visionworks error
hello,I want to map vx_image object into cv::Mat object with nvx_cv::VXImageToCVMatMapper,but it needs to include #include “NVX/nvx_opencv_interop.hpp” and #include <opencv2/core/gpumat.hpp> is included in this function,however,this is no gpumat.hpp function in <opencv2/core/> directory in opencv 3.1.0,how should I do?
thank you!
According to topic 1032229, do you use VisionWorks on Windows?
https://devtalk.nvidia.com/default/topic/1032229/jetson-tx2/visionworks-error/
In the README of our latest VisionWorks Windows BETA, it requires to use OpenCV-2.4.13.
You can download and compile it here:
https://github.com/opencv/opencv/tree/2.4.13
TX2 from jetpack 3.2 is not turning to opencv3? When does it support opencv 3 in windows? Because debugging is more convenient in visual studio, thank you!
JetPack doesn’t support Windows.
[url]https://docs.nvidia.com/jetpack-l4t/index.html#developertools/mobile/jetpack/l4t/3.2/install.htm[/url]
It’s recommended to use Linux as host for better support.
To have an IDE environment, you can try Nsight EE for Linux:
