAR_SIZE                              0                    10                   10
The '*' shows parameters with next value different from default/current value.
I wonder which parameter should be set at host side.
Currently, I set boot configuration as below.
intel_iommu=on iommu=pt intremap=no_x2apic_optout intel_pstate=disable default_hugepagesz=1g hugepagesz=1g hugepages=64 irqpoll pci=realloc
Hi polaris6921,
Thank you for posting your query on NVIDIA Community.
I would like to request validating the configuration from our User Manual for latest DOCA 3.0 on →
If you experience issues after verifying the configuration is place, a valid support Entitlement for the HCA in use will be needed to perform additional troubleshooting.
If there an active entitlement/support contract in place, please do not hesitate to open a support ticket by emailing enterprisesupport@nvidia.com
For contracts, please reach out to Networking-Contracts@nvidia.com
Thanks,
Namrata.
