What is the significance of “Virtual display head = 1” for the virtual apps license? I will be publishing Revit in XenApp using the 4a profile. Does this mean the user can only display Revit on 1 monitor…that it is vGPU accelerated on 1 monitor only?
for sure not. As XenApp doesn’t use NVFBC it depends on XenApp what your max resolution is. Therefore Dual monitor with Full HD should work perfecty for example.
Regards
Simon
