jwson3
August 16, 2022, 9:40am
1
I try to use isaac_ros_visual_slam with realsense on jetson orin (docker, ros humble).
$ ros2 launch isaac_ros_visual_slam isaac_ros_visual_slam_realsense.launch.py
And I got error
ERROR] [launch]: Caught exception in launch (see debug for traceback): "package 'realsense2_camera' not found
so I tried
$ sudo apt-get install ros-$ROS_DISTRO-realsense2-camera
E: Unable to locate package ros-humble-realsense2-camera
Is there way to install realsense2_camera on humble (docker container)?
Or Can I get the foxy docker?
jwson3
August 17, 2022, 11:31am
2
I tried to install realsense sdk but failed.
The development team said Jetpack 34.1.1 is not supported yet.
I'm trying to use realsense D455 on Nvidia Jetson AGX Orin, with JetPack revision 34.1.1 on it. However, Jetpack 34.1.1 is not supported yet, according to https://github.com/IntelRealSense/...
You have to build the realsense2_camera
ROS2 package for Humble from the source and put it in your ROS workspace and follow this troubleshooting guide . Also, have a look at the link where it shows you how to extend run_dev.sh
to install any new dependencies inside Isaac ROS Dev base image.
jwson3
August 24, 2022, 4:31am
4
I will try it. Thanks so much
system
Closed
February 23, 2024, 7:42pm
5
