Where can I find standalone visionworks repository (not from jetpack) to install on drivepx2 ?
Dear pratik.bari,
Support for Visionworks is deprecated on Drive PX2. We have vision programming interface APIs to perform computer vision related operations. Could you check Drive 1.0 documentation(NvMedia sample applications → vision programming interface)
Hi SivaRamaKrishna,
Thanks for the reply. So is there any way that I can cross-compile the visionworks sample code running on x86-64 machine for the Drive PX2 ?
Hi SivaRamaKrishna,
I am also facing the same issue with DrivePX2 while I am able to install and use the vision works in Jetson Tx1.
My Question is when both are using Tegra Devices why it is not supporting in Drive PX2
I am sad that there is no answer.
When can you respond?
Dear pokurinataraj,
We deprecated support for visionworks. We see our NVMedia VPI primitives as alternative to visonworks. Could you please check NvMedia sample applications → vision programming interface in documentation.
Dear SivaRamaKrishna,
thank you for your support…
