and nobody knows or help or wont
in xp i can change output signal to tv from composite to svideo or mixed or else
but under vista there is only one option in control panel wich not work with my tv!
hardware is able tv is able im able but driver isn´t.
my english is bad but there is no german forum…
No German forum, but there is an NVIDIA hardware forum, which is at http://forums.nvidia.com/index.php?showforum=24.
The CUDA forum is a programming forum, so most people here probably can’t help you much, so give that one a try.
ok i do thank you
