Hi, I have come across something I would consider a bit weird with building for various architectures in VS2008 (Cuda 5.0) and was wondering whether anyone could shed some light.
Build 1 - Architectures selected 1.1, 2.0 and 3.5. Builds fine, runs fine on all machines.
Build 2 - Architectures selected 2.0 and 3.5. Builds fine but only runs on Titan machine, not a 580 GTX which is compute 2.0. Eyebrows were raised.
Build 3 - Architectures selected 2.0. DOES NOT BUILD, complains that AtomicInc is undefined.
Build 4 - Archiectures selected 1.1, 2.0. Builds fine and runs on all machines (but obviously without 3.5 optimisations).
Why is AtomicInc not defined in 2.0, and why does the compiler allow the arch 2.0 to successfully build when it relies on something to do with the 3.5 architecture to build correctly? (The kernel that uses AtomicInc basically creates garbage). This has made me nervous about how the compiler is selecting what kernels and options to use if it happily continues using things it should know it cannot use.
Tiomat
