I’m working on CUDA on Linux and now i gotta switch to Windows. But I’m wondering if there is another way to use CUDA without Visual Studio ? :ph34r:
Yes, through the command line of MS-DOS ^_^
Yes, you can just use notepad to edit code and complie it in MS-DOS through command line,but you should configuration more environment variables。
