I’m trying to run the demos and samples that come with visionworks.
This is the CUDA error that is printed when I run any of the Visionworks examples:
Error: CUDA Error in cudaGraphicsGLRegisterBuffer(&resStyles_, vboStyles_,
cudaGraphicsMapFlagsWriteDiscard)src/Render/CUDA-OpenGL/OpenGLBasicRenders.cpp
file 1106 line : invalid device ordinal
Here’s the configuration:
VisionWorks library info:
VisionWorks version : 1.5.3
OpenVX Standard version : 1.1.0
$ nvidia-debugdump -l
Found 3 NVIDIA devices
Device ID: 0
Device name: Quadro K4200 (*PrimaryCard)
GPU internal ID: GPU-155a3bdd-93f4-e81a-246d-838d03c95e66
Device ID: 1
GPU internal ID: GPU-a1c7ca11-f9bf-4e0d-09f0-5106b7a7c932
Device ID: 2
Device name: Tesla K20c
GPU internal ID: 0324813082841
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.1 LTS
Release: 16.04
Codename: xenial
I originally installed everything using the JetPack 2.3.1 installer. Then I tried to fix this problem by upgrading CUDA to 8.0.44, which had no effect.
I was able to run an older version of the visionworks examples on the same hardware.
Thanks for you help!
