Vision Components MIPI CSI-2 driver for NVIDIA Jetson Orin NX (Sony imx415-c)
My team and I working on the NVIDIA Jetson Orin NX 16GB with two Sony IMX 415-C sensors. We encountered some difficulties during the integration process. When we run the dmesg command, we get the following error messages:
imx219_board_setup: invalid sensor model id: 6d69
imx219_board_setup: error during i2c read probe (-121) board setup failed.
Has anyone solved this problem yet ?
We found the GitHub repository for the driver but unfortunately our card is not supported. There’s a branch called “9-support-for-jetson-orin-nano” that might be able to solve the problem, but it’s not yet merged into the master.
hello ttvexcv,
it’s error reported by sensor driver side, board setup is the very beginning function to register camera device to linux kernel.
please see-also Sensor Software Driver Programming to review the driver implementation.
Thank for your reply.
I used sdkmanager to get the correct board support package for Orin NX.
However I can’t find <top>/hardware/nvidia/platform/ as mentionned in the documentation.
ls nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra
apply_binaries.sh                        jetson-agx-orin-devkit-industrial.conf  l4t_generate_soc_bup.sh           p2972-0000-devkit-maxn.conf               p3737-0000+p3701-0000-as-p3767-0003.conf
bootloader                               jetson-agx-orin-devkit-maxn.conf        l4t_sign_image.sh                 p2972-0000-devkit-slvs-ec.conf            p3737-0000+p3701-0000-as-p3767-0004.conf
build_l4t_bup.sh                         jetson-agx-xavier-devkit.conf           nvautoflash.sh                    p2972.conf                                p3737-0000+p3701-0000.conf
clara-agx-xavier-devkit.conf             jetson-agx-xavier-ind-noecc.conf        nvmassfusegen.sh                  p3449-0000+p3668-0000-qspi-sd.conf        p3737-0000+p3701-0000-maxn.conf
e3900-0000+p2888-0004-b00.conf           jetson-agx-xavier-industrial.conf       nvsdkmanager_flash.sh             p3449-0000+p3668-0001-qspi-emmc.conf      p3740-0002-b00+p3701-0002.conf
flash.sh                                 jetson-agx-xavier-industrial-mxn.conf   nv_tegra                          p3509-0000+p3668-0000-qspi.conf           p3740-0002-b01+p3701-0002.conf
generate_capsule                         jetson_board_spec.cfg                   nv_tools                          p3509-0000+p3668-0000-qspi-sd.conf        p3740-0002-c01+p3701-0008.conf
holoscan-devkit.conf                     jetson-orin-nano-devkit.conf            odmfuse.func                      p3509-0000+p3668-0001-qspi-emmc.conf      p3767.conf.common
igx-orin-devkit.conf                     jetson-orin-nano-devkit-nvme.conf       odmfuseread.sh                    p3509-a02+p3767-0000.conf                 p3768-0000+p3767-0000.conf
jetson_additional_board_spec.cfg         jetson-xavier.conf                      odmfuse.sh                        p3509-a02+p3767-0000-maxn.conf            p3768-0000+p3767-0000-maxn.conf
jetson-agx-orin-devkit-as-jao-32gb.conf  jetson-xavier-maxn.conf                 p2822-0000+p2888-0001.conf        p3668.conf.common                         p3768-0000+p3767-0000-nvme.conf
jetson-agx-orin-devkit-as-nano4gb.conf   jetson-xavier-nx-devkit.conf            p2822-0000+p2888-0004.conf        p3701.conf.common                         README_Autoflash.txt
jetson-agx-orin-devkit-as-nano8gb.conf   jetson-xavier-nx-devkit-emmc.conf       p2822-0000+p2888-0008.conf        p3711-0000+p3701-0002.conf                rootfs
jetson-agx-orin-devkit-as-nx-16gb.conf   jetson-xavier-nx-devkit-qspi.conf       p2822-0000+p2888-0008-maxn.conf   p3737-0000+p3701-0000-as-p3701-0004.conf  source
jetson-agx-orin-devkit-as-nx-8gb.conf    jetson-xavier-slvs-ec.conf              p2822-0000+p2888-0008-noecc.conf  p3737-0000+p3701-0000-as-p3767-0000.conf  source_sync.sh
jetson-agx-orin-devkit.conf              kernel                                  p2972-0000.conf.common            p3737-0000+p3701-0000-as-p3767-0001.conf  tools
Have I forgotten or misunderstood something?
Additional question : How to include my custom .dtsi to main .dts and rebuild the new image ?
hello ttvexcv,
please visit Jetson Linux 35.3.1 | NVIDIA Developer to download [Driver Package (BSP) Sources]. you’ll need to extract kernel_src.tbz2 package to obtain the device tree sources.
please see-also developer guide, Kernel Customization for the steps to build the kernel.
I have carried out the following steps, in accordance with the documentation:
  • Create my file tegra234-camera-imx415-dual.dtsi in the directory hardware/nvidia/platform/t23x/common/kernel-dts/t234-common-modules/
      panthera3@workstation:bsp_sources/kernel_src$ ls hardware/nvidia/platform/t23x/common/kernel-dts/t234-common-modules/
      tegra234-camera-ar0234-a00.dtsi  tegra234-camera-imx185-a00.dtsi   tegra234-camera-imx415-dual.dtsi  tegra234-cvb-e2425-1099.dtsi  tegra234-p3711-p3713-pcie.dtsi
      tegra234-camera-e3331-a00.dtsi   tegra234-camera-imx274-dual.dtsi  tegra234-camera-p3762-a00.dtsi    tegra234-cvm-e2421-1098.dtsi  tegra234-super-module-e2614.dtsi
      tegra234-camera-e3333-a00.dtsi   tegra234-camera-imx390-a00.dtsi   tegra234-camera-p3783-a00.dtsi    tegra234-cvm-e2421-1099.dtsi
  • Create my file imx415.c in the directory ./kernel/nvidia/drivers/media/i2c/imx415
    panthera3@workstation: bsp_sources/kernel_src/kernel/nvidia/drivers/media/i2c$ ls | grep imx
    imx185_mode_tbls.h
    imx185_v1_mode_tbls.h
    imx214.c
    imx219_mode_tbls.h
    imx268_mode_tbls.h
    imx274_mode_tbls.h
    imx318_mode_tbls.h
    imx390_mode_tbls.h
    imx415.c
    imx477_mode_tbls.h
    nv_imx185.c
    nv_imx185_v1.c
    nv_imx219.c
    nv_imx268.c
    nv_imx274.c
    nv_imx318.c
    nv_imx390.c
    nv_imx477.c
  • Add the line obj-$(CONFIG_VIDEO_IMX415) += imx415.o to the file ./kernel/nvidia/drivers/media/i2c/Makefile
    panthera3@workstation:bsp_sources/kernel_src/kernel/nvidia/drivers/media/i2c$ grep -ir CONFIG_VIDEO_IMX415
    Makefile:obj-$(CONFIG_VIDEO_IMX415) += imx415.o
  • Add CONFIF_VIDEO_IMX415=m line to ./kernel/kernel-5.10/arch/arm64/configs/tegra-defconfig file
    panthera3@workstation:bsp_sources/kernel_src/kernel/kernel-5.10/arch/arm64/configs$ grep -ir CONFIG_VIDEO_IMX415
    defconfig:CONFIG_VIDEO_IMX415=m
  • Build kernel in kernel_output directory
    panthera3@workstation:bsp_sources/kernel_src$ mkdir kernel_out
    panthera3@workstation:bsp_sources/kernel_src$ ./nvbuild.sh -o ~/Workspace/Orin/nvidia/bsp_sources/kernel_src/kernel_out
      LD [M]  sound/soc/tegra/snd-soc-tegra210-mixer.ko
      LD [M]  sound/soc/tegra/snd-soc-tegra210-mvc.ko
      LD [M]  sound/soc/tegra/snd-soc-tegra210-ope.ko
      LD [M]  sound/soc/tegra/snd-soc-tegra210-sfc.ko
      LD [M]  sound/tegra-safety-audio/safety-i2s.ko
    Kernel sources compiled successfully.
After compilation, I can’t find the imx415.ko file in the outuput.
According to the documentation, the imx415.ko file should be located in <OUT>/nvidia/kernel/drivers/media/i2c/<camera>.ko
Here are the directory contents after the build :
panthera3@workstation:bsp_sources/kernel_src/kernel_out$ ls
arch   certs   drivers  include  ipc     kernel-int-overlays.txt  lib       mm               modules.builtin.modinfo  modules.order   net      scripts   sound   System.map  virt     vmlinux.o
block  crypto  fs       init     kernel  kernel-overlays.txt      Makefile  modules.builtin  modules-only.symvers     Module.symvers  nvsched  security  source  usr         vmlinux  vmlinux.symvers
panthera3@workstation:bsp_sources/kernel_src/kernel/kernel-5.10$ ls
android-patches  block  COPYING  crypto         drivers  hardware  init  Kbuild   kernel                   kernel-overlays.txt  LICENSES     Makefile  net     rt-patches  scripts   sound  usr   WD
arch             certs  CREDITS  Documentation  fs       include   ipc   Kconfig  kernel-int-overlays.txt  lib
How do I recover the imx415.ko file after the build?
please dig into these building messages, did you see IMX415 files has included?
# dig into output files
hardware  kernel  kernel_out  l4t-gcc  nvbuild.sh  nvcommon_build.sh
panthera3@workstationbsp_sources/kernel_src$ find . -type f -name *imx415*
./hardware/nvidia/platform/t23x/common/kernel-dts/t234-common-modules/tegra234-camera-imx415-dual.dtsi
./kernel/nvidia/drivers/media/i2c/imx415.c
# dig into output logs
panthera3@workstation:bsp_sources/kernel_src$ ./nvbuild.sh -o ~/Workspace/Orin/nvidia/bsp_sources/kernel_src/kernel_out > building.log
panthera3@workstation:bsp_sources/kernel_src$ cat building.log | grep 415 | wc -l
0
I can’t find any trace of an imx415 file.
hello ttvexcv,
it might be something wrong with your kernel config.
could you please revise the Makefile,
for example, Makefile:obj-y += imx415.o to force compiler include imx415 sources to built the code.
Hi JerryChang, thanks for your quick reply.
I’ll give it a try now.
I have updated ./kernel/nvidia/drivers/media/i2c/Makefile as follows
subdir-ccflags-y += -Werror
ccflags-y += -I$(srctree)/drivers/media/platform/tegra
ccflags-y += -I$(srctree)/drivers/video/tegra/camera
obj-$(CONFIG_NV_VIDEO_IMX185) += nv_imx185.o
obj-$(CONFIG_NV_VIDEO_IMX185) += nv_imx185_v1.o
obj-$(CONFIG_NV_VIDEO_IMX477) += nv_imx477.o
obj-$(CONFIG_NV_VIDEO_IMX219) += nv_imx219.o
obj-$(CONFIG_NV_VIDEO_IMX268) += nv_imx268.o
obj-$(CONFIG_NV_VIDEO_IMX274) += nv_imx274.o
obj-$(CONFIG_NV_VIDEO_IMX318) += nv_imx318.o
obj-y += imx415.o
obj-$(CONFIG_NV_VIDEO_LC898212) += nv_lc898212.o
obj-$(CONFIG_NV_VIDEO_OV5693) += nv_ov5693.o
obj-$(CONFIG_NV_VIDEO_OV9281) += nv_ov9281.o
obj-$(CONFIG_NV_VIDEO_OV10823) += nv_ov10823.o
obj-$(CONFIG_NV_VIDEO_OV23850) += nv_ov23850.o
obj-$(CONFIG_I2C_IOEXPANDER_PCA9570) += pca9570.o
obj-$(CONFIG_VIDEO_TC358840) += tc358840.o
obj-$(CONFIG_VIDEO_LT6911UXC) +=lt6911uxc.o
obj-$(CONFIG_I2C_IOEXPANDER_SER_MAX9295) += max9295.o
obj-$(CONFIG_I2C_IOEXPANDER_DESER_MAX9296) += max9296.o
obj-$(CONFIG_NV_VIDEO_IMX390) += nv_imx390.o
obj-$(CONFIG_NV_VIDEO_AR0234) += nv_ar0234.o
obj-$(CONFIG_NV_VIDEO_HAWK_OWL) += nv_hawk_owl.o
obj-$(CONFIG_NV_DESER_MAX96712) += max96712.o
obj-$(CONFIG_VIDEO_ECAM) += ar1335.o
ar1335-objs :=  ar1335_common.o
Does NVIDIA supply the nv_imx415.c driver for imx415 sensor as for the 185, 129, 268, 274, 318, 390 and 477 ?
hello ttvexcv,
no, IMX415 is not supported by default.
all default supported camera drivers were located at… $public_sources/kernel_src/kernel/nvidia/drivers/media/i2c/*
you may check Jetson Linux 35.3.1 | NVIDIA Developer to download [Driver Package (BSP) Sources] for confirmation.
