Hello
I tried the same command to log also when correctly acquiring with camera 0
-- Logs begin at Wed 2024-11-06 14:42:10 CET. --
Nov 06 14:42:13 ubuntu systemd[1]: Started Argus daemon.
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: === NVIDIA Libargus Camera Service (0.98.3)=== Listening for connections...=== video-viewer[8176]: Connection established (7F7F4711D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvPclHwGetModuleList: No module data found
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: ---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 18: Error: Invalid isp config attribute: "sensor.companding.enable=FALSE"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 19: Error: Invalid isp config attribute: "sensor.companding.LUT={2048,2048,65536,3040,1048576,4000,1048576,4096}"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 20: Error: Invalid isp config attribute: "scene.brightnessKey={0.01,0.02,0.05,0.1,0.2,0.5,1}"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 21: Error: Invalid isp config attribute: "scene.toneTable.axisX={10,100,1000,10000}"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 22: Error: Invalid isp config attribute: "scene.toneTable.axisY={30,60,90,120}"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 23: Error: Invalid isp config attribute: "saturation.strength={0.0,0,0,0,0,0,0}"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 24: Error: Invalid isp config attribute: "noiseReduction.strength={0.5,0.5,0.5,0.5,0.5,0.5,0.5}"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 25: Error: Invalid isp config attribute: "sharpness.strength={0.5,0.5,0.5,0.5,0.5,0.5,0.5}"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 26: Error: Invalid isp config attribute: "gtm.enable=FALSE"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 27: Error: Invalid isp config attribute: "gtm.preset[0]={0,0,0.25,0.25,0.5,0.5,0.75,0.75,1,1}"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 28: Error: Invalid isp config attribute: "dae.mode=0"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 29: Error: Invalid isp config attribute: "dae.enableGammaPQ=FALSE"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 30: Error: Invalid isp config attribute: "dae.EVCompensation=0.0"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 31: Error: Invalid isp config attribute: "dae.highlightControl=0.5"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 32: Error: Invalid isp config attribute: "dae.shadowControl=0.5"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 33: Error: Invalid isp config attribute: "ltm.enable=FALSE"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 34: Error: Invalid isp config attribute: "ltm.enableLf=FALSE"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 38: Error: Invalid isp config attribute: "ltm.strength={0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5}"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 39: Error: Invalid isp config attribute element: "awb.nightmode.enable=FALSE"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 40: Error: Invalid isp config attribute element: "awb.nightmode.gains={2.5,1,1,3.2}"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 41: Error: Invalid isp config attribute: "em.initialState=0"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 42: Error: Invalid isp config attribute: "em.thresholdLow=2080"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 43: Error: Invalid isp config attribute: "em.thresholdHigh=3232"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 47: Error: Invalid isp config attribute: "em.preset[0].wbgains={1.5,1.0,1.0,1.5}"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 51: Error: Invalid isp config attribute: "em.preset[1].wbgains={1.5,1.0,1.0,1.5}"
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: CAM: serial no file already exists, skips storing again---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: (NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: (NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 107)
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvPclStartPlatformDrivers: Failed to start module drivers
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvPclStateControllerOpen: Failed ImagerGUID 2. (error 0xA000E)
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: NvPclOpen: PCL Open Failed. Error: 0xf
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 593)
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 437)
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 305)
Nov 06 14:45:24 ubuntu nvargus-daemon[4648]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 471)
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: Acquiring SCF Camera device source via index 3 has failed. === video-viewer[8176]: CameraProvider initialized (0x7f788a3810)NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 18: Error: Invalid isp config attribute: "sensor.companding.enable=FALSE"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 19: Error: Invalid isp config attribute: "sensor.companding.LUT={2048,2048,65536,3040,1048576,4000,1048576,4096}"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 20: Error: Invalid isp config attribute: "scene.brightnessKey={0.01,0.02,0.05,0.1,0.2,0.5,1}"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 21: Error: Invalid isp config attribute: "scene.toneTable.axisX={10,100,1000,10000}"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 22: Error: Invalid isp config attribute: "scene.toneTable.axisY={30,60,90,120}"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 23: Error: Invalid isp config attribute: "saturation.strength={0.0,0,0,0,0,0,0}"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 24: Error: Invalid isp config attribute: "noiseReduction.strength={0.5,0.5,0.5,0.5,0.5,0.5,0.5}"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 25: Error: Invalid isp config attribute: "sharpness.strength={0.5,0.5,0.5,0.5,0.5,0.5,0.5}"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 26: Error: Invalid isp config attribute: "gtm.enable=FALSE"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 27: Error: Invalid isp config attribute: "gtm.preset[0]={0,0,0.25,0.25,0.5,0.5,0.75,0.75,1,1}"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 28: Error: Invalid isp config attribute: "dae.mode=0"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 29: Error: Invalid isp config attribute: "dae.enableGammaPQ=FALSE"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 30: Error: Invalid isp config attribute: "dae.EVCompensation=0.0"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 31: Error: Invalid isp config attribute: "dae.highlightControl=0.5"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 32: Error: Invalid isp config attribute: "dae.shadowControl=0.5"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 33: Error: Invalid isp config attribute: "ltm.enable=FALSE"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 34: Error: Invalid isp config attribute: "ltm.enableLf=FALSE"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 38: Error: Invalid isp config attribute: "ltm.strength={0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5}"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 39: Error: Invalid isp config attribute element: "awb.nightmode.enable=FALSE"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 40: Error: Invalid isp config attribute element: "awb.nightmode.gains={2.5,1,1,3.2}"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 41: Error: Invalid isp config attribute: "em.initialState=0"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 42: Error: Invalid isp config attribute: "em.thresholdLow=2080"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 43: Error: Invalid isp config attribute: "em.thresholdHigh=3232"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 47: Error: Invalid isp config attribute: "em.preset[0].wbgains={1.5,1.0,1.0,1.5}"
Nov 06 14:45:25 ubuntu nvargus-daemon[4648]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 51: Error: Invalid isp config attribute: "em.preset[1].wbgains={1.5,1.0,1.0,1.5}"
