Hi NVIDIA Isaac ROS team,
I’m using the [b]isaac_ros_visual_slam[/b]
package with the [i]realsense_example.launch.py[/i]
file from [i]nvblox_examples_bringup[/i]
, running in [b]mode:=people_detection[/b]
. The SLAM node (visual_slam_node
) consistently outputs warnings like the following:
[visual_slam_node]: Delta between current and previous frame [34.164736 ms] is above threshold [34.000000 ms]
[visual_slam_node]: Delta between current and previous frame [34.333952 ms] is above threshold [34.000000 ms]
[visual_slam_node]: Delta between current and previous frame [34.438400 ms] is above threshold [34.000000 ms]
🔍 Setup Details:
[list]
[]ROS 2 Humble
[]Isaac ROS 2024.1 release
[]RealSense D435i camera
[]RealSense FPS set to 30 (640x480 @ 30)
[]Using visual_slam_node in the provided launch structure
[]Running on GPU (Jetson Orin / x86 with NVIDIA GPU)
[*]Running live sensor (not rosbag)
[/list]
✅ What I’ve Tried:
[list]
[*]FPS is locked at 30 (verified via rqt)
[*]enable_sync:=True for RealSense
[*]–log-level warn does not suppress these warnings
[*]Modified vslam.launch.py to set max_frame_delta_time_ms = 50.0, but warnings still appear
[*]The actual deltas are only slightly above 34 ms (e.g., 34.2–34.4 ms)
[/list]
❓ My Question:
[list]
[*]Is there a default hardcoded threshold of 34.0 ms still being enforced?
[*]Does max_frame_delta_time_ms actually take effect when passed as a node parameter in the launch file?
[]Is there a better way to handle this frame jitter for a 30 FPS camera?
[]Would it be possible to officially support a small tolerance window (e.g., ±1 ms) to suppress false positives?
[/list]
Thanks in advance! Any guidance or clarification would be appreciated.
Best regards,
Abhishek
