Hello! I successfully compiled visionworks in windows with nmake. However, in order to facilitate debugging, I want to generate a visual studio solution. However, the following error occurs. Is this missing a library? errors:main_video_stabilizer.obj : error LNK2019: 无法解析的外部符号 "public: __cdecl nvx::VideoStabilizer::VideoStabilizerParams::VideoStabilizerParams main_video_stabilizer.obj : error LNK2019: 无法解析的外部符号 "public: static class nvx::VideoStabilizer * __cdecl nvx::VideoStabilizer::createImageBasedVStab main_video_stabilizer.obj : error LNK2019: 无法解析的外部符号 "int __cdecl nvx::initDelayOfImages(struct _vx_context *,struct _vx_delay *)
Here is an embedded TX2 board.
It’s recommended to post your issue to the accurate place to get a better support.
Looks like you have solved this problem already.
Please let us know if you need helps.
