Hi.
I want to visualize the ionizing radiation emitted from a source.
I transformed one of IsaacSim example, ‘Jetbot_keyboard’, and implemented this by using Lidar sensor, like below.
However, I thought there is a fundamental problem, that is each ray can not penetrate the object and can not reflect the feature, attenuation of radiation.
Can I break through this problem by keeping using Lidar sensor ? or shoul I change the way to visualize it.
Thank you !
