I’m writing a ROS nodelet (shared library) which needs to use libovx\libnvx static libraries.
At linking stage I get:
libovx.a(UtilityOVX.o): relocation R_X86_64_32 against `.rodata.str1.1’ can not be used when making a shared object; recompile with -fPIC
Is the only way to get rid of the problem is to recompile Visionworks 1.6 Samples with -fPIC?
